Projects Gabriel air shock compressor help
Discussion in 'The Hokey Ass Message Board' started by Carver Kemle, Jan 5, 2020.
  1. Carver Kemle
    Carver Kemle
    I have Gabriel hi jacker air shocks in the back of my 52 styleline. I am trying to add an onboard compressor kit. Recommendations? I was looking at airlift 25804. Though i do not want it to take it forever to fill them when needed. Any help is appreciated
  2. Air shocks have an extremely small capacity. Will only take them a moment to fill up the regardless of what compressor you're using.
  3. suedestude
    suedestude
    Gabriel makes a pump kit. comes with lines a little compressor and a gauge. I have mine so I can change the psi as I drive. I have used a couple of these works very well.
  4. Carver Kemle
    Carver Kemle
    Thats great for some reason when i look on the website i dont find a compressor kit.
  5. Carver Kemle
    Carver Kemle
    Do you find airshocks work well with your application?
  6. Bandit Billy
    Bandit Billy
    Years ago I installed Firestone overload air bags on my OT lowrider Silverado. I also installed their compressor (fit behind the seat on my standard cab) and bought the wireless remote set up. Still works perfect. I can fill one side at a time to level the load or set it to 20 pounds for everyday driving and it maintains pressure. With the remote I can stand behind or along side the truck and level it without h***le. The remote has pressure readings and balance indicators.
    Nice little compressor and not too noisy. May be more than you are looking for.
  7. suedestude
    suedestude
    Now that I have had time to pull my head out of my ***. It was not a Gabriel kit. Iam going to my shop later today Ill get the name of the manufacturer. I do use Gabriel shocks with the kit. sorry!
  8. chopnchaneled
    chopnchaneled
    from Buford Ga.
    I use one out of an o/t olds toranado, works really well.
    Carver Kemle likes this.
  9. Carver Kemle
    Carver Kemle
    No problem please let ne know
  10. Blues4U
    Blues4U
    from So Cal
    I figured this thread would be closed for being OT. I'm surprised it's still alive.
  11. suedestude
    suedestude
    ok I found the box at my shop. Its called air supply electric ride control system made by Monroe. It works on all air shocks. I could not find a part number on the box.
  12. Carver Kemle
    Carver Kemle
    Ok thanks
  13. Carver Kemle
    Carver Kemle
    What is OT?
  14. Blues4U
    Blues4U
    from So Cal
    Off Topic. This site is for 65 & earlier hot rod & custom cars, and I don't believe air shocks and on board compressors were part of that era. Note, I'm not complaining about this, I'm just surprised somebody else hasn't ratted you out and had this thread shut down. Some guys get all upset easily. Best of luck to you with your project.
  15. Rich S.
    Rich S.
    qicvick, catdad49 and Carver Kemle like this.
  16. Carver Kemle
    Carver Kemle
  17. Rich S.
    Rich S.
    I’ve only used air shocks for pulling a trailer and fill them with a air hose. Sorry. IMG_3442.JPG
    catdad49 likes this.
  18. Blues4U
    Blues4U
    from So Cal
  19. Rich S.
    Rich S.
    According to what I’ve read, they did use air suspension.
  20. jnaki
    jnaki
    Hello,
    Air shocks came with 1964 Chevelle El Caminos as a stock factory item. They were the first gen models for a fresh off the factory build ***embly line. Those air shocks were filled from an air inlet screwed into the small panel behind the p***enger side seat.
    https://www.jalopyjournal.com/forum/threads/chevrolet-el-camino-thread.995126/page-2#post-13329989
    When the El Camino came from the factory, there was only an inlet air valve. It got to be a h***le not knowing how much air was in the rear shocks at any time. So, I found a company that made gauges for all sorts of applications and they had the perfect one for the Chevrolet factory air shock.
    Jnaki
    The gauge fit directly under the panel with the air valve cap on the surface of the small package tray. This gauge saved many extra trips to the gas station for exact readings. If not enough air was in the shocks, the ride was awful. No loads could be put in the back without the nose going up in the air and the handling becoming awful to unsafe.
    Any over inflation of the air shocks could blow out the seals when overloaded with stuff in the back of the El Camino. The gauge was as accurate as those accessory air valve pens. They were good additions to having a comfortable ride in an El Camino loaded or unloaded. (The El Camino, not you.)
    Yes, air bag suspension is off topic and not allowed as per HAMB rules. Since the stock Chevrolet factory supplied the new (then 1964) El Camino with two rear air shocks, it is allowable to talk and show photos of those set ups. The air ride suspensions were another ball game.
    With the successful application of those early factory air shocks, more advances took place. Big companies started to flood the market with their own air shocks as the factory ones did blow seals with overloading episodes. Then those "up in the air" fake gas coupes and sedans came on the market after 1965 and took the air shocks to extremes.
    Despite the numerous stories of those fake gas coupes and sedans, those were off topic for the HAMB pre 65 rules. If the compressor is for adjusting the factory style air shocks in the original application or later rear shocks, it should be OK.
    If we had a small compressor behind the El Camino seat, that would have made the trips to the gas station null and void. Just hit the ****on and the factory air shocks would have pumped up the rear bed instantly. Good for instant loading at any time.
    Rich S. likes this.
  21. Rich S.
    Rich S.
    Thanks for the info. I never knew that about the El Camino.
    jnaki likes this.
