Hot Rods Rich's Coupe - a ten year odyssey
Discussion in 'The Hokey Ass Message Board' started by Rich B., Nov 10, 2019.
  1. Rich B.
    Rich B.
    from Portage,IN
    DSC01084.JPG DSC01085.JPG DSC01086.JPG DSC01087.JPG I did not plan on using ignition wire covers on the valve covers, but decided
    I wanted the option. This meant I needed to make new larger blisters, I seem
    to do everything twice!
    I made these out of 19 gauge CR steel instead of alum like the others. I also shaped
    the hammer form to mimic the slight curve of the hood panel to stop the possibility
    of oil canning.
  2. Rich B.
    Rich B.
    from Portage,IN
    Theese pics are out of order in some places, but I had no pics in some places, and
    nunattax, brEad, Shadow Creek and 9 others like this.
  3. rd martin
    rd martin
    from indiana
    looks great rich!
    loudbang, Rich B. and kidcampbell71 like this.
  4. Rich B.
    Rich B.
    from Portage,IN
    A friend stopped by to see how things are going.
  5. Rich B.
    Rich B.
    from Portage,IN
    I wanted to finish up in the trunk. First I had to weld a strip of 16 gauge to the upper
    trunk edge to have something to fasten to. I used 1/4" nut certs for that.
    I could than make a pattern of the shape I needed, also used scratch awl to locate
    fastner holes.
    One of my favorite saws, uses 1/4" blade . It's an old Enco with multi speed , a couple are slow enough
    for metal.
  6. Rich B.
    Rich B.
    from Portage,IN
    I also finished the divider panels, and welded those in.
  7. Terraizer
    Terraizer
    Man, you do nice work.
    loudbang and Rich B. like this.
  8. Thor1
    Thor1
    Wow Rich! Like Terraizer said, you do NICE work! I love your panel and metal work. Superb!
    chryslerfan55, loudbang and Rich B. like this.
  9. Rich B.
    Rich B.
    from Portage,IN
    Here's some shots that I missed before. I did go back and edit a few in, but
    it's getting out of hand. photo bucket screwed up my pics with the dialog
    making it hard to follow what's next.
    Add to that my COPD is getting worse slowing me down.
  10. Rich B.
    Rich B.
    from Portage,IN
    Some more pic's:
    I did add more supports to the ladder bars.
  11. Rich B.
    Rich B.
    from Portage,IN
    This Shows the different wood required for the roll down rear window.
    the window regulator is housed in the rear shelf that I removed for more leg room.
    I fabbed a new drain pan, and ran the drain out thru a predrilled hole that I
    made for that reason.
    The window regulator uses the back shelf for mounting the roll up regulator.
    I adapted it to the new panel I fabbed support the regulator. It will be visible
    when I finish the interior metal. coupe50.JPG DSC00411.JPG coupe291.JPG coupe292.JPG coupe293.JPG
  12. Rich B.
    Rich B.
    from Portage,IN
    I was finally ready to fiinish the panel work in the cab. I'll just post the pics
  13. Rich B.
    Rich B.
    from Portage,IN
  14. Blues4U
    Blues4U
    from So Cal
    That's beautiful!
  15. gary kessler 1932
    gary kessler 1932
    Very nicely done!!!
  16. alchemy
    alchemy
    That car is so solid it's gonna be quieter than a new Lexus.
    scotty t and loudbang like this.
  17. Mike Colemire
    Mike Colemire
    All I can say is WOW!
  18. manyolcars
    manyolcars
    Anchor the seat so that it doesnt slide forward and crush you against the steering wheel and give you broken ribs when you have a minor crash against a concrete mailbox. yes, that is the voice of experience. I knew of a sweet old lady who died from a car hitting the p***enger rear fender and she fell out and hit her head on a curb when the door popped open. The car was quickly repaired. Two minor wrecks with injuries. Seat belts seem to be important, bear claw latches too
    chryslerfan55, Thor1 and loudbang like this.
  19. Rich B.
    Rich B.
    from Portage,IN
    Thank's guy's !
    Here's a few pics of the emergency brake install.I didn't want it on the floor,
    not much room there. It's a 40 brake handle, I just made some brackets to
    mount it with. really happy with the placement, and works great.
    I also have better pic of the bolt on shock mount. The frame has had xtra steel
    welded inside the web to beef it up. Any bolts going thru frame have a
    tube welded inside. coupe277.JPG coupe278.JPG coupe279.JPG coupe345.JPG coupe346.JPG
  20. GordonC
    GordonC
    Very nice stuff!
  21. loudbang
    Did you put some kind of lube between the wood and the new panels to prevent squeaks in the future?
  22. Rich B.
    Rich B.
    from Portage,IN
    There won’t be much movement with the metal
    Structure I built inside. Has been quiet since it’s
    Been on the road.
    manyolcars: the seat is anchored very well. The
    seat belts are not attached to seat, and would
    stop the seat from moving forward. The seat has it's own ratchet locking
    system to keep it from moving. This is why I put a 3 point belt system in.
    Rich
  23. Rich B.
    Rich B.
    from Portage,IN
    coupe308.jpg coupe309.jpg coupe303.JPG coupe304.JPG Here's my system for cutting holes for my gauges, or any circle.
    I have a nibbler that I mounted in a box to catch those pain in the ***
    c shaped cut pieces. It holds the nibbler in a fixed position. The
    holes needed for this are 5/16" center stud, and 1/2" for the cutting head.
    You hook the piece on the outer hole, than lock it down on center stud.
  24. Rich B.
    Rich B.
    from Portage,IN
    This is finished piece. The next view shows cutting head. I use a
    hole puncher to make things easier. Here's the final design. coupe305.JPG DSC01328.JPG DSC02206.JPG DSC01329.JPG
  25. Rich B.
    Rich B.
    from Portage,IN
    Ready to cut. Panel welded in. Finished piece. DSC01330.JPG DSC01330.JPG DSC01336.JPG DSC01337.JPG DSC01357.JPG
  26. GordonC
    GordonC
    Smarter than the average bear!
    scotty t, loudbang and Rich B. like this.
  27. loudbang
    chryslerfan55 and oldiron 440 like this.
  28. Rich B.
    Rich B.
    from Portage,IN
    If anyone copies the nibbler cutter, you must face the cutting head towards
    the outside of circle slightly. You can add a fence, and cut straight pieces of
    sheet metal. cuts very easy, leaves smooth edge.
    OFT and loudbang like this.
  29. Rich B.
    Rich B.
    from Portage,IN
    Finaly ready to get the frame painted.
  30. Rich B.
    Rich B.
    from Portage,IN
    Some pieces ready for ***embly. IMG_0672.JPG IMG_0671.JPG DSC01367.JPG DSC01369.JPG DSC01370.JPG
