Technical What's a Good "STREET" Solid Cam of a Chevrolet 454......
Discussion in 'The Hokey Ass Message Board' started by Elcohaulic, Jan 7, 2020.
  1. Elcohaulic
    Elcohaulic
    My car has a 1978 Chevy 454 with 781 heads. Its all stock and never been touched. It also has a TH-400 with a 2.73 rear end...
    I'm looking for a nice solid cam for this engine.. Nothing crazy, no lumpy idle. I'd like to have 18-22" of vacuum at idle.. A wide lobe separation with smooth lobes..
    What solid cams have worked well for you..
    Thank you...
  2. oldiron 440
    oldiron 440
    Sounds more like hydraulic cam territory......
    porknbeaner, badvolvo, RmK57 and 2 others like this.
  3. dan c
    dan c
    i responded to a similar thread earlier. i was looking at a 302 ford and found modern takes on the old hipo mustang cam, sweet spot 1,800-5,800, but most of what i found was track cams that aren't happy until 3- or 4 thousand rpm.
  4. squirrel
  5. KoolKat-57
    KoolKat-57
    from Dublin, OH
    Why a solid lifter cam?
    KK
    lumpy 63 likes this.
  6. lippy
    lippy
    from Ks
    That looks like a good choice Jim. Lippy
  7. Elcohaulic
    Elcohaulic
    Appreciate the help but the last Comp XE cam I dealt with had to be cut out of my buddys numbers matching Mopar block. Man was he pissed. That thing was as flat as a broomstick after 2000 miles.. Even when new it never ran worth a damn. I could never tune that flat spot out of it at 4500 rpm.. It never did this with the old Mopar cam it had.. Over in Pontiac land they've had all kinds of issues with the XE Series cams. But it seems like Chevy folks like them..
    I have had good luck with Crower, Isky, GM and Summit..
  8. lumpy 63
    lumpy 63
    The .500 lift Chevy L72 cam is a good street cam but honestly with the 454 combo you have I don't really see the point . With the compression ratio and heads + the gear you have a mild hydraulic is a much better choice.
  9. Tooth
    Tooth
    from Missouri
    Sealed power used to make a hydraulic RV cam that I put in my 78 1/2 ton towing truck,It had a stock converter with a 400 turbo with a 308 gear. It had a nice idol to it tons of low and mid range torque.
    I drove it everywhere with no issues, I could even pull my Camaro or my Chevelle with the trailer and it would bark second gear no problem. LA salt flats knows the old truck well and it had a $60 camshaft and $40 lifters. Lash was zero with a half a turn. All stock length components. I’m sorry I don’t remember the part number but it was listed as a RV duty camshaft. Good luck!
    Elcohaulic likes this.
  10. bowie
    bowie
    I really like the GM 427/435 cam in my OT ‘68 Vette . Can’t answer the vacuum question, but my vacuum headlights and vacuum wiper vent always have worked well.
  11. bobss396
    bobss396
  12. Elcohaulic
    Elcohaulic
    That L72 looks interesting. Since I have more cubes then 396/427 I wonder how rowdy it would be, I want low end torque. It does have a 114 lobe separation with Adv . 316/302 @50 242/242 with a .520/.520 lift... It comes form Crane as the 969961 and Comp as the 11-106-3...….
    I'd like to keep the adjustment close, I like the sound of solids but not loose ones..
  13. badvolvo
    badvolvo
    Call Bullet or the cam grinder of your choice. They will grind the cam to fit your needs, and it's not much more than an off the shelf camshaft. Tell them what you have, and what you want.
  14. 4speed411
    4speed411
    Ran a Crane 461 lift solid 1500-3800 cruise Rpm with a power band to 5800...850 Holly...drive anywhere...run high 11's in the 1/4 mile in a Chevelle...
