Hot Rods 29 RPU- "Street/Strip" B/SR Build - Marty Strode
Discussion in 'The Hokey Ass Message Board' started by Marty Strode, Dec 19, 2019.
  1. Johnny99
    Johnny99
    A wee bit of inspiration! This will be fun to watch.
  2. 31Apickup
    31Apickup
    Look forward to this build, plus your workmanship is incredible.
    Stogy and loudbang like this.
  3. Marty Strode
    Marty Strode
    Today I got the rear frame section squared and tack welded in place. After tack welding the front engine mounts in, I have a 327 block, along with a Mcleod scattershield dug out and plan to install the engine/trans combo tomorrow. IMG_3716.JPG IMG_3717.JPG IMG_3719.JPG IMG_3721.JPG
  4. Blues4U
    Blues4U
    from So Cal
    Oh, I'm in for this ride! Thanks for starting the thread Marty!
  5. The thing is Marty, the wood in the bed rails sits on the frame rails. What happens at the kick up?
  6. I'm in for a technical drag car build with time slips, yes sir !
  7. loudbang
    Going along for the wild ride. I really like your build threads.
    cruiserjohn76, 1947knuck and Stogy like this.
  8. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Marty,
    That's a TruTrac style. Could have been made by a variety of manufacturers. Are there any markings anywhere on it?
    A Torsen Gleason looks like this:
  9. My gosh!! Came here linked by my friend @elgringo71... I'm suscribed! Thanks for sharing this build thread... We always talked with him about all the talented guys over The Hamb. Wish I had some speed/performance drag parts down here in Argentina!!! Don't cry for me Argentina[emoji16]
    Going further with the rear axle theme... I read.. back in the day 1 1/2 ton truck would be useful to build a drag banjo.
    Sent from my Mi A1 using The H.A.M.B. mobile app
  10. bowie
    bowie
    I think it’s a 3/4 ton unit, that was used.
    Robert J. Palmer, Stogy and loudbang like this.
  11. elgringo71
    elgringo71
    I’m really looking forward to seeing this Pickup come together. It’s obvious that you have been collecting parts for a while and the build style is my favorite. I always liked Don Lowe’s Pickup. It’s a perfect combination of show and go.
  12. Marty Strode
    Marty Strode
    I think you mean Dean Lowe !
  13. elgringo71
    elgringo71
    @Marty Strode
    Yes I Do, sometimes auto correct and small letters on a cellphone are not your friend.
  14. john potter
    john potter
    Hey Marty- This is going to be Good. I will bring you some flap disc's.
  15. Marty Strode
    Marty Strode
    Dean,
    From the bottom of the wood floor, to the bottom of the wood that sits on the frame rails, the measurement is 4-1/2". That should allow 1/2" gap over the top of the rail extensions. I hope I am not missing something. IMG_3728.JPG IMG_3734.JPG
  16. Marty Strode
    Marty Strode
    Today,
    I was able to couple up the engine block to the transmission, and add a few goodies for inspiration. The last time I shifted that 4-speed was in the white Boss 302 powered roadster shown, 1975 ! IMG_3726.JPG IMG_3730.JPG IMG_3733.JPG 2012-08-22 110155.jpg
  17. If you measured it, I'm sure the bed wood will be fine Marty.
    Love those Hilborns on an RPU!!
  18. Marty Strode
    Marty Strode
    Bowie is correct, the basis for Championship quickchange rears evolved from the 3/4 ton Timken truck axle that was used in 1939 and up Fords and Studebakers. The wide 5 hubs (Shown) were 39-41 Ford as near as I know. P1010156.JPG
  19. Marty Strode
    Marty Strode
    Dean, your injector stacks look like 6", mine are 10", I will be looking for some 6's or 8's. Do you have any closeup shots showing the pocket in your firewall to clear the mag ?
  20. Thanks for the education Marty... The wide five wheels were 18" tall in trucks?
    chryslerfan55, loudbang and Stogy like this.
  21. Stogy
    Stogy
    Wowie another early gift before Ho Ho Ho...thanks for sharing this...another front row seat Hamb adventure...Ho Yeah
    kiwijeff, kidcampbell71 and loudbang like this.
  22. This is the best shot of the firewall I have Marty.
  23. loudbang
    A bit BIGGER :)
  24. alanp561
    alanp561
    Really like how you're getting started but I've got a question. Looking at the pic of the rear ends hanging on the wall, how are the spring perches attached? I can't get in close enough to see it. Are they welded directly to the axle tubes?
    Alan
    chryslerfan55, Stogy and loudbang like this.
  25. j hansen
    j hansen
    Ohhh,I like this.Subscribed.I got my beers and snacks ready! Skärmavbild 2019-12-23 kl. 14.09.08.png
  26. Tim
    Tim
    from KCMO
    I see it often on Instagram so I’m sure the current owner would be easy enough to get ahold of if you really wanted a good look. I’d snoop further but I’m off IG and Facebook for a while. Hope the videos are helpful
  27. Marty Strode
    Marty Strode
    Alan,
    The housings are '37-'40 with the stock spring hanger in place. I wanted to retain the spring stretch of v-8 rear axle. The width of a v-8 banjo is 3-3/4" vs 4-3/8" for the Championship, and the thickness of the side plate adapters is 1-1/4. My old friend Lonnie Gilbertson narrowed each housing 1-9/16" to compensate for the width, and pruned off the bearing snouts to fit the bolt on floater spindles. Thanks for your interest. IMG_3738.JPG
  28. Marty Strode
    Marty Strode
    Bruce, The only markings I found were engraved on the center barrel, LG333R, I know the L &R designate right and left. Is a TruTrac similar to a Dan Press Gold Trac ? BTW, did you notice you and Swade41 share the same Avatar, hard to miss ! IMG_3739.JPG
  29. Hello Marty ! Hello Dean !
    ... & hello to everyone else !!
    What a present this is ... for us here. Love it, of course. :)
    Merry HAMB-mas !!
    Happy HAMB-akuh !!
    HAMB-zaa !!
    brad2v, swade41, oldiron 440 and 3 others like this.
