Folks Of Interest How many of you are true garage builders ?
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Jun 10, 2019.
  1. Fortunateson
    Fortunateson
  2. mad mikey
    mad mikey
    Built my first hot rod when I was 15 in my parents garage. Built a engine for it, 327 with a old 671 blower. Did I know exactly what I was doing? Hell no! Figured it out. Was the car fast? Hell yea. Have always built my hot rods and engines myself. Keeps me sane. Kind of.
    lumpy 63 likes this.
  3. Tickety Boo
    Tickety Boo
    from Wisconsin
    Ya keeps me sane too, ;)...Except for the Engine noises in my head :oops:
    mad mikey likes this.
  4. junkyardgenius
    junkyardgenius
    from Kernow
    50CFC9E7-4138-4872-8B10-F4FBEA57DD38.jpeg If don,t get done in here it don,t get done.
    JUNK ROD and mad mikey like this.
  5. winduptoy
    winduptoy
    Oh, no I've been found out....sometime I fill up the driveway Bus engine install 012.jpg Bus engine install 013.jpg
    JUNK ROD and Hamtown Al like this.
  6. Sculptive Design Co.
    I am a garage builder. I'm 30 and finally got my own space. A 19'x19' two car garage. I am thankful just to have a space. Hopefully 2020 I will have a running Model A ch***is. 75483287_313455339537492_7866330141987346472_n.jpg
  7. warbird1
    warbird1
    I've been building them in a garage, or driveway, for 50+ years now... see my avatar. A long time ago I learned that I can generally do anything as well as most shops can the hard, expensive way; so have done all my own engines, trans, ch***is and suspension; also body work, paint and gl*** work. Only thing I didn't do was the machine work. Installing the interior on my '40 now which has been quite interesting.
    I had this one professionally painted simply because I didn't have a place to do it anymore... wish I hadn't.
    UNSHINED 2, mad mikey and lumpy 63 like this.
  8. 48reo
    48reo
    20171015_135746.jpg I have a one car garage but it goes all the way thru so I have a portable carport for all the vehicular surgery
    JUNK ROD, LAROKE and mad mikey like this.
  9. Rusty Heaps
    Rusty Heaps
    I have no garage! Does that make me a True Shade Tree Mechanic?:rolleyes:
    LAROKE and winduptoy like this.
  10. jailbar joe
    jailbar joe
    sorry...i paid someone to build my garage
    winduptoy likes this.
  11. flamedabone
    flamedabone
    This is the original location of the super famous, yet top secret Flamedabone Color Application Studio.
    -Abone.
    JUNK ROD, shortypu and mad mikey like this.
  12. low budget
    low budget
    from Central Ky
    Any more pics of the 55 olds? I like it!:cool:
  13. error404
    error404
    from CA
    My day job is creating computer graphics, VFX for products, commercials and films. I work on vehicles at home for fun :)
    I do just about everything myself, except rebuild transmissions and re-gear axles. I've just never wanted to attempt that before. I've never worked on vehicles that required nice paint, so I haven't crossed that bridge yet. Most of what I've worked on is 4x4 jeeps/willys, and I intend to keep doing everything myself for my 33 Chevy too :)
    I don't really have a garage though, I used to have a 1 car garage, but that's where all my tools and machines were, no where near enough room for a vehicle so I did all my work in the driveway. Now I don't have a garage or a driveway, just a (new!) 2 car covered "carport" on a concrete pad with alley access, and a walled up 1 car garage "big shed" type thing. It's nice to have more space, but I really wish I had a 3 or 4 car garage, closed up. Maybe someday :)
    I also dabble a bit in machining. I have a small lathe, would like a bigger one, and would like a 3 axis mill.
  14. Hank37
    Hank37
    Here's my Caddy mill before I overhauled it and replaced heads with 57 Caddy ported and polished and pulled the Howards M-4 cam and replaced it with a Crane ultra hi rpm drag cam then replaced crankshaft with a Crankshaft Co. stroker kit with 12.1 pistons then it's shown in my rolling ch***is circa 1965 . I removed body and Olds. DSC00269.JPG DSC00270.JPG mill and painted frame .
  15. grdra1
    grdra1
    I try to do everything myself, if Ive never done it before I will buy the tools required and do my research, usually youtube, books or thehamb and give it a go. Its generally takes a couple of go's to get it right but the knowledge / skills obtained is well worth it. Glen P7040499.JPG P8200620.JPG P9290682.JPG P1011171.JPG P1011302.JPG P1011254.JPG P1010117.JPG
  16. Mark A Garcia
    Mark A Garcia
  17. Mark A Garcia
    Mark A Garcia
    I have done all my work in a 1 car carport. I farm out my engine machining, but I ***emble them. I narrow my own rears, modify my frames, really like fabricating my own stuff if I can. Last year I finally poured a slab in the back yard but no roof yet. Built lots of muscle car hot rods during my street racing days which want that long ago since I retired last year. Guess you never get over this stuff.
