Projects Mild custom '51 Pontiac Chieftain
Discussion in 'The Hokey Ass Message Board' started by PhilA, Nov 4, 2019.
  1. Johnboy34
    Johnboy34
    from Seattle,Wa
  2. PhilA
    PhilA
    California Pontiac Restoration have aftermarket stainless ones for $15.25 a pop- that's the best price I've found so far. Research continues!
    Phil
  3. PhilA
    PhilA
  4. Lloyd's paint & glass
    Get in the zone Doc!
    Woogeroo, loudbang and PhilA like this.
  5. PhilA
    PhilA
    Oh, may have spoken too soon, that appears to be a cross reference snafu.
    VE938 H0415 is what this has stamped on it.
    Phil
    Edit: Seems like the price is $15-18 on average
    mrspeedyt, chryslerfan55 and loudbang like this.
  6. vtwhead
    vtwhead
    Phil, perhaps a post over on the AACA forum in the Pontiac section would find a source for those valves that could help with the pricing and availability.
  7. PhilA
    PhilA
    Yeah, it was they who put me in the direction of CPR.
    Phil
    mrspeedyt and loudbang like this.
  8. PhilA
    PhilA
    Started pulling valves out today. That's no. 6 exhaust valve, exactly as it was removed. Basically just grimy.
    Continued pulling the exhaust valves out.
    One of the adjusters has been overtightened and the threads are bad. I may try to get a replacement.
    The followers are good though. They just need a clean.
    Finished up pulling out and cleaning up all the valves I could without rotating the crank.
    All of them are straight and clean apart from no. 7 exhaust so that one will be replaced, the rest ground back in and replaced. That should hopefully see an improvement.
    --Phil
    mrspeedyt, Okie Pete, brEad and 3 others like this.
  9. Lloyd's paint & glass
    Awesome doc! I await the post of your celebration dance :D
  10. Ford52PU
    Ford52PU
    from PA
    love reading this thread. Such detail is impressive and very helpful. Thanks for sharing.
  11. PhilA
    PhilA
    Not too much though. 3 hours in the cold spinning dirty valves in a twist drill is hardly entertainment!
  12. Lloyd's paint & glass
    But i bet you was the only man in Louisiana doing the valves on a 51 Pontiac today! Who else can say they did that?
  13. PhilA
    PhilA
    That there is quite likely!
  14. Lloyd's paint & glass
    In this case it's the destination brother.
  15. PhilA
    PhilA
    That there is the aim.
    It'll be done when it's done- hopefully well enough that I can enjoy it. I'm so used to having cars that fight every step of the way...
  16. Lloyd's paint & glass
    Kinda like wrestling a greasy pig ain't it? Just hang in there, you're about to whip that pigs hind end ;)
    PhilA likes this.
  17. vtwhead
    vtwhead
    On a note of levity Phil perhaps you can define "in the cold" to this Old Vermonter:D
  18. PhilA
    PhilA
    47 with rain.
    Cold enough. Consider that on Monday it was 79, Tuesday 36 and it warmed up a little then got windy and rained so the wind has that Chicago feel that goes right through you.
    It's not about the numbers, is about the difference in such a short time.
    Phil
  19. vtwhead
    vtwhead
    I can agree for sure. Been installing two garage doors on the new garage this week -8 then 0 followed by 20 and now that I have them installed it is 32, tomorrow to be 48. I would have waited but seems the two resident neighborhood cats like to do their business inside the new garage for some reason not to mention walking all over the wifes new OT car.
  20. bchctybob
    bchctybob
    Ha, ha, that’s why I always work with the doors shut, the neighbors cat gets in and hides. Damned things.
    You know Phil it’s a good feeling when you are out driving your Pontiac, knowing you’ve had your own meticulous hands on a lot of it. Good old piece of mind. I’m glad you didn’t need a full set of valves but if it makes you feel any better, a friend of mine just spent $700+ on a set of valve springs for his oddball project. These things can get expensive!
  21. PhilA
    PhilA
    All the valves out and cleaned. Made a start on cleaning the collets, spring housings and the top and base plates. Got fed up of having my hands in gasoline after 2 valves worth.
    Enough for today. Thinking very hard about getting an ultrasonic bath.
    Phil
  22. PhilA
    PhilA
    In a sudden bout of creativity, I ***embled a piece of fairly worn 220 grit abrasive paper into a piece of poplar dowel.
    Fits nicely into the guide; spun round a little like a hone it appears to have cleared any rust or debris.
    I need a small bottle brush and a can of carburetor cleaner to finish up, I think.
    Phil
  23. PhilA
    PhilA
    Hot water and Pine-Sol.
    I guess we'll see what has happened to that in a little while.
    Phil
  24. Lloyd's paint & glass
    Lol does she know you took her pyrex baking dish
    osage orange, loudbang and PhilA like this.
  25. PhilA
    PhilA
    I haven't started using the dishwasher to clean engine parts yet so we're still good
    Phil
  26. Lloyd's paint & glass
    But it's a great idea lol. Did you get your new valve ordered?
  27. PhilA
    PhilA
    No, not yet.
    I had wanted to pull all the valves first and check I didn't need more than one before ordering anything. I didn't finish that until today so it'll be whenever everywhere is open again.
    Phil
  28. vtwhead
    vtwhead
    Phil, from experience I have noticed that the Cascade dish washer soap has the tendency to remove almost everything to a fault. It etched our copper based sauce pans so badly that Cascade bought us new ones! Might give that a test just to see the results:rolleyes:
  29. loudbang
    Or a rifle bore cleaner brush and patches. Got any neighbors that hunt?
    Woogeroo, Hombre and chryslerfan55 like this.
  30. PhilA
    PhilA
    Ooh, good point. Hadn't thought of barrel cleaning tools.
    Phil
