Projects My old coupe might be turning into an A-V8
Discussion in 'Traditional Hot Rods' started by olskool34, Jan 31, 2019.
  1. qzjrd5
    qzjrd5
    from Troy, MI
    Looking good!!
  2. flatheadpete
    flatheadpete
    from Burton, MI
    Man...That's one of my favorite As. Don't screw it up too bad. ;) Lookin' good. Keep up the good work.
  3. jmerson
    jmerson
    Darn, you gave up too soon. A friend of mine here in N. Cal. has been a 4 banger guy his whole live and he's 92 and still works on his projects EVERYDAY. He works mostly in his SHOP, which is his two car garage with carpet on the floor. I've tried to get him to work on a workbench or at least plywood on some sawhorses, but his theory is if you have to get down to the floor and then back up all day, you're going to stay in shape. It works for him so if it ain't broke don't fix it. The good part is he has a 4 banger like no other. All of the machine work has been done by Ray Righetti's machine shop in Stockton,CA. The engine should be on the dyno shortly and they expect 175 HP. This engine has very little left of Henry's engine but if you're interested i can get a print out of what all has been done?
    It's going in a '29 or '30 softop pickup and it is being built for hill climbing. Here in Cal there ia an ***ociation of ardent A hill climbers and my friend Ed Simpson is hopefully going to show them how to climb a hill, you know, like Pikes Peak!!!
    Anyway, i'm enjoying your build and thought you might like to see what some people are doing with A's even as late as 2019?
    Jim
  4. bobbooth
    bobbooth
    from limeyland
    As Chris said , I fitted a 37 21 stud into an A frame but used the entire "K" member from a 33/34, 39 pedals, 33/34 wishbone , F1 box with "A" flange ,modded the oil pump stand and dimpled the firewall to enable removal of the p***enger side head, recored an "A" rad and had extra inlet and outlet fitted , modded a 8BA fan carrier/cut down 37 fan and fitted a H&C mag all in the stock space
  5. olskool34
    olskool34
    CFF8778F-09AB-4EDA-8F2D-34BD0A71595F.jpeg 02E9CB1B-71BC-44BC-8FC7-D4BC3D258A9A.jpeg I building this as if someone did in ‘35-6. Sorta like a prototype if Ford would have came out with the V-8 in the years of the Model A. So far everything is lining up nicely. This is where the engine is going to be so time to make some factory looking mounts.
    v8flat44 likes this.
  6. olskool34
    olskool34
    I did not give up to soon. I drove this car for 10 years with a 4 banger. I do not have the cash to build a full bearing, full pressure oil, counterbalanced 4. Plain and simple. Spend 5k on the 4 or spend 1/8 that in putting in an 85 horse and get me where the 4 would be. Mind made up.
  7. olskool34
    olskool34
    Front mounts are in. Final welding will be done after the engine comes back out. Time to make the rear trans mount/wishbone mount. I am also going to be running anti chatter rods so those have to be incorporated into the mount as well. EC34C1BD-B2FD-42F4-A79F-E25AD7454D9F.jpeg
    Aaron D. likes this.
  8. 97
    97
    I am glad I saved those pics from your build Bob , because now they are just a ****** red X and/or a blur, completely ruins your efforts and spoils the information for future generations........screw photobucket and damn all those who are involved. :mad:
  9. olskool34
    olskool34
    3CC274B8-37B2-4891-B6DC-97A2A6DAD818.jpeg 562C5EF0-4B0B-41F5-8512-8EE0F7396164.jpeg A523E401-F320-469B-A6CA-8E7D5C8D1A6B.jpeg Crossmember and wishball mount done. Fitting the steering now. The box still has to go into the frame rail about an inch so I think it will work.
  10. olskool34
    olskool34
    606C4787-DA78-4C16-80B1-49D306005EE7.jpeg F0BA2351-1135-421C-A22F-E39A96260786.jpeg BB296B74-11FD-4F9D-841A-39286FCCC775.jpeg 2CC6CEA6-21DC-432D-B610-17C01B8A96B5.jpeg I cut the flange off the F-1 box and made a new one that allowed me to square up the box where it was originally. That put the stock headlight switch directly over the ‘32 wishbone. Nothing I could do other than modify the bone to go around it.
