Projects Seagrave 531 V12 Special BuiLd Up in Brazil
Discussion in 'Traditional Hot Rods' started by Drmalacarne, Sep 5, 2019.
  1. WC Durant
    WC Durant
    The column drop is beautiful and I like the Excelsior tires. You may have previously mentioned it, what size are the tires?
    Deuces, Stogy, loudbang and 2 others like this.
  2. Drmalacarne
    Drmalacarne
    700/20
    Thanks.
    Enviado do meu iPhone usando H.A.M.B.
  3. { DRMALACARNE } Kool Thread, and thanks for sharing. Gee, how did I miss this? So made some coffee, and started from your first post. I guess that I should to check on here more. :) Keep up the Great Work! I hit the watch thread ****on, so not to miss the rest of it! Thanks again Ron.........
  4. Rolfzoller
    Rolfzoller
    WOW,ABSOLUTELY AWESOME!
    loudbang, Deuces, Stogy and 2 others like this.
  5. Drmalacarne
    Drmalacarne
    We made our own set of friction shocks.
    4 in front and 2 back in the rear.
    We cut a steel plate to act as support for the pedals axle.
    We’ll use the original 1926 Buick brake and clutch pedals.
    And all the mechanical brake system.
    A3FAF206-B22D-4F23-B688-8641A51F1EB5.jpg ECC6CDF5-2C8D-4685-B6E9-663A0A27BEF5.jpg IMG_2616.JPG
    Front brake rod. We’ll use a central support to prevent flexing.
    Here the Seagrave has a lateral power exile to the water pump. We’ll cover it with the steel plate.
  6. ClayMart
    ClayMart
  7. JUNK ROD
    JUNK ROD
    now thats some serious crazy work!!!! Awesome project, ill be following for sure!
    Thanks for sharing!
  8. Blues4U
    Blues4U
    from So Cal
    Chip / Need louvers makes them a lot, he showed how in a build thread, maybe it's the de-uglifying a T Bucket thread.
    Stogy, chryslerfan55 and loudbang like this.
  9. Dean Lowe
    Dean Lowe
    I built my own for my T Speedster.
    Stogy, Deuces, ClayMart and 1 other person like this.
  10. catdad49
    catdad49
    I built a set for the front of my T bucket, but not quite a fancy as these.
  11. ClayMart
    ClayMart
    Woot-Woot! ;) I'll put your name on the list, but I bet it'll be fairly short. :p
    (Add catdad49 to the list. It's doubled in length already! :eek:)
  12. Drmalacarne
    Drmalacarne
    We made the fuel tank from sheets of 304 Stainless Steel.
    It holds 22 gallons of gasoline.
    It will be attached to the frame with straps.
    IMG_2607.JPG 9064A9DA-5579-41D8-A975-0E5F25753E15.jpg B7A7BE37-CC57-4608-A95E-A924E4C2861E.jpg
    And I found this fuel tank cap in Ebath
    We’ll make the holes in the fuel tank for the inlet hose and outlet for the fuel pump, using stainless steel niples.
  13. loudbang
    Do you forge Knives too?
  14. catdad49
    catdad49
    Here's a pic of mine, created from aluminum flat stock.
  15. one would say: what the heck if you're having an accident, slow, but with a bad impact angle. the steering could kill ya, even if you hit the dash, or even the fuel cell will break, you can loose your life in a fire or while flying out of the car because of no belts.
    i say: congrats to a damn fine machine. not to beat. my greatest admiration to your work, keep on, i love to read your thread.
    Cheers, Carsten
    41 GMC K-18, Deuces and Drmalacarne like this.
  16. That 22 gallon tank should be good for about 22 miles with that monster engine.:p
  17. Drmalacarne
    Drmalacarne
    No my friend.
  18. drtrcrV-8
    drtrcrV-8
    What arrangement of internal baffles did you put into the gas tank?
    loudbang and Stogy like this.
  19. Drmalacarne
    Drmalacarne
    We made a central longitudinal vertical internal baffle.
    I believe will be enough to brake the waves.
    Gui.
  20. Never2low
    Never2low
  21. ClayMart
    ClayMart
  22. Drmalacarne
    Drmalacarne
    We took the body off from ch***is to make the steering and fuel line installation.
    Two people can easily handle the whole body.
    And we are studying some variations for the dashboard too.
  23. pumpman
    pumpman
    Great progress, on the dash I'd keep it nice and simple. But I'm sure you will figure out the best solution.
  24. Never2low
    Never2low
    Personally, I like the gauges centered, so they are equally visible to the co-pilot, who would most likely be monitoring them more closely than the driver.
  25. Drmalacarne
    Drmalacarne
    Carburetors air inlets.
    We made some tubes for the exhaust.
    IMG_2608.JPG IMG_2708.JPG IMG_2719.JPG IMG_2720.JPG IMG_2721.JPG 5239fd0b-edb3-40b6-845f-29d45de51ee1.jpg
    Megaphone Pipes.
  26. 41 GMC K-18
    41 GMC K-18
    Simply magnificent! I am sure the sprit of Juan Manual Fangio, is smiling at the amazing progress you are making! Very impressive mi amigo !
    DenK, Stogy, chryslerfan55 and 2 others like this.
  27. j hansen
    j hansen
  28. tubman
    tubman
    Love the exhaust, especially the tips! From my experience, you might be a little disappointed at how quiet it might turn out to be. After I got the two 180 degree turns to bring the exhaust around the front of the engine and then ran it through over two 20 foot lengths of 2 1/4 tubing, it was downright mellow!
    Stogy, chryslerfan55 and Drmalacarne like this.
  29. Drmalacarne
    Drmalacarne
    Thanks!
    I’ll try to post a video with sound soon.
    Gui.
  30. v8flat44
    v8flat44
    Oh man ! The temp in Brazil must be setting record lows because of the COOL this thing resonates !!!
    Just AWESOME! Merry CHRISTmas to you !
