Hot Rods Pecks RPU project
Discussion in 'The Hokey Ass Message Board' started by pecker head, Dec 29, 2018.
  1. pecker head
    pecker head
    260269BF-DCDE-4B97-8188-8BEED5437E90.jpeg E5DA8CE4-56D6-4D8A-8DC3-CE21CE3F9A02.jpeg The old coat hanger trick , before you go hunting for radiator hoses.
  2. pecker head
    pecker head
    E7C76EA1-177C-4668-8502-4E943576F82E.jpeg 950E5303-748C-4CA6-BB47-17D7555D84D8.jpeg 9BECA052-77B3-4E49-999C-7231E61A1ED3.jpeg 714F6504-BA1E-4CD9-BC0A-F393B582C8D6.jpeg D4BB8F54-D7F7-4409-BE04-C5F5605D3933.jpeg 3$ swap meet oil bath breather , cut up today.
  3. pecker head
    pecker head
  4. pecker head
    pecker head
    6CA26BB7-E758-4118-A438-D2465B452E39.jpeg C744D922-28EE-4453-B518-861D369A4DC6.jpeg 98B7FBCC-A02D-46EE-93D4-EC3FD6F888CD.jpeg Welded ground and painted , I like better than big air cleaner. Making room for generator.
  5. krusty40
    krusty40
    I do too. Looks like a cheap 50s sci-fi movie "alien spaceship" ( imagine lights instead of pleats behind the slots and a barely visible wire "flying" it).
    Great build.
    vic
    Just Gary, LCGarage, BradinNC and 4 others like this.
  6. pecker head
    pecker head
    Thank you sir , my thoughts exactly.
  7. RodStRace
    RodStRace
    pecker head, Really diggin' the build and the clean work you are doing. I do have a couple of suggestions, if I may:
    Tighten the throttle return spring up a bit. It should have a bit of space between the coils at full return so it still has tension.
    Bend and flare a fuel line to fit between the pump and carb. It will look better, and if you ever take the car down the strip, many places limit you to a TOTAL of 12" of rubber in the whole system. That side is also pressurized.
    P.S. Checkered Vans for the win!
    That type of choke also likes to have a metal tube running to either the exhaust crossover in the intake manifold (don't see provision for it) or the exhaust manifold itself (drill a hole in the flat D-shaped area that is not level, IIRC). It's a slip fit in the exhaust, threaded nut on the choke. Without the proper heat coming up, the choke will not open properly, and it is a vacuum leak, too.
  8. pecker head
    pecker head
    I live in TEXAS , no choke required. Will be hard lined from pump to carb.VAN’s always ROCK.Thanks man.
  9. RodStRace
    RodStRace
    Cool (but not cold)! :D
    Then back it off completely and plug the hole in the housing so it isn't vacuum leaking. It's a small hole that looks like it might be at 1 O'clock on yours in the pics. There is a p***age tube that does NOT have a screw going thru it to attach the choke housing to the carb main body. There is also a small gasket with 2 holes, one for the alignment bump and the other for the vacuum p***age. That's what I see in the one pic of the side of the carb.
  10. pecker head
    pecker head
    It’s backed off completely ,and just have to cap off opening, has brand new gaskets on everything.
    chryslerfan55, OFT and loudbang like this.
  11. pecker head
    pecker head
    70AA9DC9-823B-47B8-B907-738C3E3F022B.jpeg F1F1A397-4E57-4B1B-8B4D-B95DADB823AC.png 35CD7349-3607-4A7F-93CD-C4FB4A75F80B.jpeg Finally got around to redoing the rearend art that I originally did when I was 15 with Testors model paint.
  12. pecker head
    pecker head
    252C0EB6-C728-411A-B02C-C6F8520AE2FE.jpeg 2FFA062C-8BA4-4EC9-91BF-BAA026AED8A7.jpeg 6F9BED55-4AB8-47EA-B21C-F7A3E5EA9F1C.jpeg I painted this 4 blade fan and installed.
  13. pecker head
    pecker head
    31375874-23DF-4A4B-90B4-987C1873E56C.jpeg B93A91EA-2C3B-4CEC-AFDD-EFDF24EFA3F6.jpeg 659B9045-ECF6-440F-8406-7BB41D6B8CEA.jpeg 36C645B4-02B1-4AE9-A705-7C9F151231F8.jpeg 1B3E3460-A35D-4263-B7B3-9D00A7B28095.jpeg 9E1C3D12-CC16-4E1B-9459-41D0203CC9FB.jpeg 6BD428B5-372E-45A8-B889-1A1A71F101A0.jpeg I built a decent generator out of the original, and a $5 Pate Swap Meet find from last April. If it don’t work right, I’ll send to Dirty2 for a rebuild.
