Projects 26 T Roadster Pick Up build Thread
Discussion in 'The Hokey Ass Message Board' started by Blue One, Mar 27, 2010.
  1. Blue One
    Blue One
    from Alberta
    I mentioned that transmission pan gasket leak earlier and it is still leaking :mad: another thing that’s my fault :D
    I know that the chrome stamped steel pans typically leak.
    Heck even the stock steel pans leak eventually.
    I installed one because I couldn’t find a stock depth aluminum pan anywhere.
    No extra depth pan for me to hang down on a already low car :eek:
    So I decided that I’ll take matters into my own hands in typical hot rodder fashion and order a deep pan and cut it down to suit my needs.
    ( Stock depth and capacity )
    A little bit of aluminum Tig welding and away I go.
    Searching lead to a pan I think will be perfect made by LPW Racing (USA made)
    I also picked up a Moroso silicone pan gasket.
    68DBD857-E492-46DB-B006-E1818640E08B.jpeg 32A1AAB4-27C1-4501-BFA4-58A29AB0E5D1.jpeg
    I’m also installing the new fan once I get the 1” fan spacer machined down to 3/4”. :cool:
  2. Blue One
    Blue One
    from Alberta
    This is an example that things can be overlooked at the best of times.
    I had a small weeping leak in the 29/32” core plug on the rear of the p***enger side head near the distributor.
    Couldn’t get it to stop. Looking closely it appeared to be leaking at the bottom of the inside of the cup not around the edge.
    So, I drained a jug of antifreeze and pulled it out.
    What I found was a thin rusty old plug that when pulled out revealed the pin hole leak when a piece of rust popped off.
    1425E8E8-5139-405D-B0A7-973443302480.jpeg EC3BB465-90D3-4A18-AFBD-E77D1E9252C8.jpeg B6314D95-D97A-43DE-B597-357889F90F59.jpeg
    So I ordered up some more core plugs which of course aren’t available locally. :mad:
    In the meantime I took a larger (1”-1 1/8”) rubber expansion plug and spun the diameter down on the belt sander to fit the hole snugly.
    The small one was too small and the big one was too big :D
    I know some people don’t like them but I’ve used them with good success in the past having had one installed on a old daily driver for over 10 years.
    It’s in place and not leaking and I’ll keep an eye on it and if’s it’s ever a problem it’s easy to change.
    brEad, AndersF, loudbang and 5 others like this.
  3. kidcampbell71
    kidcampbell71
    I was gonna' say dance a dremel stone across that chrome pan lip for gasket sealing ... but I'm looking forward to what you do to that aluminum pan.
    Cal Custom "custom" look ? Or whatever ... will be nice. You do good work.
    This whole build is so sano' & thought out. Super clean everything, & everywhere.
    brEad, Stogy, brad2v and 4 others like this.
  4. trollst
    trollst
    Look pal, I can clearly see this car is going to be a serious source of stress for you in the coming years, what with parts failing and the mistrust you'll develop in the car, you probably won't want to take it much further than the end of your street. I can help with that......
    If you want to retry the stock pan, try "the right stuff" for a sealer. My transmission guy uses it, never leaks, I wanted a gasket for my 8.8, and he wanted to seal it with that stuff, told me the gasket would weep, well, guess who was right. It does weep.
    Looking good pal, hope that first long ride brings the smile I think it will. LeRoy.
  5. Six Ball
    Six Ball
    from Nevada
    Those rubber plugs can be your best friend when on the road. My son and I replaced a leaky steel one some where in New Mexico on a trip from Nevada to Texas in his '54 Studebaker. It was in a spot that would have called fo some major dismantling to get another metal one in. It's been working for years. And yes the Right Stuff works but sometimes not fun to get things back apart.
    Stogy, loudbang and Blue One like this.
  6. Blue One
    Blue One
    from Alberta
    That rubber core plug is going away sooner rather than later as I got a package of new steel core plugs and decided to install one.
    I made a special tool to install it.
    I also installed the new fan and spacer after having the 1” thick spacer machined down to 3/4”. ( You can’t buy a 3/4” mechanical fan spacer)
    Still waiting for the transmission pan to arrive, probably this week.
    So as usual progress is slow but it’s not like I can go for a drive anyway. :D
    brEad, OFT, pcbart and 6 others like this.
  7. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Larry,
    Sure you can. Put on your Big Girl ******* and a scarf. Show 'em what Canadians are made of.
  8. Tim
    Tim
    from KCMO
    **** gear head if he drove the damn thing what would he have to do in the garage? This things gotta last him at least another year of fine tuning and specialized fixtures before it hits the street.
    26 T Ford RPU, loudbang and Blue One like this.
  9. Blue One
    Blue One
    from Alberta
    :D If you could see the toxic mixture of **** that they spread on our streets and the resulting brown to black mush we lovingly refer to as oatmeal you’d change your tune on that one :eek::D
    If it was just a little cold and some clean snow then it would be less of an issue although frost bite can be a little painful :D
    Dino 64, 26 T Ford RPU and loudbang like this.
  10. Rickybop
    Rickybop
    I've never done a full build, so I've never been where you're at right now, Larry. So close. But I've tried to imagine it. Any time I see any of you guys get real close to finishing a big project, I can't help but think the the excitement and emotions must be very high... along with some worry and stress of course. I feel it sometimes even with minor milestones on my stuff.
