Hot Rods Roadster build.
Discussion in 'The Hokey Ass Message Board' started by bct, Oct 21, 2015.
  1. bct
    bct
  2. alchemy
    alchemy
    See if there are serial numbers stamped in the upper pad.
  3. bct
    bct
    Fitting some pads under the sub frame to spread the load. I can mount the back half of my body now that I've located my rear. Lol
  4. bct
    bct
    Opinions please. Structurally it is in a great spot.
    Stogy, 1biggeorge and chryslerfan55 like this.
  5. bct
    bct
    1578510063076893098087835614322.jpg everything want to occupy the same spot. I dont mind , easy to brace
  6. bct
    bct
  7. You talkin ta me?, are you talkin ta me?, there’s nobody else here so you must be talkin ta me.
    Stogy and bct like this.
  8. bct
    bct
    Moved it back
    .25 looks better
    chryslerfan55, Stogy and 1biggeorge like this.
  9. bct
    bct
    he looks apprehensive because he has his shock collar on. the ONLY time he does what he is told.
  10. bct
    bct
  11. bct
    bct
  12. bct
    bct
  13. bct
    bct
    Found the roots of all the trouble. Warped door and twisted foot on the a pillar. Tweaked itwith a weld on handle
  14. 51box
    51box
    from MA
    Looking good @bct it ain’t easy to get to this point
  15. bct
    bct
    I hope 1/4" is enough for speedway roadster latches.
  16. bct
    bct
    Bit of work on my firewall.
  17. bct
    bct
    20200223_151659.jpg little by little.
    20200218_171841.jpg sheet metal fun with my kid.
  18. bct
    bct
    Im glad i made this firewall before locking it down to subframe. It pushes the cowl band flange outward. This is good but it may have an affect on the A pillar. Easy to modify now. I better get my dashboard in soon too.
    Stogy likes this.
  19. rusty_bits
    rusty_bits
    I like your build.
    chryslerfan55, Stogy and bct like this.
  20. bct
    bct
    Thanks neighbour. Hope you are enjoying the mild winter too.
    Stogy likes this.
  21. bct
    bct
    Made a frame table of sorts . Level and square now .
  22. bct
    bct
    Bob drake 32 engine support brackets replaced the tardel mounts . Unfortunately the box is touching the manifold .
  23. 303racer
    303racer
    How close is the lower radiator hose going to be to the bolt and the outside of the mount ?
    Stogy likes this.
  24. bct
    bct
    I have to lengthen mount bolts by half inch and use a thick .375 spacer at the bottom to lift the engine at least a .25 . Its not as bad as it looks in picture. The crossmember is actually more in the way .
    Stogy, dana barlow and 303racer like this.
  25. RICH B
    RICH B
    I remember having to grind the top edge of those '32 mounts for fan belt clearance; how does yours look?
    bct and Stogy like this.
  26. bct
    bct
    I will too . Also a bit of work on the front cross for pulley clearance
    Stogy and dana barlow like this.
  27. bct
    bct
    20221225_121500.jpg 20221225_121514.jpg 20221225_121524.jpg 20221225_161820.jpg
    Screwed up the old panel twice trying to flange above gas tank . Too straight first time to much curve the second . Spent a long time filling taillight holes for nothing. Made a new panel . Deck lid has never fit so well. 20221225_161831.jpg
    Stogy, RICH B, The37Kid and 1 other person like this.
  28. bct
    bct
    Mounted gas tank and rear shocks too . Modified front 1932 engine mounts by lengthening bolts and spacing mounts half inch up .
    Stogy, Bondo Slinger and 1biggeorge like this.
  29. The37Kid
    The37Kid
    Nice to see you kept the '32 tank.
    Bob
  30. LCGarage
    LCGarage
    I would really like to buy a pair of the cowl post tops from you. Building a 29 RPU from a pile of s**** parts. Converting a closed car cowl to roadster, have all the pieces now, but the cowl posts are missing the tops. Thanks!
    Stogy likes this.
