Hot Rods 1933 willys coupe build
Discussion in 'The Hokey Ass Message Board' started by drumyn29, Sep 4, 2014.
  1. wrenchbender
    wrenchbender
    Those brackets are to mount the inside z bar bracket for a mopar car The car is coming along nicely
  2. drumyn29
    drumyn29
    I stand corrected. Thanks for commenting, I would hate to send someone down the wrong path! I think tat I meant to say ALL mopar transmissions have the same bolt pattern as a 392 Hemi with the exception to the 426. Of course I may be wrong about that also.
  3. esrbuilders
    esrbuilders
    Very nice build!
  4. flatheadgary
    flatheadgary
    from boron,ca
    are you going to have enough room for a trans shield with those square tubes that close to the trans?
  5. drumyn29
    drumyn29
    oh ****.......
  6. drumyn29
    drumyn29
  7. RodStRace
    RodStRace
    https://www.dodge-wiki.com/wiki/List_of_Chrysler_bellhousing_patterns
    Small block (and 1st gen Hemi [392], 3rd gen Hemi)
    Big Block (wedge and 2nd gen Hemi [426])
    Make sure a long extension and swivel socket can reach all those bolts or make a removable cover.
    I answered your PM before realizing which project it was attached to; nice work, hope you find an answer!
    As for those brackets on the side of the shield, it would be smart to hang the engine and bellhousing in the car so that the trans can be removed without supporting the back of the engine with a jack. This allows servicing the clutch and trans more easily, along with having additional support to keep the clutch linkage aligned. If you do this, make sure this is also allowed by the floor supports before finishing it. Racing means fixin' stuff! If this was a street car, it doesn't matter if it takes 4 hours to pull. If you are going into the final round, it does matter.
    This is an example of how modern door cars have the trans mounted for access. You don't have to do it this 'modern', but you shouldn't have a single hoop roll bar and no driveshaft loop in a real race car either.
    https://timmcamis.com/shop/lenco-mount-kit.html
  8. drumyn29
    drumyn29
    I was thinking removable cover for sure.
    loudbang and RodStRace like this.
  9. I wouldn’t have those support tubes there around the transmission.
    A formed tunnel is incredibly strong for floor support and light. Also pretty easy if you’ve got a break and can make a pattern .
    This is a small car and the floor needed to be easily removed. It takes a little longer to plan set up build but then goes in and out in just a few mins.
    The routine stuff, or what might be roadside stuff is all under the seat
  10. drumyn29
    drumyn29
    I have always hated the los of the square tubes. Thats a beautiful floor !
    31Vicky with a hemi and loudbang like this.
  11. DDDenny
    As Vicky said no need for all that space eating square tubing.
    If you feel the need for extra support you can easily form up a sub-structure out of round stock, I've done it in 1/4" and it is surprisingly strong, lightweight too.
  12. Here’s 2 more to get you going.
    Actually same car and had a change so I changed the tunnel too.
    BF34108C-2F3A-4C49-B98C-5C06F56316A9.jpeg BD969A20-187E-43BA-B883-D6D4B8A8C376.jpeg 05C86676-CADD-4520-8FF7-DF23083BC28B.jpeg 0D45FB01-6017-40B5-B93B-DA4B50117DE0.jpeg EB69F039-12BF-4085-9D9C-7B27F0CEAA27.jpeg A954EBC9-F2ED-426A-A917-E0A0137D79A5.jpeg
  13. Then the re dooo
    92335829-5DD8-4419-8CCC-143C914509E7.jpeg 231F9F07-6906-4298-B609-527D641A7142.jpeg 988EB7BD-AAC0-4B81-B738-ECA35EB9B881.jpeg CEB0DC63-9470-46A4-AE9F-9BB45E2F5996.jpeg 622CDDA2-9088-4B6C-9B79-799412FC46C7.jpeg
    A fella could wheel out the defined break lines and smooth it out. I kinda like them
  14. chop job
    chop job
    from Wisconsin
    VERY nice workmanship.
  15. drumyn29
    drumyn29
    I don't have any of them there fancy tools like 31 vicky but I did take his advise and I'm glad I did. The floor section that I am building will be plenty strong without the tubing. Now I just need to decide if I should weld it in solid or have it removable. I don't necessarily need access to the trans and the bell housing bolts are easily accessible from the ground and of course there will be carpet and a shifter mounted.
  16. drumyn29
    drumyn29
    Finished all of my welding on the frame today(I hope).
    Nothing better than rattle can!
  17. ROADSTER1927
    ROADSTER1927
    Good move on the trans cover! I would still make it removable even if you think you will never need it. Thanks for a great thread, Gary:D:D
  18. drumyn29
    drumyn29
    The back yard build resumes.
    driveshaft, windshield frame, rear coil over shocks, steering box, pitman arm, steering column, seats, pedals, trunk hinges, rolled fenders.
    It's about ready to go to the leaf spring shop and then I can add the brake lines to the list.
    IMG_8834.jpeg IMG_9124.jpeg IMG_9172.jpeg IMG_9173.jpeg IMG_9174.jpeg IMG_9176.jpeg
  19. drumyn29
    drumyn29
    Rolling with the stock 33 tail light and headed to the shop Wednesday for a new front leaf spring.
    I also ordered up my entire clutch ***embly for the Fairbanks, ouch!
    elgringo71, RodStRace, Thor1 and 4 others like this.
  20. wrenchbender
    wrenchbender
    What seats are you using I have a pair just like that in my willys pickup but never knew what they were out of mine came from the attic of my dads shop your car is looking real good man
    Thor1 and loudbang like this.
  21. drumyn29
    drumyn29
    They are from a 1954 Triumph. I think I'll use them, it's small inside and these seem perfect. Thank you.
    Thor1, elgringo71 and loudbang like this.
  22. elgringo71
    elgringo71
    You are making some good progress and it’s got the right vintage parts. What motor do you plan to put in it and what parts are you still looking for ? For some reason when I look at it I think of the Pink Panther
  23. drumyn29
    drumyn29
    I don't think I need much other than sheet metal which Lee has but I haven't picked up yet.
    Definitely a Hemi. I'll probably mount my Delta blower drive to my magnesium bowers blower that is at Littlefield now.
  24. drumyn29
    drumyn29
    Rebuilt the rear bottom drivers corner today, p***enger tomorrow and final install of spare tile panel.
  25. wrenchbender
    wrenchbender
    Thanks for the info I know its small in there and that’s why they fit good in my pickup my truck is tight but your car is more narrow than my truck but I would think your car has more leg room than a pickup or maybe not lol.
  26. drumyn29
    drumyn29
    It took 4 months but I finally have an appointment for front springs.
  27. tomkelly88
    tomkelly88
    Thats a cool photo man!
    OahuEli, Thor1, The37Kid and 2 others like this.
  28. elgringo71
    elgringo71
    It’s coming along great, did they finish the front springs and what is the next thing that you need to do for it to move under it’s own power? Post a few more pictures of it. What was the reaction to it at the spring shop?
    loudbang, guitarguy and Thor1 like this.
  29. loudbang
    Hope you don't mind I had a little fun with the great photos. :)
    mad mikey, Thor1, The37Kid and 3 others like this.
  30. Mitchell Rish
    Mitchell Rish
    from Houston MS
    Cool build. Check out the trans cover/tunnel we did for the prefect. I made every mistake in the book before I got it right. If you build it like it’s a race car you typically build for every possible scenario. . Good luck and if I haven’t told you. Damn I love your hauler.
    kidcampbell71, Thor1 and loudbang like this.
