Projects 26 T Roadster Pick Up build Thread
Discussion in 'The Hokey Ass Message Board' started by Blue One, Mar 27, 2010.
  1. DDDenny
    Wow, that turned out nice Larry.
    That deserves the Hannibal Smith award.
    "I love it when a plan comes together"
    brEad and Blue One like this.
  2. bobbytnm
    bobbytnm
    Wow
    That is jut****s!! Nicely done....as usual
    Bobby
    loudbang and Blue One like this.
  3. 26 T Ford RPU
    26 T Ford RPU
    Or should it be "i love it when a Pan comes together":rolleyes:. Slick job, Larry....but what else can we expect from you.:cool: :D:D JW
    Atwater Mike, brEad, Blues4U and 4 others like this.
  4. loudbang
    NICE WORK as expected. :)
    1947knuck, 26 T Ford RPU and Blue One like this.
  5. Blue One
    Blue One
    from Alberta
    Now it’s ready to install.
    The nice flat wide gasket surface and the silicone gasket should do the trick. :cool:
    3565770C-5B80-4A8D-A2A4-3599F8F89672.jpeg 87D164B3-43F1-4662-B9BB-359FEFE61523.jpeg 9E5ACED1-BA4B-4C5D-9E77-E8F22A802496.jpeg 30C598DA-8866-41B1-A40F-33A7C76164A9.jpeg
    brad2v, Dino 64, loudbang and 2 others like this.
  6. Blue One
    Blue One
    from Alberta
    Just for reference this is where and I believe why the stamped steel piece of***** pan was leaking.
    It has a relief formed into the pan that I can see no reason for.
    And of course that’s where it leaked.
    44EB90E3-16E9-45D4-A825-CB86C1646739.jpeg EABD2FB4-A0A8-4B4D-8DC5-4F45509E156E.jpeg 5C585434-47D4-4A0B-9B4C-8B023AA87120.jpeg
  7. Blues4U
    Blues4U
    from So Cal
    Ahhh man, you gotta remove the paint from those fins before you install it.
    Great job Larry, very impressive.
  8. Six Ball
    Six Ball
    from Nevada
    Where ever you drive this car you should pass out cards with a link to this thread so people after being amazed with the car can be truly amazed with what it took to build it. Just seeing the finished product is not enough.
  9. Blue One
    Blue One
    from Alberta
    Thanks
    :D I have a transmission cooler and even painted aluminum transfers and dissipates heat.
    Surely you’re not one of those guys that believe that a small film of paint acts like an insulating blanket :D
    Dino 64 and loudbang like this.
  10. Blues4U
    Blues4U
    from So Cal
    No, it's just aesthetics. The pan would look much cooler with the paint removed from the fins, especially if you polished them! ;)
  11. 26 T Ford RPU
    26 T Ford RPU
    Silly question but, have you test fitted the pan? Just looking at the revels in the tin pan and the new gasket. JW
  12. Blue One
    Blue One
    from Alberta
    I’ve nicely finished and taken care of the details on the underside but I’ve been restricting the shiny stuff to the topside ( the ceramic coated exhaust being a small exception ) where you can see it and I can clean it.
    I think I’ll stick to the plan ;):D
    loudbang and 26 T Ford RPU like this.
  13. Blue One
    Blue One
    from Alberta
    It seems to fit nicely, I’ll report back if it doesn’t :D
  14. 26 T Ford RPU
    26 T Ford RPU
  15. Blue One
    Blue One
    from Alberta
    Well the pan is installed and the fluid is back in.
    So far everything is looking good. :cool:
    B6D74DD3-2CF5-4B26-AAA1-915E8977D1D0.jpeg D1C13D65-D007-4C85-B89B-95A953E8C4A2.jpeg
    brEad, brad2v, Shadow Creek and 6 others like this.
  16. kidcampbell71
    kidcampbell71
    Dang' .. that does look good !
    Also ... I can see you with some rags and towels cleaning underneath too. Looks pretty damn tidy to not to.
    After all .. you did build some fancy high lift stands.
    We see you, man. :)
  17. Blue One
    Blue One
    from Alberta
    The transmission pan is perfect, no leaks and I’m confident it will stay that way.
    I realized that I never posted pictures of the new fan. :D
    It should move a lot more air than the previous one. :cool:
    I also switched to a 7 lb cap.
    4A88FD46-ACCA-4F4B-AA27-BF376DA6FB1D.jpeg 78FD7AD5-1EA5-4D5C-8283-654E650320F2.jpeg
    brEad, brad2v, Six Ball and 5 others like this.
  18. atch
    atch
    Probably a dumb question, but shouldn't the rivets on the fan be towards the radiator and the smooth side be toward the engine?
  19. Blue One
    Blue One
    from Alberta
    It’s a clockwise standard rotation fan and was labeled for the side facing the radiator.
    I installed it the way it was marked.
  20. atch
    atch
    Very interesting.
  21. Blue One
    Blue One
    from Alberta
    This picture shows what the front side facing the radiator looks like.
    Derale fan - non flex 28 degree blades , should move air well.
  22. K13
    K13
  23. Blue One
    Blue One
    from Alberta
    Yes actually I got those from Oxygen products I believe.
    KMS tools sells Walter too but I’ve never looked for them there.
    I’m pretty sure Praxair would have them also.
  24. K13
    K13
    Thanks I will have to look for some.
    Sent from my SM-G950W using The H.A.M.B. mobile app
  25. Blues4U
    Blues4U
    from So Cal
    Oh Jeeeez, those fins are crying to have the paint cleaned off them & polished up. ;)
    kidcampbell71, Stogy and loudbang like this.
  26. Blue One
    Blue One
    from Alberta
    :D Didn’t we already talk about this ;):D
  27. Mr. Mac
    Mr. Mac
    Your fan looks just like the one in my Roadster and I can tell you it works real good.
  28. Blue One
    Blue One
    from Alberta
    Well today I put the distributor back in and got it fired up and started fine tuning the 3 Strombergs
    The new core plug in the head is perfect and leak free as is the transmission pan.
    I couldn’t get the transmission to do any driving of the rear wheels so I checked the fluid level.
    I added another litre and I’ll have to get more.
    After that it does move the rear wheels but there’s still no fluid reading on the dipstick yet.
    Any idea how much a C4 holds from right empty? I’ve got about 7 1/2 litres in it now.
    Any tips on adjusting the carbs?
    My oil pressure gauge is working and shows good oil pressure.
    The new fan did the trick no overheating, great air movement and cooling.
    Stogy, loudbang, OFT and 2 others like this.
  29. Tim
    Tim
    from KCMO
    My uneducated guess is 11.5
  30. 57 Fargo
    57 Fargo
    I would say this is close