    And progress can be slow and a source of frustration. I'm the king of slow progress. Often, no progress LOL. Hard to find the time sometimes.
    But I'm actually kind of glad to see that you have another whole winter to finish up all the little details of your meticulously built hot rod. It deserves to be fussed over to the nth degree. You deserve the time to do that. And you'll head out next spring with full confidence and pride in a job well done.
    Enjoy the process.
    Still... can't hardly wait!!! [emoji16]
    Everybody have a good Sunday.
    Sent from my VS835 using The H.A.M.B. mobile app
  11. Six Ball
    Six Ball
    from Nevada
    I just want him to get done and drive off into the sunset. That makes my **** look like ****! :D
    brEad, bobbytnm and 26 T Ford RPU like this.
  12. Blue One
    Blue One
    from Alberta
    Transmission pan is here and very soon will be cut down and ready to install.
    Goodbye rubber core plug and hello new steel core plug. :cool:
  13. DDDenny
    Larry
    We just thought that was reindeer doo doo!;)
    Boy, that's going to take a big piece of aluminium rod and the top plug on your buzzbox.
    Curious, do you plan on preheating the pan to weld it?
    Blue One likes this.
  14. Tall t 26
    Tall t 26
    Looks awesome. Nice work.
  15. Blue One
    Blue One
    from Alberta
    :D I won’t be preheating the pan, but I have prepared a 12” square piece of 3/4” steel plate that I drilled so that I can bolt the pan down tight to it with the 11 bolts.
    That way it will keep the nice flat machined gasket surface.
    I’ll cut it down with Walter Zip Aluminum blades.
    I’ll be welding it with my Tig machine. :cool:
    loudbang, brEad, OFT and 2 others like this.
  16. The37Kid
    The37Kid
    Merry Christmas! Thanks for that Aluminum disk tip, never knew they were out there. Bob
  17. DDDenny
    The Walter line of cutoff discs are premium, when I ran the toolroom I got no whining unlike some other brands.
    Blue One and The37Kid like this.
  18. DDDenny
    I knew that!
    Good thing you are doing it now rather than after being saturated with ATF.
  19. The37Kid
    The37Kid
    Will you V out both sides, and weld inside and out? Belt & suspenders thinking I know. Bob
  20. Blue One
    Blue One
    from Alberta
    I’m thinking that I’ll fit up the bottom (after cutting it down) using a corner joint all around.
    After welding I can just fuse the inside corner with a quick fusing p*** with the Tig
    Dino 64 and loudbang like this.
  21. Blue One
    Blue One
    from Alberta
    That would be tough. I’m only doing the cut down because I couldn’t find a stock depth aluminum pan.
    This LPW pan is very nice and the design lends itself well to cutting down to stock depth and capacity.
  22. The37Kid
    The37Kid
    Ok, I had it pictured cut in the center and a section cut out, like a body top chop. Bob
  23. Blue One
    Blue One
    from Alberta
    That would be one way to do it. I think I’ll have better success cutting the bottom off and then taking a section off and then putting the bottom back on because the pan has a very slight taper to the sides that you can barely see.
  24. The37Kid
    The37Kid
    Reminds me of the old days when I could Heli Arc stuff, maybe 2020 is the year I can fund a TIG unit. Bob
  25. Blue One
    Blue One
    from Alberta
    Six Ball, OFT, The37Kid and 2 others like this.
  26. RICH B
    RICH B
    Do those discs leave any abrasives in the cut or is it left clean of any contaminants that could effect welding? Vaguely remembering some problems we had when building aluminum block beds.
  27. Blue One
    Blue One
    from Alberta
    No abrasive residue or steel contamination like you’d get using a steel cutting disc.
    The aluminum discs don’t load up like the steel discs do.
    Nice clean cuts ready for welding.
    loudbang, 26 T Ford RPU and Tim like this.
  28. Blue One
    Blue One
    from Alberta
    Did some measuring and went ahead and cut the pan down.
    Welded it inside and out and then used a flapper disc and smoothed out the outside welds.
    That allowed me to take the pan to the blasting cabinet and make it look like it was never cut down.
    It’s now stock depth and capacity. :cool:
    Ready to install. :cool:
    045ABACD-E870-496B-ABEA-B2BDD9FAF197.jpeg E0D8611B-960E-4BF5-9F0A-12AF50C5F11B.jpeg 1C628578-8D11-48DD-8FE1-6FE6E7623B49.jpeg 7C7A7EA4-1C98-4F63-9995-AA0099DD7F53.jpeg 1B6A39FD-BECC-459E-9953-A6A07397060C.jpeg
    Tim_with_a_T, brEad, brad2v and 17 others like this.
  29. atch
    atch
    ^^^^^^^that's pretty darn slick.
    Dino 64, loudbang and Blue One like this.
  30. Blue One
    Blue One
    from Alberta
    I decided that since I have it all blasted and clean that I should paint it.
    First I went out to the garage and leak tested it with a little solvent just to be sure. As expected no leaks.
    Then a nice coat of etching primer (It dries to a dull flat finish) before the coat of black. :cool:
    The 39 guy, Dino 64, RICH B and 4 others like this.