  18. raymay
    raymay
    After 41 years this past summer I decided it was time to rebuilt the outside of my Garage. It is an old 1920's truck farm barn that has seen several modifications and additions over the years. Critters were always chewing into the layers of wood siding so I chose a less maintenance approach and used metal siding with some new vinyl and gl*** block windows this time. Still need to install new upstairs deck railing when the weather breaks. Happy with the results so far.
  19. camcrusher
    camcrusher
    from Candor, NY
    IMG_20191016_170257399.jpg I've since pulled the Chevy out and put a running 4 banger in. I have no heat in the shop so winter's are for collecting parts.
    jimgoetz, JUNK ROD and mad mikey like this.
  20. camcrusher
    camcrusher
    from Candor, NY
  21. southcross2631
    southcross2631
    After I retired from 30 years of being a mechanic for the Govt. I moved to Florida and opened a shop and turned out some cars.
    Sold it all to move to Tn. to do my own thing in a one car garage and 10x20 storage shed.
    Hopefully in the spring I can put up a 2 car garage in the back yard. 2014-08-27 13.32.07-1.jpg 2014-09-11 12.13.49.jpg 2015-03-19 15.59.33.jpg DSCF3536.JPG DSCF3557.JPG
  22. T. Turtle
    T. Turtle
    Don't have a garage - where I live separate garages are hard to find so when I work I use a friend's place, which means I have to plan ahead. I used to work on other people's cars for living but then went back to study, moved from one country to another and have a full time OT job and time is tight so I do everything in spurts - I take a few days off and do as much as I can. I Do the things I'm good at (bodywork) on my own, get help from friends on those I'm not so good at lol.
    So yes and no:)
  23. johnold1938
    johnold1938
    from indiana
    journeyman electrician and part time krafter of metal and machine DSC00241.JPG
    JUNK ROD likes this.
    Long before I was a home garage builder, I was a work-in-the-rain-and-snow-behind-the-house builder.
    It was so great to build a garage.
    Now that my garage overflows, I am back to working outside again :)
    If I didn't do all my own work, I couldn't afford to have a cool car at all.
    All the greatest adventures I have had, have come from being too poor to buy my way through.
    WHY BE ORDINARY ?
  25. rudestude
    rudestude
    Garage? That would be nice ....
    Ya ...this time of the year living in NW Oregon along the Columbia River....ya a garage would help...
    But the house does have 5 bedrooms ...and there's a chance that there are some hot rod parts in some ,most , all of them...and I possibly had to slide a dash panel for my Studebaker down the kitchen counter to have room to prepare my dinner last night, and while relaxing in my new overstuffed oversized reclining chair watching a very large flat screen tv....that may have a tunnel ram setup for a sbc. and a few other vintage intakes placed here and there next to it and whats that on the other side ....looks to be a couple of dropped tube axles some vintage aluminum valve covers , disc brake setups oh ya watch out for that M-22 and ****ter shield in the hallway ......and ya its a real possiblity that I'm most likely single. IMG_20161113_102738.jpeg IMG_20181026_111241~2.jpeg
    Sent from my SM-T387V using The H.A.M.B. mobile app
  26. indyjps
    indyjps
    I dont build transmissions or sew seat covers. Everything else, Im game, dont have any machining equipment, limited there.
    I have built many garages as well:)
  27. Baumi
    Baumi
    image.jpeg Garage??? I wish I had a shade tree.... I'm more of a barn builder using what I can find to put things back together
    JUNK ROD, jnaki and j hansen like this.
  28. 40-50 hour work week, which has an additional 10 hours added on because I coach football & baseball at a local school. I do all my own wrenching, but this is my first car and I just don't have the tools I would need to do much more. I would love to build my own engines, and I'm working towards getting there. Tuning and any welding I have to outsource due to a lack of tools, knowledge, and experience.
    LAROKE and j hansen like this.
  29. mister Bill
    mister Bill
    Built the garage too.
    UNSHINED 2 and JUNK ROD like this.
  30. 340HilbornDuster
    340HilbornDuster
    Mr Roothawg...
    Home Builder? I guess would consider myself as such....
    Pro?... Nope!
    - Spend way to much time at Work! (not enough on Hot Rod Projects)!
    - Like to do "everything myself" and not Buy everything like on TV...
    - Poor...Nah...Just Cheap i guess OR I want it Done My Way...!
    - It's great to get a little help from my friends too!!! Thanks Buddies!
    - Paint...Aaah...sorta...
    See links below
