Best Degreaser
Discussion in 'The Hokey Ass Message Board' started by Carpet Bomber, Sep 14, 2006.
  1. DOCWHIT
    DOCWHIT
    Ok, getting a little confused since I'm reading soooo many different opinions on engine/parts degreasers...
    So I will show you my valve covers I removed yesterday & what ideas each of you have to degrease & clean these nasty SOB's.... 59valve covers.jpg 59valvecovers.jpg 59valve covers.jpg 59valve covers.jpg 59valve covers.jpg 59valvecovers.jpg 59valve covers.jpg 59valvecovers.jpg
  2. boring-hop-yard
    boring-hop-yard
    Greetings, if I were doing those: I would start by putting some cat liter in and soak up wet oil and get down to the stuck on crud, this will reduce the amount of liquid waste. Then I would keep them wet with wd40 during the day and let it soak over night. Then I would hit them with a strong degreaser. Out here in Oregon we have a store called "cash and carry" they have a red degreaser that I use, I have used most of the other and they work as well. I would pick one and go for it, weaker degreasers will still work, it just takes longer.
    Hope this helps
  3. Slide.Aint that the truth.LOL.Bruce.
  4. Docwhit...........nice set of 318 Plymouth Poly valve covers........and whats so hard about it?............I'd get a few paper towels or even a heap of toilet paper and wipe out the covers first to get rid of as much as possible then use mineral turpentine or WD40 or even straight petrol, anything to soften the crud first then spray a good brand of water soluble degreaser and stir the pot or covers with more degreaser and an old paint brush...........after its nice and runny then I'd hit it with a hard water jet............I would expect to repeat this a few times, also replace those valve cover gaskets, they will be ****..................ideally don't do this underneath the wifes just hung out clothes line or wear your Sunday go to meeting clobber, the older clothes the better..........lol.........either way from the condition of these covers I'd say that you haven't done an oil change in a while..........just think what the sump will have in it.............lol..............btw is this why you intend to put the hemi in the Coronet?.............andyd
  5. Hot Rods Ta Hell
    Hot Rods Ta Hell
    If those valve covers came off your running engine, you may be in for some engine work. Sludge may be taking it's toll by blocking oil flow through p***ages. Looks like you may have some water mixed in with the oil too?
  6. jackalope
    jackalope
    Greased Lightening is the best for heavy degreasing and cheap. Use it on tractor equipment all the time. Excellent stuff
  7. vtx1800
    vtx1800
    Personally, I used to use gas but now, since I am older, I use kerosene, I guess I am not as "green" as some folks, then when it is too funky to use anymore it goes into my burn ring for fire starter (note that the burn ring is used mostly for burning the paint off of various pieces of metal that my wife incorporates into her metal sculpture or just the limbs, etc that blow down out here where I live.
  8. jackalope
    jackalope
    We use diesel fuel for heavy stuff in our parts tank. I use Greased Lightening to wash that all off though afterwards.
    slowmotion likes this.
  9. 37gas
    37gas
    If your doing something like a small block Chevy I turn the valve cover over and put all my nuts and bolts in the valve cover and put paint remover in about a 1/2 inch deep, use a brush to move it around, when the parts are clean wash out with a garden hose. Nuts and bolts come out looking brand new, and so does the valve cover. I do the same thing with the engine block to ,paint the lifter area with paint remover and work it in with the paint brush and wash it out with a garden hose and it will look like new cast iron. Been doing this for over 45 years works great
    R A Wrench and vtx1800 like this.
  10. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Glad to hear you're no longer using gas. Just an FYI for youngsters or anyone not aware. Gasoline should NEVER, ever be used as a cleaning agent! It has a very low flash point and is extremely volatile. One spark from metal parts clanging together or an ignition point such as a nearby gas water heater and you'll be blown up w/o warning. Many people have been burned to death or had bad shop/house fires.
    It's right up there with using cinder blocks as jack stands! Stick to safety solvent or a good biodegradable solution for cleaning.
    ekimneirbo likes this.
  11. slowmotion
    slowmotion
    I'd clean those valve covers just like grandpa used to do, kerosene & an old paint brush. Finish up w/the fancy cleaner of your choice. (I'm partial to Purple Power 'cause it's cheap (like me)).:D
    jimgoetz likes this.
  12. max mariner
    max mariner
    The best type of degreaer that you should use is a spray degreaser because it is easy to use and it also gets cleaned up easily and most importantly it does not harm the parts of vehicle , I ahve been using spray degreasers for last 5 years and suggest you also to use it .
    RX Marine was established in 1996 in Mumbai, India; as chemical manufacturing company catering exclusively to the needs of the marine industry. In a short span of 12 years the company has established itself as one of the leading wholesale suppliers of a wide range of chemicals for - Marine industry internationally - and other local industires and plants. Our client list bears testimony to this. The RXSOL policy has its foundations on two pillars of strength - a continuous investment in research and development to deliver premium quality products and a commitment to service.
