Hot Rods Rich's Coupe - a ten year odyssey
Discussion in 'The Hokey Ass Message Board' started by Rich B., Nov 10, 2019.
  1. rd martin
    rd martin
    from indiana
    i will tell you that the body for the digger, like richs coupe , turned out dead nuts! i wish we could do that chute pack car! its always a pleasure to see rich work the metal magic! rich has helped out alot of people over the years. thank you bud.
    Blues4U, loudbang, Thor1 and 3 others like this.
  2. Rich B.
    Rich B.
    from Portage,IN
    Thanks again guy's for the comments, they are appriciated. Now back to our
    regular programing. As I mentioned these pics may be out of order, as photo
    Bucket deleted whole pages of pics because of their lousy soft ware.
    Rich
  3. Rich B.
    Rich B.
    from Portage,IN
    DSC01288.JPG This photo shows the aprons located with two scratch awls , I had drilled
    two 1/8" holes for locating them in exact position for alignment with
    fenders. Once body is on frame it's very difficult to adjust them.
    The scratch awls I use are the best I've found, and are used in most sheet metal shops.
    https://www.amazon.com/Malco-A0-Made-Regular-Scratch/dp/B003NFCQSI
    I buy several at a time, and use them like cleeco's.
    Vic Walter, GordonC, Thor1 and 3 others like this.
  4. Rich B.
    Rich B.
    from Portage,IN
    Some pics showing the start of paint process. Every thing gets epoxy primer as
    first coat. I have even used filler over it now, and given up on etching primer.
  5. Rich B.
    Rich B.
    from Portage,IN
    After metal working I epoxy prime, block sand, use filler if needed, then use a
    urathane primer to finish blocking with. The sanding never ends !!
  6. Rich B.
    Rich B.
    from Portage,IN
    Fender prep on the above pics was at a friends shop, I was running out of room.
    Shadow Creek, GordonC, Thor1 and 3 others like this.
  7. Rich B.
    Rich B.
    from Portage,IN
    I built stands for the fenders to make it easier to work on.
  8. Rich B.
    Rich B.
    from Portage,IN
    The gas tank had to be reshot, burned thru buffing. Fenders came out nice.
  9. Rich B.
    Rich B.
    from Portage,IN
    IMG_0836.JPG I did not want rocks causing star chips in the paint. I looked at a lot of options, and
    decided on a local shop that lines truck beds for most of the new car dealers. It
    cost about the same as a pick up bed. They spray this liner at high temp, and it
    sets up in 3 minutes. They imbed wires in to make the cuts. They were great to work
    with and did a great job. IMG_0835.JPG IMG_0840.JPG IMG_0842.JPG IMG_0849.JPG
  10. Rich B.
    Rich B.
    from Portage,IN
    Vic Walter, Lil'Alb, GordonC and 6 others like this.
  11. HotrodHR
    HotrodHR
    Beautiful work... the interior panel details are too nice to cover with upholstery!
  12. loudbang
    Bedliner under the fenders looks GREAT.
    kidcampbell71 likes this.
  13. Rich B.
    Rich B.
    from Portage,IN
    HotrodHR : Just the seat will be done, with rubber diamond plate pattern floor.
    Loudbang: the heaviest fenders around! Thanks
    for all the great pics you post!
    Rich
  14. HotrodHR
    HotrodHR
    What's the current color of the interior panels? It looks like a primer that you might seeused in military vehicles or aircraft. The fenders look like a retro grey/green on my iPad... very cool.
    scotty t and loudbang like this.
  15. Rich B.
    Rich B.
    from Portage,IN
    I found a bunch of exhaust pics so there going up next. There is very little
    room around the rear axle, and with the 32 tank I'll take the easy way out.
    they will dump out by the rear wheels. I'm using the heavier 16 gauge
    304 stainles. (of course I am) I found a couple flanges on line, and shaped
    them to fit. It is 2 1/4" near the manifolds, than I ran the rest in 2 1/2".
