  1. egads
    egads
    Looks like several were built. DSC00041.JPG Does look pretty good.:)
    40two, chryslerfan55, NHRANUT and 5 others like this.
  2. Rootie Kazoootie
    Rootie Kazoootie
    from Colorado
  3. JD Miller
    JD Miller
  4. WQ59B
    WQ59B
  5. WQ59B
    WQ59B
  6. loudbang
  7. loudbang
    1954 Skyliner with options
    The roof has the same treatment
  8. loudbang
  9. loudbang
    Clint
  10. loudbang
  11. loudbang
    I will get you my little pretty. And your dog too.
  12. Mr. Mac
    Mr. Mac
  13. Dodge Polara taillights on that 57 Ford. Easy custom touch in the early sixties. First time I've seen the stock grille bars cut out like that. Not my cup of tea, but custom n eye catching for sure. I've always liked the style of 57 Ford's, just not big fan of Y block compared to Chev small block. Lots of Y blocks had rocker oiling problems. Oil flow went thru hole in cam bearing, as I recall. Small turn of bearing n "tick tick tick" no oil to rockers. ALL the parts houses sold overhead oiler kits for them. Put a br*** t-block where oil pressure line came out of engine, then route two small copper lines up to valve covers. One line went under each valve cover n sprayed oil over whole rocker. Problem solved. With that said, I do have a Y block I intend to use to convert my 56 F100 panel truck to V8 someday.
    1 more car I promise, Rex Winter
    Dry n windy Lubbock TX
  14. The37Kid
    The37Kid
    [​IMG]That is an Hispano Suiza V8 WWI airplane engine. They were dirt cheap war surplus and found their way into race cars, dirt track and some early drag cars. Bob
  15. indyrjc
    indyrjc
    from Indiana
    I don't really recognize this driver, Rootie. Just a wild guess but could that be George Morris in the Hook Lobster roadster?
    Thanks!
    chryslerfan55 and Speedwrench like this.
  16. Jim Nise
    Jim Nise
    What I find unusual, Indyrjc, is the front suspension. There are 2 brackets for tube shocks, but no visible use. Looks like a watson but can't find anything about the car. (1963 I believe) It is not in the Watson book.
    Speedwrench likes this.
  17. indyrjc
    indyrjc
    from Indiana
    I do see what I think is a right front shock angled from the axle to the inside of the frame. Someone must have been experimenting with the unused brackets that you noticed.
  18. Rootie Kazoootie
    Rootie Kazoootie
    from Colorado
    Can't say for sure who's driving but it is the Hook Lobster car.
  19. lowcad61
    lowcad61
    from 18947
    chryslerfan55, loudbang and HEMIDAV like this.
  20. JD Miller
    JD Miller
  21. JD Miller
    JD Miller
    [​IMG] [​IMG]Huntington beach [​IMG]
  22. junkyardjeff
    junkyardjeff
    The Chevy stovebolt sixes also had rocker arm oiling issues,I had to get creative on a freshly rebuilt 235 to get oil to the rockers and while removing valve cover studs from a 53 216 in a local junkyard it had a external oil system going to the head,like with most Y blocks it was lack of oil changes causing the problem and that 216 was nasty.
  23. JD Miller
    JD Miller
  24. HEMIDAV
    HEMIDAV
    from FL.
  25. HEMIDAV
    HEMIDAV
    from FL.
  26. HEMIDAV
    HEMIDAV
    from FL.
  27. HEMIDAV
    HEMIDAV
    from FL.
  28. HEMIDAV
    HEMIDAV
    from FL.
    The Big C near the big E W. Springfield 3 1 5.jpg , MA
    Lil32, chryslerfan55, DenK and 6 others like this.
  29. HEMIDAV
    HEMIDAV
    from FL.
  30. HEMIDAV
    HEMIDAV
    from FL.
