Hot Rods 1936 Plymouth window channel
Discussion in 'The Hokey Ass Message Board' started by Greg Rose, Dec 20, 2019.
  1. Greg Rose
    Greg Rose
    Hi! I am almost done with my 1936 Plymouth coupe but am having trouble with the door gl*** channel. Does anyone know how the felt channel is attached inside the door, as I role the gl*** up it goes straight till it gets to the end of the regulator travel then it moves forward about an inch leaving the channel just hanging by itself. There is two clips built into the door but they don't hold the channel were it needs to be, when I got the car it was a shell with nothing in the doors, I have regulators and the felt channel but cannot get everything to line up, its like something is missing? Any Ideas? Thank you!
  2. Paul
    Paul
    Editor
    There should be a deep felt line channel at the rear from sill up, that holds the gl*** in alignment as it moves forward and back
  3. Greg Rose
    Greg Rose
    Hi, what I got from mopar direct is a 1/2" deep felt lined channel that is eight feet long, fits nice around the gl*** but only fits snug in the lower part of the door where there is a 12" or so metal channel, it then runs up the inside the door frame across the top of the window and back down the front of the door frame, when you roll the window up it comes out of the channel at the rear and goes in the channel at the front, how do I make the rear part stay with the gl***? Thanks for your reply!
  4. Paul
    Paul
    Editor
    There must be someone here that can share a picture of the channel, I think it was mohair lined not felt. There were also short rubber guides at the sill where a modern car would have a full length sweep.
  5. Paul
    Paul
    Editor
    Unfortunately I no longer have a car or parts to show but they were the same system on both my '35 Dodge and '36 Plymouth, probably same on Chryslers and Desotos of the same years.
  6. mgtstumpy
    mgtstumpy
    Here's a 41, it may be similar?
  7. Paul
    Paul
    Editor
    Nope not even close. The '35-'36 has no wing window and like the OP said the gl*** rolls all the way up leaving a slot open at the front, keep cranking and the gl*** moves forward to close the gap at front
  8. Greg Rose
    Greg Rose
    Ok, on the lower front channel it is about three inches deep with a felt lining that hooks into the door like a 36 ford, so do you think I should cut the narrow channel off at the top of the door and make a wide piece as in the front see very crude picture? Thank you everyone for your responses, if anyone comes across a picture of an original please post it. Untitled.png
  9. BobPer
    BobPer
    As I remember, I used 35-37 Ford truck channels. The back channel is deep so when the window reaches the top and then slides forward, it is still contained and supported.
    Hope that helps, Bob
  10. Greg Rose
    Greg Rose
    Thank you very much!!!
  11. BobPer
    BobPer
    Greg, Here are their instructions:
    You will still have to cut and adjust to fit, but it gets you about 95% there.
    If you need anything else, ask away. Bob
  12. Greg Rose
    Greg Rose
    Thank you, I found some of these on ebay after Christmas I will get one.
