Projects Order of events - building a model A Hot Rod
Discussion in 'Traditional Hot Rods' started by cederholm, Jun 28, 2018.
  1. Mike Colemire
    Mike Colemire
    Ron that is a good looking sedan. I would go with building another ch***is also. You could enjoy your hot rod and when you do switch over as was said you could sell whatever you have left. If I had it to do over, I'd of bought a semi restored car and built mine. You don't run into as much screwed up **** that way.
  2. AmishMike
    AmishMike
    Not a Flathead guy but love & follow lot of old builds. Surprised no one warned about weight of Flathead on engine stand. Have seen that warning on number of sites. Will be following your build love it
  3. Ron Brown
    Ron Brown
    Thanks Mike...it’s a good running good handling rust free car...great specimen to work with for sure.
  4. cederholm
    cederholm
    Well it's been a while since I posted - I'm really not good at this posting stuff so this wont be much of a build thread but I'll try.
    So, what have I been doing? A) driving the snot out my car B) building my 8BA.
    The 8BA
    Based on strong recommendations from members of FordBarn, I settled on Gary of the Engine Shop on Long Island and boy am I happy I did. Gary, who goes by GOFAST on FordBarn is a top notch machinist that specializes in flatmotors. He took my old block that I had had for years sitting in a shed and gave it a perfect bill of health after a thorough inspection/testing. The he performed the machining and provided me with a "kit" off all the parts that he has learned worked well together. I have to say his and ***embled "kit" was extremely well labeled and organized. All machined parts were labeled with their new specs and everything was packaged with the mind toward ***embly. Here are the details.
    - cylinders bored to 3.2245
    - Isky Max 1 cam
    - Eagle 4" crank
    - Ross pistons
    - **** rods
    - Isky springs
    - Johnson style lifters
    - Offy heads
    - ARP main studs & nuts
    Here are some pics.
    Note - the "ticks" on the valves were my way of keeping track of the adjustment. One tick means its the one I'm working on, the second means I'm finished.
    And here is a glam photo from me cruising around NYC.
    ~ Carl
    slim38 likes this.
  5. cederholm
    cederholm
    One thing that might be helpful to someone was my method for installing the valves. Since Gary machines the bottom of the valve guides to accept a lower seal, the stock lip is removed from the guide. This makes the pickle fork method of installing the valve ***embly useless. Instead I bought a cheap as hell spring compressor for the exhausts and made a tool from a Harbor Freight tire iron. The spring compressor was finicky but worked, the other tool was amazing! I took the tire iron and bent the tip. By placing this in the intake opening and pressing the valve guide down, you can add/remove the retainer with ease. Here are a couple pics.
    ~ Carl
    Note the very tip of the iron
    And this compressor was such a POS I'm amazed it worked.
  6. cederholm
    cederholm
    Last updated.
    I had posted in the wanted section that I was on the hunt for a transmission - preferably a local. Lots of guys responded which I really appreciate, but Randy (Flat Power) came through with a really nice '39 and he's just over the bridge from me in NJ. My son and I made the trip to his place yesterday and really enjoyed learning from a hot rodder with generations of hot rod knowledge behind him. We also go to look at his father's and uncle's projects. Impressive is an understatement.
    In addition to the transmission we also walked away with other goodies that I'll need.
    ...I know you like pics.
    ~ Carl
    patzfab and slim38 like this.
  7. Chopp'd49
    Chopp'd49
    Question for the group, do any of the battery box / master cylinder mounts for a banger give you a dual reservoir master cylinder?
    I converted my stock A roadster to a T5 trans with a banger. Built a tidy little box for a skinny battery (6 volt optima currently - group 51 12 volt should fit also)
    here’s some pics. 6308683F-1F59-48A0-A273-DC54AA468A6F.jpeg 05D57284-3DF3-49A9-B505-B7943A741214.jpeg 201119FB-39D1-4833-8F37-3A5DEC81BD26.jpeg 0B71577F-C61C-4564-B800-D45622198731.jpeg
    metalhead140, Aaron D. and cederholm like this.
