Projects Newbie first AV8 build
Discussion in 'Traditional Hot Rods' started by Justin Niven, Dec 31, 2019.
  1. Justin Niven
    Justin Niven
    from Toano, Va
    Hey guys I'm a new guy from Williamsburg Va. Just starting my first build. I bought a 1928 Tudor a few years ago and have been driving it around stock ever since. It didn't take long to realize stock isn't for me. I don't have much space to work in an have a garage full of fenders and a banger I have to get rid of but I'm gonna do my best. Any help would be very appreciated. 20190719_112535.jpeg 20191231_114631.jpeg
    Sent from my SM-G920V using The H.A.M.B. mobile app
  2. evintho
    evintho
    That's quite the starting point! Not much rust repair or bodywork in your future! What are the plans?
    BTW, I see a fully finished garage in the background. Might I suggest, set aside a day or two for cleaning and organizing. Looks like you'd have quite a comfortable shop to work in.
  3. Justin Niven
    Justin Niven
    from Toano, Va
    I'm planning on a flathead traditional style build. Nothing unusual for the guys on here. No plans for a chop now. Just finished the F-1 steering box today. 20191217_125957.jpeg 20191220_121225.jpeg 20191231_123702.jpeg 20191231_123712.jpeg 20191231_123722.jpeg
    Piewagn, 31hotrodguy, bymanr and 6 others like this.
  4. 2935ford
    2935ford
    Ah, more fun in the works! :)
  5. Ryans65
    Ryans65
    from Yulee FL
    Hello from down the road! Nice color combo on that rig.
  6. ramblin dan
    ramblin dan
    Sweet ride. It will be a real head turner.
  7. pkhammer
    pkhammer
    That's going make a great Highboy! If you want to get rid of the stock parts PM me and let me know, I'd be interested.
  8. 5280A2
    5280A2
    I would recommend that you seek out and purchase Vern Tardell's book on building an AV8. The subject vehicle is a Tudor just like yours and it covers every aspect of a traditional AV8 build in great detail. I think you would find it well worth the money for your project, even if only for the trial and error it will eliminate.
    31hotrodguy and upspirate like this.
  9. Tall t 26
    Tall t 26
    Very clean ride. Gonna be a cool build.
  10. dirt t
    dirt t
    Welcome to the best place on the internet.
    I also recomend Vern"s book.
  11. Justin Niven
    Justin Niven
    from Toano, Va
    Thanks guys. I'll keep you posted on the progress. Hopefully I can get my 12 year old son off the video games and interested in working in the garage with his old man.
    31hotrodguy likes this.
  12. Tall t 26
    Tall t 26
    That will be rewarding for you both. Good times!!
  13. RMONTY
    RMONTY
    Tell him to come help you work on "his" car!
  14. cederholm
    cederholm
    Very cool! I'm on the same quests with a '30 Coupe.
    ~ Carl
  15. Rustygt
    Rustygt
    from Emeryville
    Verns book !!!!!!!!!!!!!!
  16. Justin Niven
    Justin Niven
    from Toano, Va
    I got the body removed. That was a very sketchy job to do alone with a jack, some wood and a few jack stands. Next time I'll grab a case of Budweiser and call a few of my buddies. I also cut the rear of the frame and stepped it. 20200108_125107.jpeg 20200113_114753.jpeg 20200114_125005.jpeg
  17. sloppy jalopies
    sloppy jalopies
    IMO... get a good straight edge and check for sag... usually at the front motor mount...
    now is the time... easy fix... later on ?
  18. Aaron D.
    Aaron D.
    Great job on the step, looks really good.
  19. 33Doll
    33Doll
    Awesome!
    There is so many stock restored “A” s out there fairly cheap, and easy to turn into a traditional Hot Rod Ride! Just don’t tell the old fart you’re buying one from! Tell him its for parades! Lol!
    JUNK ROD and Chopp'd49 like this.
  20. Justin Niven
    Justin Niven
    from Toano, Va
    Can you please explain what "sag" you are referring to.
  21. sloppy jalopies
    sloppy jalopies
    the weight of the body ends at the firewall... the motor mounts end just ahead of that...
    it is a pressure point and sometimes is rusty behind the MM plate... makes a weak spot.
    if it is sagged you will go nuts trying to get hood gaps right...
    I have seen a half dozen boxed frames "cheap"... because they were sagging when boxed and now are for hoodless rods only.... check it... if straight, rock on !
  22. JUNK ROD
    JUNK ROD
    sweet ill be following!
  23. 31hotrodguy
    31hotrodguy
  24. getow
    getow
    Thumbs up. Im interested.
  25. Hey neighbor! I am also in Williamsburg, and just finished up a 4 year build on my 53 Ford. May be able to give you a few pointers from time to time. Also have a 59A Flathead lying around. Welcome to the HAMB.
