Projects Mild custom '51 Pontiac Chieftain
Discussion in 'The Hokey Ass Message Board' started by PhilA, Nov 4, 2019.
  1. PhilA
    PhilA
    Yeah, dishwasher soap is a little too caustic. I'm working on a slightly more gentle degrease.
    Phil
    mrspeedyt, chryslerfan55 and loudbang like this.
  2. PhilA
    PhilA
    Well, good deed done for Christmas; stranded motorist given ***istance.
    Hope y'all have a happy holidays!
    Phil
    mrspeedyt, Woogeroo, ClarkH and 10 others like this.
  3. PhilA
    PhilA
    Tonight's endeavor: Valve guide cleaning.
    We begin with a toothbrush, some dowel and a few hand tools.
    Cut down, notched and filed.
    Fitted in with superglue.
    Carefully trimmed.
    Calibration checked- success. It's now clamped so the glue can set thoroughly overnight.
    Also, spring retainers have come up clean. It proves that Pine-Sol has:
    Pros
    - Cleans oily grime
    - Smells okay
    Cons
    - Takes forever
    So, not so bad but I don't feel like waiting so long for results, but it is shifting 60+ year old muck so I'm going to give it a break on that front.
    If the guides come up clean and the brush doesn't fall apart then I'll lap the good valves in and re***emble.
    Phil
  4. Lloyd's paint & glass
    chryslerfan55, loudbang and PhilA like this.
  5. PhilA
    PhilA
    Ended up drilling a hole through the brush head and driving a pin through to hold it all in place. This, however worked really well and all the guides cleaned up nicely.
    Started to lap the valves in and ran out of time.
    Looking good so far though.
    Hopefully more at the weekend.
    Phil
    mrspeedyt, Woogeroo, brEad and 4 others like this.
  6. Lloyd's paint & glass
    Once you get those valves done, hop a flight to Kentucky and help me! I'll buy lunch :)
  7. PhilA
    PhilA
    Why fly? Would be a nice drive, come springtime.
    Phil
  8. Lloyd's paint & glass
    Yes sir! Bring that Indian to bowling green in June
  9. PhilA
    PhilA
    Holley Hot Rod Reunion?
  10. Lloyd's paint & glass
    Yes sir, gives you a goal lol
  11. PhilA
    PhilA
    That's a 650 mile goal!
    Woogeroo and loudbang like this.
  12. Lloyd's paint & glass
    Consider it an extended shake down run :D
    Woogeroo, loudbang and PhilA like this.
  13. PhilA
    PhilA
    My worry is it would end up as a shake apart!
  14. Lloyd's paint & glass
    Nah, from what I've seen you've got a good mechanic on the job
  15. PhilA
    PhilA
    Today the temperature and humidity shot up suddenly, leaving the garage and its contents well below the dew point. Everything condensed, the oil I put on the block deck turned into creamy mayonnaise. Yuk.
    I did a few more valves before running out of clean shop rag. Plus, it's really sweaty out, 72F at 98%rH. The paper kitchen towel I was using was just tearing apart from the damp.
    I put the aircon on in the side workshop to try keep the humidity down, all the rest of the parts are stored in there.
    Phil
    mrspeedyt, Okie Pete and loudbang like this.
  16. PhilA
    PhilA
    Brief escape from doing the car.
    Found an old can of paint that was still good so threw it up on the doors and wall.
    Brightened it up a bit in there.
    Phil
  17. 302GMC
    302GMC
    from Idaho
    Betcha those walls won't stay bare very long ….
  18. PhilA
    PhilA
    No, I want to put up some lights.
  19. Lloyd's paint & glass
    I just might have a wicked "Pontiac parts and service" sign out in my stash, if so it'll be on its way ;)
  20. PhilA
    PhilA
    I was eyeing it up for a mural of some sort, maybe...
    We'll see
    Phil
  21. poncho catalina
    poncho catalina
    from summit il
    Lloyd
    If Phil does not want the sign, I would be interested. Send me a pm on how much you want for it
  22. Lloyd's paint & glass
    Not really something valuable, reproduction tin sign. Just something to help cover that wall Phil has polished up :D
  23. PhilA
    PhilA
    Did a few more valves. Need to finish cleaning the collets and retainers and I'll do the springs on them.
    Phil
    mrspeedyt and loudbang like this.
  24. thegreenbuzzer
    thegreenbuzzer
    from Knoxville
    I’m rewiring with a new harness my 50 silver streak but my sausage fingers are to big to get some unhooked behind the gauge panel how does it come out? Like you did. Thanks
  25. PhilA
    PhilA
    First, wire clip holds the wires up, next to the speedometer drive. Speedometer drive unscrews. There's a bunch of wires that come down the A pillar next to the screen, one goes to the left hand nut on the fuel gauge (should have a rubber bungy and red warning label).
    Ammeter wires come off, temperature gauge wire and the two power wires on each gauge. Oil pressure line undoes. All illumination bulbs pull out (4 off), turn signals and bright lights indicators too.
    Once all that's out of the way there's two nuts at the bottom, two at the top that hold the gauges in. I find a finger's length extension bar and a ratchet help get access.
    I had the driver's door open, shoulder down on the floor, looking up past the hood pull and parking brake mechanism allows easier access to the outside pair, leaning over a little and reaching up past the ventilation duct controls will let you reach the other side.
    Flashlight is essential!
    Head on dimmer switch, Houdini style shoulder twist to get in past the door, halfway out of the car, looking up past the handbrake mechanism. Retaining nuts arrowed.
    From the same position looking up past the steering column, using left arm to reach nuts (one just up out of view at the top). For reference that's the ignition switch and cigar lighter below.
    The bottom will tilt out but the threads hold it in place. Get out of the car, crush your face against the steering wheel, reach up under the dash and support it from behind, other hand ready to catch from the front. It's moderately heavy, about 4lbs so take care not to drop it.
    Phil
  26. Lloyd's paint & glass
    Knock knock knock.... you in there Phil?
  27. PhilA
    PhilA
    I'm here...?
  28. Lloyd's paint & glass
    Just checking on ya! Making sure you wasn't abducted in time square!
  29. PhilA
    PhilA
    Nope, spent the day cooking and eating with friends and family. Hope y'all had a pleasant New Year.
    Randall and loudbang like this.
  30. PhilA
    PhilA
    Got up under the car tonight and pulled the crank round 360°. All the water on there is condensed water out of the air, the engine is still below the dew point because it is so m***ive and takes a long time to change temperature.
    Lapped in the last 2 valves (minus the 16th that I need to order) and cleaned up the intake spring seats and retainers, with the exhaust ones left to soak.
    Tomorrow through to the weekend is meant to be cooler and more dry, might be able to re***emble a little and set clearances.
    However, if the rest of the week is to be used as a yardstick for that, unlikely.
    Phil
