Projects Aussie 32 frame / Model A coupe build.
Discussion in 'Traditional Hot Rods' started by Wardog, Feb 7, 2019.
  1. Wardog
    Wardog
    So I fired my engine up this week. It’s the first time in the frame , with pipes and with the stromberg e fire ignition. My wife took a cool video on her phone but I can’t post it. I took this screen shot of the moment I hit the starter cable on the jumper cables.
    ct1932ford, 1947knuck, brEad and 4 others like this.
  2. Dick Stevens
    Dick Stevens
    You have to post the video on youtube and then you post the link on here! Hoping to see that posted, soon :D
    Stogy and chryslerfan55 like this.
  3. Wardog
    Wardog
    This is when the family heard me and came out to see what I was up to. Also when my fuel can was running out.
  4. Wardog
    Wardog
  5. Jeff34
    Jeff34
    Even the dog came out to watch!
    Bravo! Sounds awesome, but you put the steering wheel on the wrong side [emoji12]
    sleepchamber and chryslerfan55 like this.
  6. Wardog
    Wardog
    @Jeff34 Its a family affair. Yep, it’s right hand drive.
    1947knuck, chryslerfan55 and Jeff34 like this.
  7. A Boner
    A Boner
    They have to put the steering wheel on the wrong side of the car.....they drive on the wrong side of the road!
  8. Benny28
    Benny28
    from Australia
    I probably could of heard you start her up from my place [emoji106]
  9. Wardog
    Wardog
    Haha. Yeah maybe. But don’t worry I’m working on making it not run again soon....
    1947knuck and chryslerfan55 like this.
  10. Wardog
    Wardog
    Last weekend I painted the throttle body’s, generator and fan. Yesterday I had an afternoon to myself so I went through the carbs and ***embled it all. Now I need to sort a linkage and a fuel line from the pump to the carbs. FD01A822-0DFB-4EFC-951A-C6E2A3A6A81C.jpeg CEBEA876-494F-4FC9-9ACF-28422AE7C359.jpeg 10688003-4A63-4349-AD29-FBDF31216F1B.jpeg
    ct1932ford, 1947knuck, brEad and 6 others like this.
  11. Wardog
    Wardog
    I made a 2 carb linkage. The clamp on arms are from micro switches we use at work. They fit perfectly and seem to work well. I’m happy with the result.
    D48BF47F-096F-41E3-B411-FD8F35FD96C1.jpeg EFE22887-3AEC-497F-81B5-7C51AE377A1D.jpeg 31D21729-3918-43CB-A642-5598E04CBC98.jpeg
  12. Stogy
    Stogy
    @Wardog it looks and sounds fantastic...as a Hotrod should...and nice balance of shiny here and there just sets the Tone and the Flavour...
    brEad and Wardog like this.
  13. Flathead Youngin'
    Flathead Youngin'
    There's nothing that says hot rod more than a Stromberg...….except two of them......IN CHROME! Dang, man...
    Love that feeling of first fire-up. Grandpa used to say, "We put flexible exhaust pipe on them so you could run it down and up, right into this ear and one for the other ear...."
    Haha, nothing sounds like a flatty...thanks for taking the time to share with us. It's easy to get caught up in the moment and not think about pics or video...
    EDIT: Honestly, you're rolling ch***is is the exact setup/mixture of black and chrome I'm going for this time......intake and carbs too!
  14. Wardog
    Wardog
    @Flathead Youngin' thank you.
    I’m usually very bad for not taking photos or taking them and not posting them.
    I have to make myself do it sometimes so I know I have my own archive to look back on.
    I also hope that this thread might help someone else along with reference or motivation.
  15. Wardog
    Wardog
    Tonight I got my manifold and head nut covers on after setting up a fuel line and moving my carb linkage to clear it.
    626DFE6B-369C-4D1F-AE5C-6A9E75575AE5.jpeg AD7A5BC9-1C2D-4029-A7F0-372BB99CB9D8.jpg
    ct1932ford, 1947knuck, 51box and 5 others like this.
  16. Flathead Youngin'
    Flathead Youngin'
    Share your process, on, for example, the frame. Do you blast, epoxy prime, build layers and block then paint?
