I've not done this before so I'd like a little advice from some folks who have. The catch 22 is as follows. To remove the steering wheel, you need to withdraw the light switch rod. However it's too long and hits the roof before it comes out. So what do I do? Drop the entire column/box down a bit before removing, or is it possible to remove the entire ***embly with the steering wheel in place? Sent from my SM-G935F using The H.A.M.B. mobile app
Well I worked it out. You have to drop the box, tilt the column slightly and then withdraw the light switch up out of the doorway. Sent from my SM-G935F using The H.A.M.B. mobile app
Has anyone got any special tips to make replacing the worm easy, or at least possible? I've done it before and it was a nightmare. I was thinking of cutting the old worm off carefully. Then heating the new one in a household electric oven for half an hour then fitting it. Would that work? Sent from my SM-G935F using The H.A.M.B. mobile app
Might work. Last one I did I cut through the old worm, then used a br*** hammer to pound on the new one. It was a nightmare. I've seen guys press them on, and also seen them bend the shaft while pressing. If you try to press make sure to carefully protect the threaded end, and clamp some heavy angle to the shaft to keep it straight. And make sure to show us pics of your successes (or failures).
I wo .uld think you would freeze the shaft in a large freezer. Heating the gear will make it expand in all directions so therefore shrinking the bore on the gear
Yes I found it did. So I removed it and then I lightly hand sanded the shaft to reduce the diameter by a thou or so, then hammered the worm on cold. It took heavy blows towards the end but it ended up flush again and tight. Sent from my SM-G935F using The H.A.M.B. mobile app
Indeed. Pressing is no good. You need the shock blows of a hammer. Sent from my SM-G935F using The H.A.M.B. mobile app
