Projects 61 Falcon V8 Headers
Discussion in 'The Hokey Ass Message Board' started by koepsel, Dec 12, 2019.
  1. koepsel
    koepsel
    I'm building a g***er type 61 Falcon. I've searched the web and this forum for fenderwell headers for a SBF 289. Haven't found a pair yet. I've tried 65-66 Mustang ch***is headers but they wont work. Cylinders 7-8 are very close to steering box. Anyone have some info on this swap?
    loudbang and catdad49 like this.
  2. catdad49
    catdad49
    Quite a few Falcons running with the Southeast G***ers or their Texas group, you could ask them.
    loudbang and koepsel like this.
  3. LM14
    LM14
    from Iowa
    Buy a sprint car header kit from Speedway and build your own.
    SPark
    loudbang, Gammz, raven and 3 others like this.
  4. oldiron 440
    oldiron 440
    Any ch***is headers you will find will be small tube , if you need 1 3/4" build your own.
  5. loveoftiki
    loveoftiki
    from Livonia,Mi
    Gonna have to build em...All Falcons **** for header applications...as you’ve discovered your steering box will taunt you.
    loudbang, Gammz and koepsel like this.
  6. raven
    raven
    Like people have said before, build your own. That way you know they will fit.
    r
  7. koepsel
    koepsel
    I agree. I have a chevy SBC sitting in it now with Chevy II headers just to see if it works better. Still would have a problem with pan sump clearance. Might have to change it to front steer or get a front sump Chevy II pan. I have a 289/C4 setup. Wanted to be brand correct but, not sure what to do. LOL
    Deuces likes this.
  8. oldiron 440
    oldiron 440
    Well there goes the nice car comment from me...:)
    loudbang, Deuces and koepsel like this.
  9. RmK57
    RmK57
    My engine choice sure wouldn't be decided on a set of rusty headers. Build your own from a kit.
  10. koepsel
    koepsel
    I have a 66 289 and a d4 code C4. I'm undecided on what to do.
    loudbang, Deuces and oldiron 440 like this.
  11. Uh, easy question to answer: put the Small Block Chevrolet in it and go fast!
    B Bay Barn likes this.
  12. RmK57
    RmK57
    Put a Cleveland in it and go mucho faster.....!
  13. GordonC
    GordonC
    Put the Chevy in the corner of the garage for a future project and the 289 in the falcon. Simple...
    loudbang and Deuces like this.
  14. DDDenny
    That's a pretty sizeable tube for a 289........unless it's a pretty "snotty" one.
  15. oldiron 440
    oldiron 440
    Well ....yeah:)
  16. Not sure about fenderwell headers but FPA(Ford Powertrain Applications) had a set of long tubes that fit snug & right in my o/t Falcon.
    Easy to deal with.
    Might want to check out Crites too.
    Really like where you're going with the old bird!
  17. I vote for the Ford drive train but I think that little car needs a third pedal.
    Again, cool car, wish it was in my garage!
    Ps. The C4 will take a lot of **** depending on how much Hp you plan to throw at it & how sticky your back tires are.
  18. Deuces
    Deuces
    I wonder if a set of stock Fox body headers would work...???.....
  19. koepsel
    koepsel
    I'll check those out. I don't mind building a set but, I can't TIG so I'd have to farm out welding.
    The fox body headers dump right at the steering box. No go. :(
  20. koepsel
    koepsel
    The 289 does look at home in there. :)
  21. Deuces
    Deuces
    Drats!.... :(
  22. koepsel
    koepsel
    You use the Tri-Y? What year Falcon?
  23. RmK57
    RmK57
    The easiest way would be to use the Mustang ch***is headers and redo the 7-8 tubes if those are the only ones that give you fitment problems. Wouldn't be as cool looking as a set of custom fender wells though.
  24. koepsel
    koepsel
    That is a thought!. Going to pull the SBC today and put the SBF back in. I'll do some more checking.
    oldiron 440 and loudbang like this.
  25. DDDenny
    This sbc guy thinks this is a wise decision.
    I knew a guy in the early 70's, that had a plain green 61 Falcon sedan with black steel wheels, he built a "killer" 221/T-10 4 speed and 9 inch rear, boy, what a sleeper, ****ed in a lot of "hey, ya want to run it" types.
    koepsel likes this.
  26. JeffB2
    JeffB2
    from Phoenix,AZ
    Probably not,they wouldn't clear in a '54 Ford car 302 swap they were up against the a-arm on the p***enger side and too close to the steering box on the drivers side but those will clear in a 1949-52 car swap. The HEDMAN 88400's will work in 1949-59 Ford cars with a 302. (small 1.5" primaries) A while back a guy used SBC fenderwells by removing the flanges and tweaking SBF flanges to fit them.
  27. loveoftiki
    loveoftiki
    from Livonia,Mi
    nope.....I’ve got Dougs...which are supposed to be the top of the line for fit and finish...I’ve gotten as far as getting every bolt on the hole and finger tight...Falcon engine compartments are narrower than a Mustang...man I wish I had smaller hands and arms...
  28. loveoftiki
    loveoftiki
    from Livonia,Mi
    Well....didn’t even notice....it’s a G***er....you got plenty of room to fab something up...man getting old ****s
  29. LM14
    LM14
    from Iowa
    This would be the easiest set of headers to build. Don't be afraid to order the Speedway sprint car headers and make some.
    Another easy option would be to cut the flange off the Chevy fenderwells, bolt a set of Ford flanges to the heads and make the Chevys fit.
    With all that room to work this would be extremely easy.
    SPark
  30. RmK57
    RmK57
    The port spacing is quite a bit different from Ford to Chevy, you would to spread the two center tubes out a couple inches to adapt to the Ford flange.. I've done that trick with chevy to y-block headers though.
