Projects Original paint coupe
Discussion in 'Traditional Hot Rods' started by duncan, Jun 30, 2016.
  1. Frame work and pan to cover the Model A crmbr to clear the quickchange. [​IMG][​IMG]
    Thor1, Shadow Creek and Elvis100 like this.
  2. banditomerc
    banditomerc
    How did I miss this thread....love it...
    kidcampbell71 likes this.
  3. Duke
    Duke
    Looks good, is that paint on the grill?
  4. dumprat
    dumprat
    from b.c.
    Ron, please get very good at straightening those bars, maybe then you can show me how to do mine.
  5. Just on the chin, to cover the br***.. Good from far, far from good.
    Thor1 and loudbang like this.
  6. Thor1, loudbang and ss34coupe like this.
  7. Bugguts
    Bugguts
    Great job so far. Just read the whole thread and enjoyed it all. Thanks for sharing your work. I’m looking forward to more.
  8. [​IMG][​IMG]
    Thor1, 19fuelie57 and loudbang like this.
  9. Thor1, Nailhead A-V8 and loudbang like this.
  10. I can’t say enough good [​IMG]about the wood kit I got from Brad Brown in Friday Harbor WA. Fits perfectly without cutting, beautifully finished, with quality fasteners. I highly recommend him.
    bradswoodshop@hotmail.com
  11. Nailhead in a 34. It can be done, but it isn’t easy. When you have a large starter (I just can’t bring myself to use a compact gear reduction unit) an F-1 steering box and clutch linkage, vying for the same 12 sq. in. Of space, it gets crowded. I’ve found it necessary to move the engine/trans centreline 3/4” to the right. It isn’t noticeable unless you really study it, but it is what it is. This gives me 1/2” between the steering box and starter. [​IMG][​IMG][​IMG]
    Thor1, Rich B., mkebaird and 4 others like this.
  12. dumprat
    dumprat
    from b.c.
    And that's why I have an adapter to move my starter to the right side
  13. Yes, but your hemi is wider and an adapter is made. I’ve not seen one for an early nailhead. Just need more improvisation.
  14. dumprat
    dumprat
    from b.c.
    And my steering box is a little larger.
  15. What box are you using?
  16. dumprat
    dumprat
    from b.c.
    Super rare F1 export only to Japan , left hand drive recirculating ball.
    (83 Toyota 4x4 lol)
    Nailhead A-V8, brEad and loudbang like this.
  17. Thor1, Nailhead A-V8, brEad and 3 others like this.
  18. Column drop. [​IMG]
    Thor1, 48fordnut, dumprat and 3 others like this.
  19. loudbang
    That is so COOL :p
  20. brEad
    brEad
    I like your defrost vent.
  21. Thanks, defrost is one thing we need up here, wipers, another.
    loudbang and 29EHV8 like this.
  22. [​IMG]
  23. Getting anxious to get the final few details wrapped up and get the body off for paint. Getting close to that. The model A brake actuator arm above, attaches to a cross brace from post/post to support the dash and add rigidity.
  24. dumprat
    dumprat
    from b.c.
    How's it coming along Ron?
  25. Doing some final body fabrication ADBB8454-7C54-4B17-8168-96CB95486C8E.jpeg F2C3808F-2740-45A3-9879-C56B12C8A7A6.jpeg
  26. F0111DDE-D11E-46FB-8B60-4C5757627E0C.jpeg 8DF355C0-1AEB-4A72-B42A-13197F5EF4F8.jpeg I’ve been working on a few things, just haven’t taken the time to post..here goes. Front axle is a V8-60 tube, spindles are round back with dropped steering arms, just sneaking under the lower hairpin link. Wishbone knuckles are 38, paired down on the miller to a nice thickness. The steps in the machining will be ground flat and blended. The spring will be behind the axle 2.5” and the perch 2” below stock height. I made the template today to have the batwing plates CNC Laser cut from 3/8” then it can all be welded together and finished.
    Thor1 likes this.
