Hot Rods Rich's Coupe - a ten year odyssey
Discussion in 'The Hokey Ass Message Board' started by Rich B., Nov 10, 2019.
  1. Rich B.
    Rich B.
    from Portage,IN
    I ordered 1/8" poly carbonate from Sheffield plastics, this stuff is amazing.
    I could not shatter it with a hammer, and can run it thru my bead roller.
    I meant to form a larger wind screen later, but did not get around to it. I did
    run it thru the step dies so it would but up to the cowel flange. I did use a heat
    gun, but could get by without it.
    brEad, mad mikey, Thor1 and 5 others like this.
  2. Rich B.
    Rich B.
    from Portage,IN
    I did make some wooden bucks to clamp to the main ch***is rails. d25.JPG d24.JPG
    Vic Walter, mad mikey, Thor1 and 5 others like this.
  3. Rich B.
    Rich B.
    from Portage,IN
    Can't have to many clamps. Yes I love machinest spray blueing. It
    This panel is running a 1 1/2" past the firewall as there will be another panel below the headers.
    cktasto, mad mikey, Thor1 and 7 others like this.
  4. Rich B.
    Rich B.
    from Portage,IN
    Wanted to add a few more pics of Cranes history.
    Vic Walter, cktasto, brEad and 9 others like this.
  5. Rich B.
    Rich B.
    from Portage,IN
    I finaly located the hole for the steering, I had fabricated the steering arm previously
    , and adapted the ****erfly steering wheel to the quick release on the sector shaft.
    A water filler was needed at the front of the engine. I had some pipe, and welded
    needed bungs on where needed.
  6. Straight Axle Guy
    Straight Axle Guy
    Rich, I just discovered your post/build, I'm super impressed with your craftsmanship, design and attention to detail. It's thanks to people like you that help me refine my skills and become a better builder. Thank you for sharing, I appreciate it and am enjoying you build.
  7. This picture takes me WAY back. I watched my uncle restore a Chevy pickup like this when I was five. I thought he was crazy for all the parts he had laying all over his house. Now, I'm just like him. Go figure.
    mad mikey, kidcampbell71 and loudbang like this.
  8. Rich B.
    Rich B.
    from Portage,IN
    Thanks so much for the kind words guy's ! It is a labor of love, and learning new
    skills with every build. This will be my last build as health problems are holding me back.
    I have learned a lot on this site over the years and hope to p*** on a little of that here.
    Rich (Scotch you should see my other bedroom ! )
    cktasto, mad mikey, scotty t and 3 others like this.
  9. rd martin
    rd martin
    from indiana
    rich if all of us just pick up a tenth of your skills, we will all be in for a major inprovement! now some dummy i know needs to finish that rail!!!
  10. Rich B.
    Rich B.
    from Portage,IN
    Rear end back in place, and the bottom row of hangers is in place.
    There are 3 fasteners holding this panel on. I Complete the center
    fastener first, than the outer two. the slightest misalignment will cause
  11. Rich B.
    Rich B.
    from Portage,IN
    d33.JPG d34.JPG Mocking up rear panels.
  12. Rich B.
    Rich B.
    from Portage,IN
  13. Rich B.
    Rich B.
    from Portage,IN
    Where two panels join, and roll under car is a real pain to get a good joint.
    Having to bead roll one causes a lot of fussing around for a good fit.
  14. Rich B.
    Rich B.
    from Portage,IN
    This transition from 3 panels joining together came out bettert than I hoped.
    Thor1, mad mikey, scotty t and 2 others like this.
  15. Rich B.
    Rich B.
    from Portage,IN
    I added one of wood bucks to start mockup.
  16. Rich B.
    Rich B.
    from Portage,IN
    I shaped a piece of 1/4' inch plate to use as a buck to form the corner, and pipe for another one.
    cktasto, oldiron 440, Thor1 and 5 others like this.
  17. Rich B.
    Rich B.
    from Portage,IN
    Pipe buck, and finished piece.
  18. Rich B.
    Rich B.
    from Portage,IN
  19. Rich B.
    Rich B.
    from Portage,IN
    Both sides done. The back will be cut straight to match cars of that era, many had no back panel.
    oldiron 440, brEad, Thor1 and 4 others like this.
  20. Rich B.
    Rich B.
    from Portage,IN
    Again I made another buck to fab rear piece.
  21. kidcampbell71
    kidcampbell71
    ^^^^ LOL. Yep ... you are. Glorious isn't it ? I think so. Your own west Texas toy chest. :)
    Rich B. and loudbang like this.
  22. Hahaha. You've seen it, so you definitely know!
    kidcampbell71 likes this.
  23. Rich B.
    Rich B.
    from Portage,IN
    It's hard to see in this pic, but the rear panel is flush with the side panels.
    I welded a piece of tubing to the frame for future push bar. the removable pipe
    stub bottoms against the frame for maximum strength. Yes it is very fussy getting
    that hole in the rear panel dead on !
  24. Rich B.
    Rich B.
    from Portage,IN
    Had last minute change so the option of weed burner headers would clear body panel. d55.JPG d56.JPG
  25. Rich B.
    Rich B.
    from Portage,IN
    jjjjjj
    The owner RD MARTIN , this was taken before the front panel mod.
  26. Rich B.
    Rich B.
    from Portage,IN
    This was a great project, I really enjoyed it, would love to do a chute back car.
    We didn't get every thing done we wanted to, he's moving has to relocate his shop.
    My health will only let me work a few hours a day now, and that time I need to use to finish my Coupe. DSC00915.JPG DSC00917.JPG
  27. You are awesome, man. I want to be like you when I grow up. :)
    Thor1 and Rich B. like this.
  28. sfowler
    sfowler
    all I can say is W O W ! I,ve been working on my 30 roadster highboy for 15 months and am inspired. I can,t get to this level of precision but your car raises the bar for me . thanks much ,STEVE
    Rich B. likes this.
  29. Blues4U
    Blues4U
    from So Cal
    That digger turned out *****in!
    Rich B. and mad mikey like this.
  30. mad mikey
    mad mikey
    Fantastic job. You have incredible skills sir. It is a pleasure to see your work.
