Technical 289 in a '34 Ford
Discussion in 'Traditional Hot Rods' started by terry k, Jan 1, 2020.
  1. DIYGUY
    DIYGUY
    from West, TX
    Don’t want to derail this thread , but I gotta ask, how did you fit roller rockers under those regular valve covers? Thick gaskets or spacers?
  2. MeanGene427
    MeanGene427
    from Napa
    Always gotta be one Chebbrainwashed Bozo gets on the bus
    warbird1 and loudbang like this.
  3. Beanscoot
    Beanscoot
    Aw, c'mon, it was funny.
    Blues4U likes this.
  4. thirtytwo
    thirtytwo
    REAL early ford guys like the sbc because it fits right where the Flathead was and will bolt in without molesting the car , traditional guys usally like engine formation that are pre 1960 so technically I’m a traditional brain washed bozo... thank you very much ..
    even Shelby wanted a sbc instead of the sbf
  5. 58ducknut
    58ducknut
    from ohio
    BD8BFB05-4170-447A-BE7D-9BE35058AE4D.jpeg Snow White water pump or the shorty ford pump works good
  6. dumprat
    dumprat
    from b.c.
    ^So you have a short waterpump and still had the cut into the firewall 3"?
  7. 6sally6
    6sally6
    289 crank AND RODS??!...in a 5.0 roller motor Musta used a custom short piston....or Boss 302 pistons?! Sounds interesting
    6sally6
  8. 58ducknut
    58ducknut
    from ohio
    28A00EFF-EE90-4103-9954-2611E9F7C096.jpeg Terry, I have the Snow White pump kit with a 3” cut firewall ,mechanical fan and a front sump oil pan . Fan bolts are 3 1/4” from the radiator. With the bronco oil pan it might fit but it would be tight without the fan . ​
  9. dumprat
    dumprat
    from b.c.
    Stock height 302 forged skirt coated .030 over Pistons. Block milled for zero beck.
  10. dumprat
    dumprat
    from b.c.
    So how far is the fan from the rad? I see you have an aftermarket front crossmember, did you push the rad forward?
  11. 6sally6
    6sally6
    OOOPs!! I "mis-spuke" (past tense for mis-spoke) I thought you ran a 302 crank with 289 rods............Boss 302 set-up.
    You clearly said 289 CRANK and rods!! I guess it was late or I'm just slow.
    6sally6
  12. terry k
    terry k
    from toledo oh
    Nice looking !!!
  13. Binkman
    Binkman
    I have a 302 in my '34 cabiolet and just put a 302 in my '34 2-dr sedan. Both fit without cutting anything.
    I used the Snow-White kit and it was simple. The radiator is about 3/4 from the fan.
    I don't now if Snow White is still in business. I tried calling them for an extra lower pulley and they never answered the phone, or answered e-mails.
    34 5W Paul likes this.
  14. FORD FAN
    FORD FAN
    58ducknut, What are you using for a fan blade? Also, it looks like you're not using a spacer. Is that right?
  15. 58ducknut
    58ducknut
    from ohio
    Stock radiator location, fan is an after market from Summit and it’s 2 5/8” from the radiator. Motors runs cool with a 180 thermostat and Walker radiator.No complaints whatsoever with it . No spacer
  16. 58ducknut
    58ducknut
    from ohio
    Speedway Motors sells the Snow White kit now if anyone is looking for it .
  17. terry k
    terry k
    from toledo oh
    Brinkman.....What fan are you using. 3/4" is close, but if I don't have to cut the firewall that would be great. 58 ducknut.... you used the Snow white kit and still cut the firewall 3"...played it very safe.
