Projects Howland the 46 Ford
Discussion in 'Traditional Customs' started by dcadwell, Nov 18, 2019.
  1. ss34coupe
    ss34coupe
    Really nice work!
  2. Some great old school ideas here- keep up the good work!
  3. dcadwell
    dcadwell
    Thank you!
  4. dcadwell
    dcadwell
    Thanks! Lots left to get done.
  5. 1-SHOT
    1-SHOT
    from Denton
    I really like the way you did the chop. I have a 46 Mercury coupe and I think that's what it needs. Frank
  6. 48fordor
    48fordor
    from York, PA
    Have you considered following the L shape of your upper/side trim as a smaller series instead of vertical teeth? Think '47 Olds.
    Sent from my SM-G960U using The H.A.M.B. mobile app
  7. dcadwell
    dcadwell
    Thanks Frank. Moving the back window forward a lot helps the lines, but even with the modest chop, a functional back seat is lost. Not a concern for me, but something to keep in mind.
  8. dcadwell
    dcadwell
    I think that would look great! At this point though, after cutting up the DeSoto grill for the teeth, I'm pretty committed to the teeth. Otherwise I'd have to build another car so the teeth didn't go to waste.
    That said, the grill teeth will be bolting on. I could always make swap-able inserts.
  9. 1-SHOT
    1-SHOT
    from Denton
    What gauge metal did you use to make the filler panel out of ? I also have a second coupe as a parts car.
  10. Mark Grabo
    Mark Grabo
    from Upstate NY
  11. 1-SHOT
    1-SHOT
    from Denton
    I like the DeSoto grill best.
    unforgiven likes this.
  12. straykatkustoms
    straykatkustoms
    Hope ya don't mind I did a quickie, I like the Desoto but this one is sure making me think twice. Love your project.
    Stogy and chlsnk like this.
  13. Bill Rinaldi
    Bill Rinaldi
    Nice job on the chop!!! I'm all in on 5 bars, you've got a great look going!! Bill Rinaldi
  14. dcadwell
    dcadwell
    I try to match the gauge as close as possible to the car - I think I used 18 Ga. for the filler panel.
  15. dcadwell
    dcadwell
    That is pretty cool looking - thanks for putting it together!
  16. dcadwell
    dcadwell
    Thanks!
  17. 47 ford
    47 ford
    That's super cool
    Stogy likes this.
  18. Mark Grabo
    Mark Grabo
    from Upstate NY
    great idea
    Stogy likes this.
  19. topher5150
    topher5150
    Love those headlights.....might have to steal that for my car
    Stogy likes this.
  20. dcadwell
    dcadwell
    Sometimes the small projects are as rewarding as the big ones.
    Mom's 1881 lucky silver dollar in her new home. If she brings Howland and me as much luck as she did my Mom, we'll be doing pretty good.
  21. dcadwell
    dcadwell
    Sometimes life gets in the way, but I left that job behind and I'm back at it planning on having Howland on the road this Summer.
    I decided not to use the gravel pan since I like the look of exposed bumper brackets. So I used the gravel pan to make a chin panel and blend everything together. I decided on horizontal grill bars instead of the vertical teeth. I think the horizontal bars will fit the look I'm going for better. Still need to do some fine tuning and make the bumper bracket openings in the chin panel. 20250107_122928.jpg 20250107_140306.jpg 20250110_144935.jpg 20250111_160256.jpg 20250111_160320.jpg
    Stogy, anothercarguy, 1pickup and 6 others like this.
  22. dcadwell
    dcadwell
    Made a simple buck to help form the bumper bracket openings. I goofed up on thr lateral location a little because I didn't realize the brackets had to be spread to match the bumper mounting holes. This moved the brackets off center in the chin pan openings. I'll either modify the brackets or just get used to it. 20250112_130157m.jpg 20250112_131106m.jpg 20250112_132620m.jpg
    Stogy, anothercarguy, 1pickup and 3 others like this.
  23. dcadwell
    dcadwell
    DSC_0003m.jpg DSC_0005m.jpg DSC_0011m.jpg DSC_0014m.jpg Drove up and down the driveway and got some outdoor photos. Grill bars are next.
  24. dcadwell
    dcadwell
    Detour from work on the grill bars - I like the Studebaker headlights that I started out with, but the shape just isn't a good fit for this flat-front car. So I decided to go back to the original buckets and form a frenching panel that incorporates a lens from an accessory reverse light for the turn signal. I'll make a little bucket for an amber bulb.
    Lots of shape to put in an 18 gauge panel, but the real challenge is going to be making the p***enger side panel match.
    Bucket mounted behind fender with wood spacer for reference when forming panel.
    Paper pattern - lots of shrinking!
    Took about 1" out to form a cone to reduce the amount of additional shrinking.
    Start of forming. Wood reference helps keep the headlight opening centered and at the right height during the process.
    Happened to have a socket the right size to form the turn signal lens opening.
    Getting closer
    RICH B, CruznArt, Stogy and 14 others like this.
  25. 51 mercules
    51 mercules
    Cool project! Nice work!
    Stogy likes this.
  26. Tim
    Tim
    from KCMO
    Pretty cool project. The roofline reads chevy, the front end feels vaugly mopar and the grill work looks like a never made 1941 1/2 ford! Very subtle and wild at the same time. Fun one to follow along with
    Stogy, Stan Back and guthriesmith like this.
  27. guthriesmith
    guthriesmith
    Kool project! Good to see you are getting back on it! :cool:
    Stogy likes this.
  28. woodiewagon46
    woodiewagon46
    from New York
    I gotta be honest with you, I have never been a fan of chopping '40 to '48 Fords, but you really nailed the roofline. I would bet that when the car is finished some people would stand back and try to figure out if the car is chopped or not. It almost reminds me of a late '40s Chevy roofline. Your metal work is beautiful, keep up with the pictures, nice job!
    Stogy and Bigcheese327 like this.
  29. dcadwell
    dcadwell
    Thanks everyone! The goal of the build is to create a car that looks like it could have been factory built back in the day, at the same time being substantially modified.
  30. Okie Pete
    Okie Pete
    Beautiful. You have an eye for small details and a craftsman’ skills . The headlight bubble is cool
    Stogy and guthriesmith like this.
