Hot Rods Porta Power? Are They Practical??
Discussion in 'The Hokey Ass Message Board' started by Fortunateson, Dec 10, 2019.
  1. ekimneirbo
    ekimneirbo
    I have one I used to recontour the floor of a truck where the bellhousing and exhaust manifolds were a tight fit. Instead of pounding with a hammer, I just wedged the jack in place and pushed the sides of the trans tunnel/firewall area back. I guess the real point is that if you don't find yourself in a position to need to use one, thats a good thing.
    When that rare time comes that you do need one, its nice to have one.
    j-jock and 427 sleeper like this.
  2. JackdaRabbit
    JackdaRabbit
    from WNC
    I had a 40 gal. water heater that was sitting on a platform 3 ft. off the floor and inspector required a drain pan under it. My HF porta power lifted it (still full of water) 3 inches one side at a time to install the pan. It had flex pipe connections.
  3. jimmy six
    jimmy six
    You run a dirt track car...nuf said
    Rex_A_Lott and bobss396 like this.
  4. Mr48chev
    If you remember you have it you will get a lot of use out of it. I've used the spreader jaws as much as the ram on mine. Last time to work on a crease in a quarter panel where I could stick it between the panel and the edge of the trunk floor to move it back out a bit at a time rather than pull the dent from the outside.
    After I got rear ended in my little box with wheels and shoved into a Johnson barrier I was out here figuring out how to hook a chain to the edge of the trunk opening and jerk the panel out far enough to get the spare out when I remembered that I had my 12 ton taking up space in the garage. It took longer to ***emble the pieces I needed to do the job than to do the job.
  5. gene-koning
    gene-koning
    That is a tool I could have, and probably should have, used many times, but just never bought one. Fact is, I have a couple things I could make use of one, if one was sitting here, right now.
    I've done a lot of moving stuff with a bottle jack and blocks of wood, but having a steel shaft would have made several of those projects a bit faster and probably a lot safer.
    These days I have a friend that has a body shop, so he has a really nice one I can borrow any time, but its across town. Often when I'm working in my shop, I don't feel like running across town.
    Cheapness prevails. If I really need one, I'll plan ahead and borrow my friends Port-a-power. I can use the money saved to buy car parts. Gene
  6. oldiron 440
    oldiron 440
    Have you ever barrowed one twice, then you need your own.
    X-cpe and Algoma56 like this.
  7. Nacifan
    Nacifan
    Check out this restored Porto-Power I saw 2016 Hershey 143.JPG 2016 Hershey 144.JPG at Hershey in 2016. A Blimp Shaped Box
  8. bobss396
    bobss396
    I ran on pavement, yet the PP was handy to fix crash damage. I had a kink in my front hoop where the radiator was tied in, a little heat with the torch and some PP action, things move pretty easily.
  9. big john d
    big john d
    from ma
    my engine hoist uses one it is handy you can have the pump on top of the motor or fender i bought it from an old ford dealer it is a ratonda made by otc
  10. oldiron 440
    oldiron 440
    Bugguts likes this.
  11. Hank37
    Hank37
    When I was a bodyman years ago I used them almost every day . They come in handy to push dents out of tops after a roll over . A must when doing frame work . Be careful if using chains to pull , when they break get outa the way !
    oldiron 440 likes this.
  12. Pete1
    Pete1
    from Wa.
    With a home made adapter, it is one of the safest ways to spread a model A rear spring.
    With a couple of small "U" clips you can even spread reverse eye springs.
    j-jock likes this.
  13. badvolvo
    badvolvo
    The body of my 40 was tweaked pretty badly, floor rusted through, it had a hard life. Doors way off, trunk way off, a few hours with the porta power and things began to come into shape. It's one of those tools that can pay for itself in one use.
  14. thecj3man
    thecj3man
    from TN
    I have used one a few times to move roofs and other panels.
    We use them a lot at work. A few weeks ago we used several cylinders to put 180 tonnes of force on a coal pulverizer we were rebuilding. When the bowl finally broke free of the taper fit, it sounded like a cannon went off.
    j-jock likes this.
  15. Fortunateson
    Fortunateson
    Truckdoctor Andy and raven like this.
  16. tiredford
    tiredford
    from Mo.
    I used mine to stretch a pair of leather shoes that were slightly snug.
  17. Fortunateson
    Fortunateson
    Now there's a really great use! Over the years UV rays have caused some of my clothing to shrink.... All will be put right with the power of "PortaPower"!
    Truckdoctor Andy and X-cpe like this.
  18. vtx1800
    vtx1800
    I've had one since the early 80's and seldom used it. Then the one daughter kept banging her car up and I used it several times to push things back into position. She caved in the right quarter corner once (someone ran into it while I was parked "SURE"), I picked up some used parts and pushed it out enough that the quarter popped out and you could hardly see any damage. When I reskinned the door bottoms on the Studebaker I had them off the car and when I bolted them back on the lower door corner at the B pillar was out an inch or two, I blocked the door at the jamb and wedged the porta power against the floor/wall and after two or three tries I tweaked the door back to a decent fit, I know it wasn't as good as they do on television but it looks fine now:) Mine was made in Taiwan it's so old:)
  19. 2OLD2FAST
    2OLD2FAST
    from illinois
  20. Look for an old push/pull and have it rebuilt. Well worth it.
  21. I have one that is a work alike, it is a small hydraulic jack body with a long adjustable rod and foot plate.
    It was sold as a replacement for car bumper jack, but I have used it for everything but lifting cars.
    Another great tool.
    Bob
  22. tb33anda3rd
    tb33anda3rd
    they should be sold with a box of rags and a bag of speedy dry.
  23. stanlow69
    stanlow69
    I bought one a year ago cheaply at an auction. Spent an hour cleaning it and the box it came in.
  24. Gofannon
    Gofannon
    There's a lot to be said for the original Porter Ferguson Porta Power. There's all kinds of different ways to set them up that most other brands can't do. It's all in the careful design and shaping of the components. e.g. The chain, ram, and extensions can be used to form a pyramid to take the twist out of frames etc. They had a manual back in the day to show you all the different pulls. Ask an old body man. I'm still building up my set, expensive here in NZ.
    j-jock likes this.
  25. Budget36
    Budget36
    Unsure about frames, but they are very useful, bought mine in the early 80's and has pushed a lot of stuff around I don't use it for car stuff only.
  26. Fortunateson
    Fortunateson
    I checked the unit I bought and other brands online and they all look like they came out of th same factory...
    I didn't see any chain components. Is this an optional part or is it supposed to be standard equipment?
  27. I bought inexpensive quick disconnects. That cuts down on the mess, and also speeds up the tool change.
    Bob
  28. Rocky
    Rocky
    Classified Editor
    I used mine to lift my work bench when a socket rolled underneath. Since then is been forgotten, stashed away ina big box under a shelf unit.
    Yes, I had to clean up the drips afterward.
  29. Gofannon
    Gofannon
    Blackhawk made a good set as well. I've never seen one to see how it compares to Porter Ferguson.
  30. Gofannon
    Gofannon
    If it's Chinese or a modern design they generally don't. You can get a "pull ram" which looks useful. I have yet to find cheap ends that fit Porter Ferguson, not interchangeable with other brands.
    I just checked their website and it says P-F has been discontinued. Such a shame to see a great USA product go away due to cheap Chinese rip offs.:( Page is still up "for research" so check out their attachments.
    https://lowellcorp.com/product-category/hydraulics/4-ton-hydraulics/4-ton-hydraulic-attachments/
