Projects Another New England build. . . From pieces
Discussion in 'Traditional Hot Rods' started by wheeldog57, Dec 9, 2017.
  1. sloppy jalopies
    sloppy jalopies
    I agree bob... when I started using it, it was called sili-kroil…
    best stuff I have ever used...
    and $18 a can is cheap when it breaks the bolt loose and nothing else does...
    but don't waste it like it was $2 a can wd40...
    told a kid down the street to try it...
    he cried when he had to pay for it,
    but ended up getting his truck stuff loose and fixed a couple adjustable wrenches for dad...
  2. wheeldog57
    wheeldog57
  3. wheeldog57
    wheeldog57
    This is a door that Sloppy pulled off of a doodle bug that was sitting deep in the woods of Maine
    I gathered up all my s****s let's see if I can make something. The inner panel was very thin and buckled so I cut out the bad and fit in a p***enger side piece. 20191129_154556.jpg . . .
  4. wheeldog57
    wheeldog57
  5. wheeldog57
    wheeldog57
    I dug out a sedan door that had intact inner structures and most of the bottom so I spliced some from it 20191130_165401.jpg 20191130_175436.jpg into the coupe door. The sedan door has a decent top on it too so I will be grafting that at a later time
    48fordnut, Baron, brEad and 7 others like this.
  6. sloppy jalopies
    sloppy jalopies
    Ron, I have 3 -'30 coupe doors, don't recall the tops condition, also both of the inner panels I cut off for the sportster doors, full length, the stock armrest section of the doors...full length... I will pm you pix if you want...
    computer says no on new pix ?
    Baron, biggeorge, OFT and 1 other person like this.
  7. wheeldog57
    wheeldog57
    Thanks Smitty, PM sent
    Baron likes this.
  8. low budget
    low budget
    from Central Ky
    Love these Something from nothing builds, Thanks for sharing!:cool:
  9. manyolcars
    manyolcars
    You're gonna give Jim Sibley a run for the ***le of Something Great from Nothing
    pitman and brEad like this.
  10. Greg Rogers
    Greg Rogers
  11. Nailhead A-V8
    Nailhead A-V8
  12. Pete
    Pete
    Wheelah
    wheeldog57 and patmanta like this.
  13. wheeldog57
    wheeldog57
    Went up to visit @sloppy jalopies today with a couple pals. Smitty is making great progress on his project. He has a garage and yard full of early Ford stuff, everywhere you look. In the rafters, on the walls, in the corners, upstairs, outside, everywhere! He is also a wealth of knowledge and doesn't mind sharing. It was 9 degrees up there but I wasn't cold because I was too busy looking for goodies!
    Smitty hooked me up with coupe door tops and a bunch of other sheet metal s****s.
  14. wheeldog57
    wheeldog57
    Had a couple hours in the hideout today
    I cut out a crispy but better than none inner door piece from the donor sedan door.
    Measured a few times, cut, fit, cut again,
    Then welded it up. 20200202_141144.jpg 20200202_141325.jpg 20200202_154058.jpg
    Baron, Nailhead A-V8, Thor1 and 7 others like this.
  15. wheeldog57
    wheeldog57
    I scored a repop p*** side inner structure from Mike B. of course. So I fit one side of that, more soon 20200202_212659.jpg 20200202_212721.jpg so now I have to cut out the rust and make new pieces at the corners, yay!
  16. wheeldog57
    wheeldog57
    Sometimes I look at the **** i am working with and I say " what am I doing!???"
    But the parts honestly are a little better than they show in the pictures. And I am having fun patching the rust. Maybe it's a challenge thing.
    If I can make something from s****s, I feel good about it.
  17. biggeorge
    biggeorge
    wheeldog57 likes this.
  18. sloppy jalopies
    sloppy jalopies
    I have 4 ... also, the front edge of an easier to find rear door should work...
    go ron go !
  19. solidaxle
    solidaxle
    from Upstate,NY
    That's what happens when you have the talent and skills.
  20. wheeldog57
    wheeldog57
    Got a few hours in the garage today, lit a fire and got some grinding and welding done on the p***enger side door. 20200329_145706.jpg 20200329_145656.jpg
    30 bottom corner is killed so I fabbed 20200329_162002.jpg 20200329_163251.jpg up a piece
  21. biggeorge
    biggeorge
  22. wheeldog57
    wheeldog57
    The side had rot holes in it so I made a piece for that too. Alot of fitment, cut and grind. 20200329_192222.jpg 20200329_192232.jpg 20200329_192244.jpg
    I posted a thread asking the height of a coupe door and 20 minutes later Continental John hooked me up- Thanks bud. 20200329_151722.jpg
  23. sloppy jalopies
    sloppy jalopies
    Hold the phone,
    memory says a '30 coupe door is slightly taller [at the B jam than the A jam] .
    measure between bottom of the beltline and the top of the lower bead...
    I will post the A jam and B jam measurements Monday, raining now...
    well this ain't the wizard of oz... I won't melt...
    measured a door that still had a slight bead crease at the bottom...
    painted over measurement was with bead curled up... didn't let the tape drop all the way down,
    bent the ragged edge back to normal,
    front was 21 3/8"... the rear was 21 1/2"... cross checked on my sportster quarter... 21 1/2". DSCN5795.JPG
  24. wheeldog57
    wheeldog57
    Thanks guys, I will fit patches once I have a semblance of a car. . .. more to come
  25. sloppy jalopies
    sloppy jalopies
    I have a couple used coupe door skins, not perfect but better than what I see in the pix above...
    free ron, come get them...
    was just given [4] more '30-'31 truck doors. no tops,
    all cut up, patches taken but may be enough left to float your boat...
  26. jimvette59
    jimvette59
    Tell me how do you deal with sandwich rust ?
    sloppy jalopies likes this.
  27. sliceddeuce
    sliceddeuce
    I admire your determination.
  28. sloppy jalopies
    sloppy jalopies
    thanks SD...
    JV59, what is sandwich rust... ?
  29. jimvette59
    jimvette59
    That is the rust you can't get to between parts of the body tin and the support structures inside. Like a cowl and the braces inside or a door skin and the inner door panels.
  30. sloppy jalopies
    sloppy jalopies
    wire brush and then paint the daylights out of it...
    interior rust is not going to eat the tin like it did because these cars are never going to be left outside as the were in their last life...
    48fordnut and chryslerfan55 like this.