  14. RodStRace
    RodStRace
    Used to work in a shop that had a SnapOn generator checker (growler) and armature turner.
    Something tells me the warranty for that tool is not Lifetime any more!
    While trying to come up with a picture of one (no luck), I came across this. It might help ya!
    https://www.hometownbuick.com/1959-buick-generating-system/
  15. belair
    belair
  16. pecker head
    pecker head
    2DFE30B4-6865-43A7-813D-B1F2ECDD8157.jpeg Started recessing firewall.
  17. pecker head
    pecker head
  18. James Haram
    James Haram
    It’s looking good, I feel that your taste and and cl***ic approach to hot rods are the same as mine. Not trying to high jack your topic but here is my firewall old wheel barrow ATTACH=full]4534695[/ATTACH] IMG_1463.JPG
  19. stillrunners
    stillrunners
    from dallas
  20. fiftyv8
    fiftyv8
    from CO & WA
    Great work on the firewall Peck.
    I did one similar several years ago and reversed the seam flanges so that the firewall bolts were hidden inside the cab. The firewall looked even better with a nice smooth clean finish.
    Sorry, no close ups, but if you blow up these two attached pic's and you know what you are looking for you can just faintly see that there is no seam flange outside.
  21. pecker head
    pecker head
  22. pecker head
    pecker head
    66BB52B5-20EF-4F2D-BFF9-DC4B88744469.jpeg 52187A65-DB14-4FAF-A9D8-4D4EF6B1370D.jpeg 45697B4F-F4CB-4880-86CF-5676EF08AB7B.jpeg 43DE8F38-3948-4ECB-86EC-181199F388BA.jpeg Fixed damaged hood lip with piece of junk cowl and got gas cap filler piece .
  23. pecker head
    pecker head
    0001845E-5765-44D3-9508-1D6AECE5F7CD.jpeg D2A12495-3B0D-4289-9758-B89457FB2BDD.jpeg FD936C8C-F168-449E-BDAB-F526F31EB6C7.jpeg F32AF34D-71B7-414D-8CF1-800BE8CAC9B8.jpeg Just getting started on this.
  24. pecker head
    pecker head
    2AE107B7-763C-41F2-A035-5D455F396F61.png E9660450-02DF-4066-8DF9-1E66469B37BE.jpeg E380EEC7-AF2B-4797-8AB3-71A707DB5556.png And then this happened today.
    sko_ford, Tim, Shadow Creek and 6 others like this.
  25. Junior Stock
    Junior Stock
    Them things just fall out of the sky in Texas don't they? HaHa
    loudbang and pecker head like this.
  26. pecker head
    pecker head
    6BB46C81-DD6B-483F-8A3F-9B139999542B.jpeg AAEA5E42-C7BA-4EBE-A759-C9B1A75CC148.jpeg E192C8B9-A88B-4BB8-980D-7DCFDD2AF72D.jpeg I’ve opened up a can of worms over here. I got more cool cars than I can drive now, I might as well redo as much as I’m capable of doing. No hurry to finish.
    brEad, loudbang, cactus1 and 2 others like this.
  27. pecker head
    pecker head
    Damn near finished with drivers side. P***enger side tomorrow, I wired brushed all the rust and sprayed rust encapsulator on it. Don't know how old this reproduction lower cowl part was, I took it in a trade but it fit good. Hope the HOWELLS SHEET METAL repop I bought at Pate Swap Meet last year fits the p***enger side as well. Drilling all the holes in the right place was very time consuming. CD4809EF-810C-4050-93B5-DE1B78CA5F87.jpeg 9093FDF6-EC6F-4F68-9A1F-9311B73F27AE.jpeg 2386D391-6ADC-49D4-B6AF-9C0B5AABB926.jpeg
  28. pecker head
    pecker head
    AE9C7BB3-DDA8-4A57-A19A-233BB441064C.jpeg Well Howell’s cowl piece FAILED reveal at least a 1/4” out of place.
  29. pecker head
    pecker head
    C9A48972-F19E-4AC7-8EB0-A5E96DC88D39.jpeg FA67974B-2B9F-4D87-96C3-4E335F959D08.jpeg 63230F46-796F-43B7-8862-EA8911196EC6.jpeg Unbelievable that these guys can’t get there **** together.
    Tman, Stogy, OFT and 5 others like this.
