Projects T&A Flathead Builds a '48 RagTop
Discussion in 'Traditional Customs' started by T&A Flathead, Aug 24, 2015.
  1. T&A Flathead
    T&A Flathead
    This thing sat all spring and summer and collected dust. Now that the snow is flying and the hot rods are away, I’ll be getting back to work.
    Still working on the rockers but made some progress today.
    9AF605B9-B618-4A3F-8079-F5EB53824A04.jpeg 4B3B8B07-4A5D-4C66-8B19-0ED77BFF1077.jpeg B4E0CCB9-2030-49B9-8ACF-CFA4AFC4CC88.jpeg 06B8D337-247E-4C21-BCF5-F08D5266BC79.jpeg
    reminder on how bad the cowl rocker was.
    A few more things to do and the cowl will be ready for welding to the floor.
    Outback, Okie Pete, cactus1 and 7 others like this.
  2. louisb
    louisb
    Just read this thread. Really nice work!
    —louis
    T&A Flathead and kidcampbell71 like this.
  3. T&A Flathead
    T&A Flathead
    Thank you.
  4. T&A Flathead
    T&A Flathead
    I had some good help in the shop today. Sam punched all the holes in the outer rocker so I can plug weld it to the inner rocker tomorrow. I also got the cowl inner rocker aligned and welded in. I’ve aligned the rocker at the b-pillar and made a brace. Hopefully I get the cowl tacked to the floor tomorrow.
    498C79B2-6768-4684-A6D4-70FCB6B95E37.jpeg 1460014C-079D-41F7-9415-7389197F11E9.jpeg D601BAAD-6D1E-4EE4-B4EF-93D6EB7A4833.jpeg A824A022-C813-4974-8BE6-DEE76775A55C.jpeg
  5. Looking good!
    T&A Flathead likes this.
  6. T&A Flathead
    T&A Flathead
    Thanks Mike! Long way to go.
    cactus1 likes this.
  7. T&A Flathead
    T&A Flathead
    Installed the B-pillar support that goes between the inner and outer rocker. I’m not entirely sure it looked like this because the rockers were completely rusted away. But this should work.
    And just like that the cowl is now welded to the donor floor.
    782FC0CC-7969-4147-BC20-07118E6EFBEB.jpeg A4B2917C-15E7-41BA-ADC5-4B7717BFAA17.jpeg F5B99317-C9CD-4FB9-90E2-63852FE08AB0.jpeg FFB56F63-D43A-424E-B1E5-B452F48C6E9E.jpeg
    Door gaps fit better than before I cut it apart and they can still be adjusted.
    The rear section is aligned in the factory holes but not welded in yet.
  8. That escalated quickly! Kickass!
  9. brady1929
    brady1929
    Looks great.
  10. T&A Flathead
    T&A Flathead
    Thanks guys @cactus1 and @brady1929
    I’ve been all over the place on power plants for this girl, from a 49 mercury Flathead to a small block Ford. I really want to keep this no newer than the mid 50s but want to keep it all Ford. I’m thinking a y-block now. Thoughts?
    I plan on driving the car a lot.
    Stogy and Okie Pete like this.
  11. I love y-blocks. The little 239 in my ‘54 pulled that car around great. OD trans was a plus!
    36 ROKIT and Stogy like this.
  12. T&A Flathead
    T&A Flathead
    I plan to use a T170 converted to closed drive shaft. Cheating a bit but I want OD.
  13. T&A Flathead
    T&A Flathead
    Buddy of mine @RHRH3P found this on Craigslist, so I checked it out on the way to work this AM and bought it. Talking cars and looking at his neat stuff made me way late to work so I still need to go back and pick it up.
    36 ROKIT, Tim, Stogy and 14 others like this.
  14. flatout51
    flatout51
    Stogy and T&A Flathead like this.
  15. T&A Flathead
    T&A Flathead
    More work today. Fixed some rust. Almost ready to tack the rear section to the rest of the car.