    I had mocked the position of the exhaust by the tire when I had the fenders on.
  16. Rich B.
    Rich B.
    from Portage,IN
    The route wasn't to bad only had miter a few fittings. I used the
    popular insulated hangers to help with vibration. DSC01282.JPG DSC01287.JPG DSC01284.JPG DSC01289.JPG DSC01297.JPG
    Vic Walter, brEad, Thor1 and 5 others like this.
  17. Rich B.
    Rich B.
    from Portage,IN
    The finished route worked great. The only problem was the neighbors, and
    the noise. The gl*** packs were even too loud for me. I looked at a lot of mufflers
    trying to find one that would fit in the small space available. Chose these Magnaflows.
    Vic Walter, brEad, Thor1 and 4 others like this.
  18. Rich B.
    Rich B.
    from Portage,IN
    HotrodHR :
    I first painted them black to match the seat. Too
    much black, couldn’t see them. I went ahead,
    sanded them all, and shot them body color. Very
    happy with them now. I left all window moldings
    Black, along with the dash.
    Rich
    kidcampbell71, scotty t and loudbang like this.
  19. nunattax
    nunattax
    2" is plenty .looking good
  20. nunattax
    nunattax
    way to go bud
  21. nunattax
    nunattax
  22. Rich B.
    Rich B.
    from Portage,IN
    Yes I used stainless Philip head screws I got
    from McMaster Carr. I wanted to always have
    the option of taking things apart if a problem
    arises in the future.
    Rich
    loudbang, nunattax and kidcampbell71 like this.
  23. scotti32
    scotti32
    Awesome build, lots of great ideas.
  24. Rich B.
    Rich B.
    from Portage,IN
    Running out of time, but determined to finish
    Coupe build. Spent another week in hospital
    with pneumonia, third year in a row. I’ve had
    the shot , but advanced COPD can’t withstand
    any infection.
    I have to use my little roll around stool to do any
    work. I’m on oxygen 24/7 of course. Have run
    Oxygen line to the shop from the concentrator in
    The house. No bottles to worry about, but can’t have any sparks!
    I have done all work up till now including all prep
    work, sanding, primmer, and blocking. Got half way
    through the finish top coats, and had a friend finish
    since the paint mask restricted my breathing to
    much. He had never finish painted before, but I
    guided him through it. He’s shot a lot of primer
    before, and we put 4 coats on.
    I did all the color sanding, and he did all the
    buffing. With out his help I couldn’t have
    finished it.
    I had always planned on single stage paint as it
    is ‘garage’ painter friendly. I think it also reflects
    a more traditional look. I looked a long time trying
    to find the right color gray. I got a old 60’s color
    chip book, and found It there. It’s the old slate gray
    found on early Porsche’s. No metallic of course, and
    I’ve had a lot of good reactions from it.
    Rich
    brEad, Thor1, TagMan and 4 others like this.
  25. Rich B.
    Rich B.
    from Portage,IN
    Here's a few paint pics:
    AndersF, GordonC, OFT and 1 other person like this.
  26. Rich B.
    Rich B.
    from Portage,IN
  27. Rich B.
    Rich B.
    from Portage,IN
  28. loudbang
    WOW just WOW. You are creating a masterpiece without letting your health problems effect your skills. My hat is off to you sir. Working all that metal with your limitations is quite a feat. Nothing in your work provided any clues that you were working under such conditions.
    Desoto291Hemi, brEad, Blues4U and 4 others like this.
  29. jeepster
    jeepster
    from wisconsin
    Thanks for sharing your journey with this car. Beautiful work!
    greaser and loudbang like this.
  30. Rocky72
    Rocky72
    from Pa.
    Rich , not only do you do beautiful work but the fact that you don't let your health slow you down is very impressive .
    loudbang, kidcampbell71 and greaser like this.
