Technical 1960 Pontiac Catalina manual trans swap
Discussion in 'The Hokey Ass Message Board' started by 4Birdman, Dec 3, 2019.
  1. 4Birdman
    4Birdman
    Anyone know what pedals/linkages would work? I know 59-60 Pontiac definitely, but not sure if anyone knows anything else close that just needs a little tweaking to make work before I have to go fab happy.
    I've had this car for a little while and my sons decided they wanted to build it. I am bringing it to the house tomorrow. It is a 389 automatic car of unknown condition. I will probably just drive it as is if the engine runs ok, but if the engine needs work I am going to put one of my 400s and ST-10s into it. Just wondering where I might be able to get the pedal and linkages to make it work. I know I'll have to do some fab work, but just wondering how much.
    j-jock, chryslerfan55 and 31 B'ville like this.
  2. missysdad1
    missysdad1
    Put out the word that you are looking for a '60 Pontiac pedal setup, here on the HAMB and on other related sites. Not that rare back in the day so you should be able to scare up a bolt-in OEM setup. Just be patient...
  3. 302GMC
    302GMC
    from Idaho
    You should try your best to find a complete factory stick parts car. Expect to pay a pretty good amount for it. It'll be worth every cent. Good luck !!!
  4. wvenfield
    wvenfield
    I saw this on the Pontiac site. I remarked on it. Anyway, someone here will know. I have pedals out of a 61 Catalina. (sort of). I think they are the same. Anyway, if it is and interested............ I have NO linkage.
  5. KoolKat-57
    KoolKat-57
    from Dublin, OH
  6. Elcohaulic
    Elcohaulic
    Pontiac Heaven has it..
  7. Possibly the pedals and linkage from a 60 Chevrolet could be used? Yes put a wanted add on the HAMB. I sold wvenfield a set of pedals from a 56 for his Pontiac. I have a 60 Pontiac mine like yours is a automatic. 60 pontiac 003.JPG
    chryslerfan55 and Hnstray like this.
  8. Slopok
    Slopok
    I may be wrong but doesn't the '60 have an X frame and '61 a perimeter frame???
    Would that even make a difference?
    31hotrodguy and Elcohaulic like this.
  9. Yes. Most likely why the fab craft metal kit won't work. I think the o/p answered his own question...59-60 only
  10. mgtstumpy
    mgtstumpy
    I gather that similar bodied GM pedals would be close and work in your application:-
    • Chevrolet Biscayne;
    • Oldsmobile 88; and
    • Buick LeSabre
  11. Maybe Olds /Buick (even rarer over here) Chevrolet tended to have more conventional looking stuff.
  12. wvenfield
    wvenfield
    Am I wrong or don't both have hanging pedals?
  13. 4Birdman
    4Birdman
    They only have 61+. I'll fab up my own before I drop that much on a pedal and some linkage.
    Thanks, just sent them a message.
  14. Yep $725 is pretty steep for clutch pedal .
    31hotrodguy likes this.
  15. Yes, they do.
    wvenfield likes this.
  16. I think you could make Chevy pedals work, they both hang and the master is in the same place. The under-dash part is similar with the column attachment and the pedal bracket and all. Linkage, you may have to fabricate, but here again I'd start with Chevy stuff. Not that the Pontiac specific is not out there but it's pretty scarce. I presume you'd go floor shift, the factory column shift for the manual is kind of weak and of course only came on a 3-speed.
    You may be able to bolt the 400 to the dual coupling Hydro, which is not a bad trans for an auto. The bolt pattern is close. Getting the starter meshed up may be an issue. Usually guys want to go the other way, late trans to early motor, which requires an adapter because the 1960 starter mounts on the trans and the 1965-up block mounts it on an ear on the block.
  17. 4Birdman
    4Birdman
    I'm kind of thinking I can make a Chevy pedal work. I might go with a hydraulic clutch setup too. If that is the case I can go through my stash of hanging clutch pedals in my attic from random cars and see what might work. If I have to chop and weld some things onto the pedal or whatever, no big deal.
  18. wvenfield
    wvenfield
    I have 61 Pontiac pedals. I'll get a pic later.
  19. 4Birdman
    4Birdman
    Thanks. I found a couple diagrams of the 59 vs 58 pedal setup and they don't look THAT dissimilar. I think we are going to end up going with a hydraulic clutch setup though just for ease of installation and finding linkage parts.
  20. wvenfield
    wvenfield
    I was going to do the same until old wolf dragged the parts I needed out of some weeds.
  21. Actually it was a s****per who drug the remains of a 56 Pontiac out. not too much there. front part of a frame. cowl,hood ,316 engine and trans. I seen it was a stick bell & trans. So I bought it from that s****per and saved it from being recycled. And was able to sell the pedals and linkage and recoup part of my money. the parts you need are setting someplace just waiting to be found. I never liked hyd clutch releases. I like mechanical release. ive drove some 60 thru 62 GMC & chevy that had hyd clutch. I always converted them using 63 thru 66 mechanical linkage. pontiac parts 104.JPG 56 pontiac 010.JPG pontiac eng 002.JPG
  22. wvenfield
    wvenfield
    Anyway, this is what I have. Came out of a 61. Not all original obviously. IMG_20191204_124912.jpg
  23. 4Birdman
    4Birdman
    I don't mind hydraulic clutches, I'm used to driving my 98 Trans Am so the feel will be about the same. Granted, I've driven both but hydraulic doesn't bother me.
  24. 57-back have under floor mount pedals, 58 I think is the transition year to hanging pedals.
    They may be exactly the same as a Chevy given the body shell is the same.
    61 is an entirely different body shell.
    Old wolf likes this.
  25. bobss396
    bobss396
    I run a hydraulic clutch in my Ford and it was the way to go. I have about 12k miles on it and have yet to touch it.
  26. treb11
    treb11
    Probably. That way you just need to find/make the z-bar
    Sent from my SM-G965U using The H.A.M.B. mobile app
  27. 302GMC
    302GMC
    from Idaho
    You guys are forgetting the overcenter spring mechanism that decreases pedal pressure … there's a whole lot of parts in a Pontiac clutch setup not used in a Chevrolet. When the Pontiac is set up as delivered from the factory, it requires far less effort to operate, and is as smooth a setup as ever built.
  28. stuart in mn
    stuart in mn
    Here's the 1961 parts catalog illustration of the brake/clutch pedal ***embly for 1961 cars.
    mgtstumpy and 302GMC like this.
  29. 421-6Speed
    421-6Speed
    This is a 60 Pontiac clutch brake pedal ***embly setup. The bad part about the Pontiac is the bellcrank is a piece of flat bar that can twist, not near as strong as the Chev. I think you could make a 59-60 Chevrolet pedal ***embly and bellcrank work with not a lot of effort. I do have a set of Chevrolet 59-60 pedal ***embly if interested.
    4-Speed Conversion.jpg Backup light switch 2.jpg Clutch Pedal Assembly 1.jpg Clutch Pedal Assembly 3.jpg Clutch Pedal Assembly Restored.jpg
  30. Rocky
    Rocky
    Classified Editor
    I took the engine/trans out of a 59 ambulance. Interestingly enough, the car had floor-mount pedals like a 55-57 Pontiac. It also came with the heavy duty Borg Warner T-85 transmission. Sold off the engine and trans but I kept the entire clutch, bell housing, flywheel and core clutch. Used it in my 34
    31hotrodguy and loudbang like this.
