1932 Ford 5 Window SOLD
Discussion in 'Cars For Sale' started by Low"n"Slow, Aug 2, 2019.
  1. Low"n"Slow
    Low"n"Slow
    City: Bellingham
    State: Washington
    Price: SOLD
    For sale is a tradition coupe that runs and drives excellent and it is nice and quiet and tight
    1932 Henry Ford Steel Body and doors and the rest of the panels and floor are steel brookville
    Filled roof fixed windshield, filled in roof and garnish moldings have been chopped and chromed as well 3" chop cowl vent functions fine 39 Chevy tail lights painted in Acrylic Black Lacquer with flatener frame is gloss black and no body filler has been applied so what you see in the pictures is the body condition and all the rust has been cut out and replaced
    ASC frame rails and C notched in the rear with
    Model A front and rear cross members
    Chrome SAC front hairpins with a Magnum Chome /inset painted 4" drop axle and Pete & Jakes rear ladder bars chrome shocks f & r
    So Cal steering rods Vega steering box with borgeson anti vibration u joints 40/48 juice brakes with Locar emergency brakes with factor Ford 8" rear end out of a Maverick with 10" drums 3:55 gears
    Engine is a 8BA flat head with large camshaft Edelbrock Aluminum heads dual quad Offenhaueser intake with original 97 Strombergs
    Mallory ignition with traditional Packard 440 plug wires with raja boots T10 4 speed transmission with Hurst Rebuilt Vintage linkage
    11 gallon 32 fuel tank car has been wired using factory Ford method so if you were to remove the body of the ch***is the car will run without the body since the firewall stays intact with main wiring attached to tunnel and firewall accept the battery being in the trunk 32 adjustable re-upholstered seat with 2" lowered spring kit and has a 32 3 window style glove box with 1949 dash knobs Stewart Warner gauges 39 ford pedals 40 ford steering wheel and column vintage heater that works great and you can cut off heat/water flow from turning off the valve also new interior wood kit and dyna matted rubber floor mat but it still needs the rest of the interior completed 8,000 miles since the build you can drive it anywhere.
    Kamikazi, toptenmoe, TA22 and 14 others like this.
  2. Low"n"Slow
    Low"n"Slow
  3. Low"n"Slow
    Low"n"Slow
    ttt
    Willing to ***ist in Shipping.
  4. Low"n"Slow
    Low"n"Slow
    Price Drop $50,000
  5. Low"n"Slow
    Low"n"Slow
  6. Low"n"Slow
    Low"n"Slow
  7. Low"n"Slow
    Low"n"Slow
  8. Low"n"Slow
    Low"n"Slow
  9. Low"n"Slow
    Low"n"Slow
  10. Low"n"Slow
    Low"n"Slow
  11. Low"n"Slow
    Low"n"Slow
    Merry Christmas Bump
  12. Low"n"Slow
    Low"n"Slow
  13. Low"n"Slow
    Low"n"Slow
  14. Low"n"Slow
    Low"n"Slow
  15. Low"n"Slow
    Low"n"Slow
  16. Low"n"Slow
    Low"n"Slow
  17. Low"n"Slow
    Low"n"Slow
  18. Low"n"Slow
    Low"n"Slow
  19. Low"n"Slow
    Low"n"Slow
  20. Low"n"Slow
    Low"n"Slow
  21. Low"n"Slow
    Low"n"Slow
  22. Low"n"Slow
    Low"n"Slow
  23. Low"n"Slow
    Low"n"Slow
  24. Low"n"Slow
    Low"n"Slow
