Technical Heat gun recommendations??
Discussion in 'The Hokey Ass Message Board' started by hotrodA, Jan 7, 2020.
  1. hotrodA
    hotrodA
    I've decided to quit using the cheesy pre-insulated wire terminals and start using heat shrink tubing. What's been your heat gun experience and what brand do you recommend? Thanks!
  2. error404
    error404
    from CA
    I like using a battery powered heat gun for shrink tubing. Milwaukee M18 in my case, since that's the batteries I have. Unlike my other corded heat gun, I can easilly set the Milwaukee down up right on it's battery, and not worry about setting down the heatgun on the floor and potentially setting the hot tip down on something. (I've melted more than one power cord this way...)
    It's a bit bulkier (because of the battery) than a corded one, but it doesn't bother me.
    If all you're going to be using the heat gun for is shrink tubing, I would say any cheap heat gun will work, you don't need one that goes to 1200 degrees.
    My other two heat guns, one is an old wagner, with 2 heat modes (high and low) that was my fathers, and I also have a newer "digital" wagner where you can choose the temperature, and it also has a "cool down" function that keeps the fan going until the heating elements cool down. It can get very hot, 1300 degrees or so, which can be nice in some situations. Obviously not needed for shrink tube though. Most common shrink tube only needs a few hundred degrees to shrink.
    All 3 of them work perfectly fine for shrink tubing. :)
    And a note on shrink tubing, if you haven't tried using adhesive lined double wall shrink tubing, you might want to give that a try. It's a bit more expensive, but it makes a very durable and completely waterproof cover. It's just about permanent though, so you can't really go back and cut open the shrink tube if you need to get back to the connection for whatever reason.
    alanp561 and upspirate like this.
  3. oldiron 440
    oldiron 440
    Anyone ever use a micro torch?
  4. sawbuck
    sawbuck
    from 06492 ct
    i use a micro torch ...never tried a heat gun
  5. Sporty45
    Sporty45
    cpd682 and papajohn like this.
  6. leon bee
    leon bee
    Box of barnburner matches will fix you right up.
    I've bought a number of heat guns over the years, I now look for the lightest, cheapest one in town.
  7. David Gersic
    David Gersic
    from DeKalb, IL
    I’ve burned up a couple of cheap ones. Everyone seems to sell essentially the same gun, only the plastic colour changes from one to the next. The first one came from HF, with a bunch of attachments I’ve never used, and a blow mold storage case. Each replacement has come with more of the attachments, and has fit fine in the blow mold case for storage.
  8. Joe Blow
    Joe Blow
    I always use a reflector with a run of the mill Wagner, for shrink tubing.
  9. bedwards
    bedwards
    Have HF one that I use for just that purpose for years. Bought on sale for 9 or 10 bucks
    JeffB2, warbird1, upspirate and 2 others like this.
  10. KoolKat-57
    KoolKat-57
    from Dublin, OH
    I've had very good results with my Wagner dual temperature heat gun.
    I use the lower setting for heat shrink tubing.
    KK
  11. I’ve used both, torch and heat gun. I have a cheap heat gun from the Harbor and it works great. I also use a mini torch at work.
    JeffB2 likes this.
  12. woodiewagon46
    woodiewagon46
    from New York
    I have been using a Milwaukee heat gun and I can't say anything bad about it. I don't know about you guy's but everytime I tried using a touch, the shrink sleeve looks like ****.
  13. Mimilan
    Mimilan
    If you want the best , then get a "Leister ch-6056 kägiswil" but be prepared to pay $300+ [for a used one]
    https://www.ebay.com/p/2079247540?iid=202828246526
    when you mentioned "I’ve burned up a couple of cheap ones." Do you run the gun through a cooling cycle before you switch it off?
    Even on my expensive Leister , I always turn the heat back to Zero and keep the fan motor blowing until cold air comes out..... Then I switch it off.
    This is the difference between 15 minutes life expectancy and the 20 years I've had from my Leister on the same element.
  14. nochop
    nochop
    from norcal
    I like electric heat guns for that. Flames for cigars
  15. LM14
    LM14
    from Iowa
  16. David Gersic
    David Gersic
    from DeKalb, IL
    Nope. These are cheap tools, with “high” and “low”, and off. There’s no real temp control, and no cool down cycle. Turn it on, point it at the heatshrink, wait a few seconds for it to do the job, and turn it off again.
    The current one looks like this:
    But you can find the same level of quality at Harbor Freight, Lowes, Menards, or Home Depot.
    Usually what happens is that the porcelain insulator starts to crack and break. Once that starts, the gun is doomed.
    I have to admit being intrigued by the cordless electric ones now, though. Would be nice to not have to tangle with cords.
    Early Ironman likes this.
  17. krgdowdall
    krgdowdall
    from Alberta
    Pick up a a BBQ lighter at the dollar store . About $3 - $4.00 It heats up quickly and shuts off when you put it down. Better than burning your fingers with your Zippo. A heat gun works great if you are doing production harness work.
    harpo1313 likes this.
  18. Fortunateson
    Fortunateson
    Production run is the key I think. When I tackle a new home made harness I think I will save any of the heat shrinking to the bitter end and do them all at once. I say say "bitter" as I know that this will be a battle on par with Clash of the ***ans!
  19. evintho
    evintho
  20. 5window
    5window
    Another vote for the HF gun. They work fine for me.
  21. 41rodderz
    41rodderz
    from Oregon
    Ditto ^^^^^ Great gun:)
    upspirate likes this.
  22. upspirate
    upspirate
  23. razoo lew
    razoo lew
    from Calgary
    I bought a less than twenty dollar one about 4 years ago. For that price I didn’t worry about whether it was the best one or not.....
  24. stanlow69
    stanlow69
    I don`t know if the salesman messed up or not, but I bought a Bosch Model 1942 from Fastenal for about $85 about 5 years ago. I use it all the time. Quite a few steps up from a cheapy model.
  25. Ziggster
    Ziggster
    I have an older Milwaukee this has served me well for over 10 yrs without issue. It has been banged, kicked, and dropped but keeps working. Simple, hot, cold, off, but that is all you need. You are not cooking with a heat gun, or blow drying your hair. Can't say if newer versions are as good, or if cordless is better.
    1934coupe likes this.
  26. 1934coupe
    1934coupe
    Ditto on the corded Milwaukee heat gun. Have had mine over 20yrs. made in USA.
    Pat
  27. southcross2631
    southcross2631
    I have had my HF heat gun for about 6 years and it works great. Sometimes I don't feel like getting out a cord and the gun I keep a bbq lighter in the top drawer of my tool box. Works fine .
  28. BamaMav
    BamaMav
    from Berry, AL
    Ditto, but I like the clear Chinese lighters better. You can adjust the flame level on those!
    olscrounger likes this.
  29. Model A Gomez
    Model A Gomez
    I use a Harbor Freight mini torch, was around $15 and works great.[​IMG]
  30. bobss396
    bobss396
    I bought a HF one about 5 years back, works fine. Got it for $9.
    Chappy444, JeffB2 and 5window like this.