  17. Wardog
    Wardog
    @Flathead Youngin' the rear crossmember I stripped with a wire wheel, the centre crossmember I had sand blasted, the front crossmember and rails I sanded externally with a 5” sanding disk on my angle grinder. All the internal was sanded by hand with 180 grit paper. I gave it a couple of sprays with thinners and then hit the bare metal with epoxy enamel. I figured a car built in the 40’s wouldn’t of been filled and blocked. I’m not about fake patina but I also recognise what I’m trying to replicate.
    Feel free to ask any questions of how I do things, sometimes I probably don’t explain things as clearly as I think I do.
  18. Flathead Youngin'
    Flathead Youngin'
  19. Wardog
    Wardog
    bymanr, 1947knuck, Stogy and 4 others like this.
  20. ct1932ford
    ct1932ford
    Looks and Sounds Good!:cool:
  21. Flathead Youngin'
    Flathead Youngin'
    ahhhhhhhh…..I'll sleep better tonight!
    Nope, on my first build I wanted a PM7 and never used one. Thanks to you, now I need to spend more money and find a PM7 AND buy EVERYTHING I need to polish it!.....and the carbs....and the linkages.....you haven't helped a bit!
  22. Wardog
    Wardog
    Haha, Sorry about that.
  23. alchemy
    alchemy
    What was your reasoning for removing the choke plates? I've read thoughts from Stromberg experts that say the air flows better through the carb with the plates in there. Even if they are never used as intended for chokes.
  24. Wardog
    Wardog
    I’ve read the same things. Although the carburettors are new I bought them second hand from a friend and they had no choke plates or shafts in them. I put 1/4” bolts through the bosses with fibre washers on the outsides so when I have air cleaners on I don’t have an unfiltered path below. If I have trouble I might put choke shafts and plates in but I’ll wait and see how they run first.
  25. Wardog
    Wardog
    Anyone who can help please do.
    The barrel in this ignition lock seems to be in great condition..... but I don’t have the key.
    I have some new Hurd key blanks but a locksmith I had look at it wants the barrel out to cut the keys for it. I hoped he could pick it but he didn’t even think he could. The ignition switch is in great condition as well but is locked by the barrel. I’d like to be able to use all of this the way it was intended. Has anyone got a tip for me?
    CE3E70C1-B99E-4118-82B4-00770ADFE90F.jpeg 86DF95BB-D9C3-460A-9713-7441D1EBBE6E.jpeg 3AD448A9-D388-47AC-9872-52706FB5822A.jpeg
  26. If i remember correctly Bruce Lancaster once wrote that the key number was inside on the barrel. I believe that little pinhole is the secret.
  27. Wardog
    Wardog
    Thanks @34 GAZ ill check it out.
    I ***umed that hole would be to remove the barrel if I ever got it to turn.
    1947knuck and Stogy like this.
  28. Stogy
    Stogy
    I think you should try another locksmith. I am under the impression its a one sided key. My Buddys Dad was a Locksmith and used to pick locks with them on occasion. I can't imagine it being to difficult as it's quite primitive...I'd do it for free but it's a 20+hr plane ride...:D I take it you have sprayed lubricant in there to free all the pins and springs and if the lock is free in the hole as in can rotate you should be good
    Once the lock is out you can hand file the key to level the pins and Bobs your Uncle...:confused:...Maybe...:D
  29. Stogy
    Stogy
    @Wardog...
    Not sure what year your column is but heres a couple of threads that may help...
    sorry if this is incorrect to your application...
    https://www.fordbarn.com/forum/showthread.php?t=15585&highlight=Ford+ignition+lock
    :rolleyes:...a post in Fordbarn by the late **** Spadaro...If you Login using your Hamb Login the pics show up...there is a 1/4 in splined pin at least there is in this column...
    http://www.vanpeltsales.com/FH_web/1939ford-project-restoration-10.htm
    :rolleyes:...another tutorial...there is a 1/4 in splined pin at least there is in this column...this fella drilled it right out whereas Spadaro's method shown the pin is drilled tapped bolted and pried out...which is preferable.
  30. Beanscoot
    Beanscoot
    There's lots of cheap lock pick sets on ebay you could also try if you have no competent Locksmith handy.
    brEad and Stogy like this.