    Degreaser
  13. Chappy444
    Chappy444
    I have had good luck with the following items (depending on the parts being cleaned):
    simple green
    greased lightning
    that orange stuff
    spray on oven cleaner
    gas
    kerosene
    engine brite (gunk product i think)
    paint prep degreaser (prepsol or something like that)
    JP-5 worked great when I was still in the navy and could get it (i guess it's just a Kerosene variant)
    the wheel and tire cleaner at the local high pressure wand car wash
    lots of rags, a couple of s****ers, and some wire brushes...…
    Chappy
    stillrunners and lothiandon1940 like this.
  14. I use a product called Oil Eater and it is a biodegradable product . Available at Oreillys auto parts store. Been using it for over 3 decades and works great.
    Vic
    LAROKE likes this.
  15. error404
    error404
    from CA
    Don't know if it's been mentioned before, but LA's Totally Awesome (goofy name, I know) from the dollar store is pretty good, and very cheap. Like, cheaper than bottled water, haha!
    stillrunners likes this.
  16. LAROKE
    LAROKE
    Another vote for Oil Eater and biodegradable or not. It is strong. It will eat paint and aluminum as well as grease if you leave something soaking in it too long. I use it in my parts washer and as a spray on.
    lothiandon1940 likes this.
  17. Hemi Joel
    Hemi Joel
    from Minnesota
    Thanks a lot for that one pal. My wife was ready to divorce me when she saw what it did to the bedroom carpet!
    X-cpe likes this.
  18. Blues4U
    Blues4U
    from So Cal
    Truckdoctor Andy likes this.
  19. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Doesn't anybody take them to the car wash anymore?
    I'd s****e the inside of the valve covers a little then take everything to the car wash. A couple of saw horses will help for the block and heads. Then take em home and put the cleaner of your choice on whatever the high pressure spray didn't get. Wear some old clothes when you go to the car wash. ( I got a good pressure washer now.......)
  20. wheeldog57
    wheeldog57
    Gunk engine brite in a spray can, that stuff has worked for me on every car I've owned.
    ****! I just realized I have been driving for 37years, I feel old.
    03GMCSonoma and stillrunners like this.
  21. donno
    donno
    Can't use a pressure washer in 'Vegas, so I get that Orange stuff from the Dollar store. Up on stands, free card board from the same Dollar store. Spray on the Orange stuff, let it drip on the card board. (most of it evaporates, what dosen't soaks into the card board.) Fold the card board up, recycle.
  22. Well, depends on the brand of cleaner. I like Castrol Super Clean (also available in 5 gal jugs from Wally World) and Simple Green, but I tried the stuff Harbor Freight in my small, bench top parts washer I use strictly for carbs and such, and wasn't that impressed with it. Also, it rusted out the parts washer from the inside out in about a year.I imagine that might be a problem with any of the water based cleaners though, so I don't store it in the new washer when not in use. I stretch an old pair of my wife's hose over a funnel and strain out any solids as I pour in back into the original jug to store.
    Sent from my SM-G955F using The H.A.M.B. mobile app
  23. 6sally6
    6sally6
    I would fill the VC's with paper towels first...........then soak'em really well with kerosene...........
    then throw a match on'em and burn all the grease out of them. AFTER they are cool...........finish'em up with Brakleen.
    6sally6
  24. bobss396
    bobss396
    I like mineral spirits in a safety kleen type washer best. Kerosene is what my dad used. Oven cleaner I have used on engine blocks, need to use the nasty dollar store stuff. Gunk is good on engines in the car.
  25. Blues4U
    Blues4U
    from So Cal
    I guess you take them outside for this? :D
  26. Blues4U
    Blues4U
    from So Cal
    What do you do with the stuff after it's fully saturated with oil and particulates?
  27. Mike Rouse
    Mike Rouse
    When I was just starting out messing with motors in the 1960’s I had a wheelbarrow and I would fill it with water and add a few cans of sodium hydroxide. I learned early on to not put any aluminum parts in the wheelbarrow. I would leave the greases parts (steel) in the mix till they were clean. Brushing occasionally with a nylon brush. I cleaned many greasy parts this way. Cover the wheelbarrow to prevent rain diluting and overflowing. This method still works today. Use gloves.
  28. Sporty45
    Sporty45
    I got to tell ya, I saw this post and just had to give it a try. I went to the local dollar store and they had it in 64 OZ bottles for $3, so I bought two of them. Figured what the hell, not much to lose. Got it home and tried it out on some old really greasy and dirty heads I had kicking around, and was very happily surprised with the results. I sprayed it on and lightly scrubbed with a stiff nylon brush and the crud just kind of melted off! Good stuff, and damn cheap. Gonna make sure to keep some of this stuff around. Thanks for the tip :cool:
  29. Gasser 57
    Gasser 57
    from New Jersey
    I just bought a couple cans of Crown PSC 1000 Parts Cleaner from Tractor Supply for my parts washer. Cost about $42 per 5 gallon can. I was doing some research online to decide what to buy and this stuff had pretty good reviews.