    E56EE364-FA0D-40C4-89EA-B208A177488F.jpeg E1985444-FC0D-4C7E-A307-FD1A61EC1F45.jpeg 1FC81FFB-BC64-4576-A45B-795758E4A79B.jpeg FCF4C904-D78F-448B-AB55-0C4373D9BB3A.jpeg C173FED8-366F-4763-AF9A-6F4CAAF8AAFD.jpeg CB965949-A644-4BF4-9A6F-EDFBA9571AD7.jpeg B4A686C5-E291-4423-A794-9A9AA657D9C0.jpeg 50C63A13-1649-4C88-8CA8-F0BF43165519.jpeg
    skatermann, RHRH3P, Stogy and 8 others like this.
  16. A Boner
    A Boner
    Looking good, Tim!
  17. T&A Flathead
    T&A Flathead
    Brought my engine home tonight.
  18. theman440
    theman440
    from Las Vegas
    That's a screwy looking carburetor!
  19. Okie Pete
    Okie Pete
  20. I am diggin’ this build. Like the way you grafted the two bodies together- lot of work but easier than cutting out that much rust and Forming complicated patches
  21. T&A Flathead
    T&A Flathead
    A little more progress since I decided to skip my day job today.
    I put the truck lid on just to check gaps and alignment before I begin welding the rear section down. Also fixed a rust through spot and started welding the rear section.
    Pretty pleased so far considering all this thing has been through.
    8371F57E-AE4C-465D-BEE5-4995AADD5ABA.jpeg BA2960B9-2458-4E08-B6D1-4A204489E943.jpeg 75BAC070-31D5-4A6B-A760-FE9122A2C8A1.jpeg 9C47E9C8-E8FA-427F-A0EE-27EBEEA44176.jpeg 635782D0-70C4-4FE2-9CBC-0D4A1A6F3E98.jpeg 18E6A860-3063-4448-962B-07C83B659560.jpeg E49E0F40-3E06-459F-B9BF-8BBA7240DE76.jpeg F3D81F84-0343-4ED9-839C-5FFCBA7F1674.jpeg C0514BB4-F8AA-499D-8580-98BC2CFF5302.jpeg 335B26EE-3E5C-4BA6-8D97-E1020DF71FC8.jpeg
  22. greaser
    greaser
    Incredible job, Tim. I always enjoy seeing your work! Looking forward to your next post.
  23. rusty1
    rusty1
    ...cool project and nice work,...here's a pic of Pat Barnhart's coupe before he converted it to a convert,..really liked this car, good luck with yours...
    Outback, kidcampbell71 and 509garyd like this.
  24. T&A Flathead
    T&A Flathead
    @greaser and @rusty1 , Thanks guys. Hopefully I’m back in the shop tomorrow.
  25. Love it! Great work and love your inspiration pics! Keep it up!
  26. Outback
    Outback
    from NE Vic
    Nice work, it's certainly coming together! The Y-block is a nice touch.
  27. T&A Flathead
    T&A Flathead
    Back in the shop for a couple hours today. Nothing too exciting, but I did finish welding the fender wells. I have more welding to do on the inside where the body supports contact the floor and the fender wells. Pretty happy with how everything lined back up. I was planning on molding the rear fenders into the body, but the fenders fit so go I really don’t need to. I’ll decide what to do later.
    0C05EC1F-AB5A-439F-A226-A7468381207B.jpeg 243EC4C4-10B0-47E2-8C37-982A128331B7.jpeg 74C8510F-0440-4D8F-BA9F-866B661BA33D.jpeg 41B52EF3-FAFE-47BC-A3E9-456C4294DF39.jpeg F2A88838-0EE0-4F0B-95EA-E0D7D2B59F40.jpeg 921F1FCF-0B67-4C59-9F98-987FDD38079E.jpeg 320E6967-7C28-4495-9173-E53CDD65CEEC.jpeg 1CE5B10E-6A0C-4CC4-94E2-D6686DE1308E.jpeg D3C8F907-2AC0-4176-ACD9-6A4D9A0BD47B.jpeg 2AA746BA-3AAA-403A-90BD-02EBA841AA06.jpeg
    I also need to decide if I should weld the seem on the inside where the rear section over lapped the fender wells, or just use a seem sealer.
  28. T&A Flathead
    T&A Flathead
    Hoping I can pull this off half as good as this.
    The Bill Roark ‘48 Ford.
  29. alchemy
    alchemy
    I really like that sea-blue-green on that convert.
  30. T&A Flathead
    T&A Flathead
    i do too.
