Projects My Traditionally inspired ‘40 Chrysler
Discussion in 'Traditional Customs' started by sodakmini, Nov 2, 2019.
  1. sodakmini
    sodakmini
    It is a stock truck (1 ton) intake. With the heat risers removed and without the aluminum riser.
    scotty t and scrap metal 48 like this.
  2. paul philliup
    paul philliup
    from ohio
    I have a 39 Plymouth but I'm put a little move power in mine. IMG_20171029_091643708.jpg IMG_20190914_120702418.jpg
  3. gene-koning
    gene-koning
    I just couldn't let this go without a minor correction. With the introduction of the 1946 model full line of Mopar automotive production (coupes and sedans, all 4 makes) after the war years, the running boards were gone and the body flared out to the outer edge of where the old running boards were, between the front and rear fenders. The change in the lower body was about the only noticeable change between the 40-45 and the 46-48 (and early 49) cars. This lower body change is pretty clear to see in this last picture of Scotty T's coupe. Gene
  4. rusty rocket
    rusty rocket
    I'm sort of wondering why folks are posting pictures of their cars on the o.p.'s thread. They have nothing to do with his car other than being mopars.
  5. sodakmini
    sodakmini
    Huge snow storm today. When the power stays on long enough I’ve been out ****oning a few things up. Then decided to mock up the intake and carbs. Boy this should be fun this spring.
    [​IMG][​IMG][​IMG][​IMG]
  6. @sodakmini Im really liking what you’re doing with your car! It a great look and theme. Keep up the good work.
    kidcampbell71 and sodakmini like this.
  7. rusty rocket
    rusty rocket
    Looks kool!
    chryslerfan55 and sodakmini like this.
  8. In the 50's here in So Cal where I live, the drug dealers drove MOPAR cars like this because the Cops never pulled them over , too slow to bother with. These have pretty small rod bearings and loose rods often, so take it easy on that bottom end. Now days they're ok, I like yours.
  9. Chebby belair
    Chebby belair
    from Australia
    Will you need manifold heat?
  10. sodakmini
    sodakmini
    No. I looked into it a bit. If anything I may need to let it warm up a bit longer. Which I normally do anyhow. I’ve found a lot of people running similar setups
  11. ClayMart
    ClayMart
    If you've got the room, and the ambition, you could splice into a heater hose and add a section of copper pipe which could be mounted the length of the bottom of the manifold from front to rear. Easy to attach with a couple of clamps. Maybe not the quick heat like you'd get from the exhaust manifold but would still help with fuel atomization and to prevent carburetor icing.
    Maybe fab up a long "U" shaped tube so the inlet and exit would both be at the rear so you don't have to snake a lot of extra heater hose around under the hood.
  12. sodakmini
    sodakmini
    I’m not sure there will be any room. It hugs the exhaust quite close.
  13. ClayMart
    ClayMart
    You're right... I went back and looked at some of the manifold pictures above. :oops: They've got the exhaust snuggled up pretty tight under the intake, but then the carbs are quite a way above that. :rolleyes:
  14. sololobo
    sololobo
    love this rare hot rod
    sodakmini likes this.
  15. Sleepercooler
    Sleepercooler
    What a great project !! I like that car..
    Well done exhaust manifold, and who made the manifold, or which car is that manifold?
    I'm going to do the same thing on my own - 54 Windsor.
  16. sodakmini
    sodakmini
    Thank you. It is a early stock big truck intake.
  17. JackdaRabbit
    JackdaRabbit
    from WNC
    I'll be watching this project for sure. Perfect traditional plan, great attention to detail with well executed craftsmanship.
    The sounds of the family Mopar flat 6's from my early years still ring in my ears.
  18. Pensive Scribe
    Pensive Scribe
    I don't get that either. Killer Mopar Sodakmini.
  19. I must apologize for that, I posted some pics intending to suggest a modification or two. I dropped the ball on the wording tho!
  20. sodakmini
    sodakmini
    Started building the exhaust today. No pictures of that yet. Ran out of tubing, will finish after Xmas. Few just because pictures.
    [​IMG][​IMG][​IMG]
  21. Dan in Pasadena
    Dan in Pasadena
    SUCH a nice looking car.
  22. sodakmini
    sodakmini
    Thank you
  23. Terraizer
    Terraizer
    Awsome car
  24. the oil soup
    the oil soup
    from Tucson,AZ
    Wow, beautiful landscape shot with the car in the snow!
    You might think about adding some louvers to the hood as these old mopars have a heat soak problem and that really cured it on mine.
    sodakmini and chryslerfan55 like this.
  25. rusty rocket
    rusty rocket
    Straight piping it?
  26. sodakmini
    sodakmini
    Right up till it annoys me. Then it gets some short porters.
    Chebby belair and scotty t like this.
  27. sodakmini
    sodakmini
    Started working on the 2nd air cleaner tonight. Got a bit left. Did some mock up to see how high I can raise the carbs. IMG_8825.JPG IMG_8826.JPG IMG_8827.JPG IMG_8828.JPG
  28. classiccarjack
    classiccarjack
    I have never had this happen on any of my modified Mopar inlines. My Chevy 250, yes.... Not sure why the Mopars did not have this issue like my GM did.
    Sent from my Moto Z (2) using The H.A.M.B. mobile app
    ClayMart likes this.
  29. classiccarjack
    classiccarjack
    Chebby belair and sodakmini like this.
  30. ClayMart
    ClayMart
    Maybe on the Mopars they just did a little better job of heating the intake off of the exhaust manifold, maybe underhood temps ran bit higher. As far as carb icing goes, a lot of that depends on air temps, humidity and air speed and the pressure drop thru the carbs. I'd guess the Chevy 250s tended to run at higher RPMs than the Mopar flatheads.
