Projects Seagrave 531 V12 Special BuiLd Up in Brazil
Discussion in 'Traditional Hot Rods' started by Drmalacarne, Sep 5, 2019.
  1. catdad49
    catdad49
    Man, can't wait to Hear this! Love those tips.
    Stogy, chryslerfan55, Jeff34 and 2 others like this.
  2. woodbutcher
    woodbutcher
    :D Looking better and better all the time.Merry Christmas Sir.
    Good luck.Have fun.Be safe.
    Leo
    Deuces, Stogy, loudbang and 3 others like this.
  3. Blackbob
    Blackbob
    I have just sat and read the whole thread through.. WoW!! Fantastic job, can't wait to see the finished car :)
    Deuces, loudbang and chryslerfan55 like this.
  4. manyolcars
    manyolcars
    Dr. MalaCarne---Dr. Bad Meat??
  5. 1-SHOT
    1-SHOT
    from Denton
    Very Impressive
    Deuces and loudbang like this.
  6. 282doorUK
    282doorUK
    I’ve always loved this era, with all the m***ive experimental cars built by privateer drivers, all trying to win at all cost with apparently total disregard for personal safety.
    With your car you’re carrying on that tradition magnificently, but hopefully without the dangerous bit!
    It feeds my needs :D
    I’m building a 1928 Chevy racer in similar style but quite a lot smaller, and am at the point where I have to shorten and adapt the tourque tube and drive shaft, something like the way you’ve done yours.
    So could you explain how you stopped the solid shaft from bending when you welded it in the middle please?
    I understand you made the cut ends cone shaped, but did you make a bore in one end and a spigot in the other then press together before welding, or use some other method?
    What type of welder did you use, MIG, TIG, or Oxy acetylene?
    I think a torque tube is much safer than an open drive shaft in this sort of car, and it’s wise to keep it, but because of the extra strain on the UJ, do you intend to put a safety hoop around the end of the tourque tube in case
    the UJ breaks up?
    Thanks for showing us your work, it’s very inspiring!
    Here’s a pic of my ’28 Chevy Racer as it so far, except it now has two exhaust pipes all along the side, one above the other.
  7. Blackbob
    Blackbob
    love that, great job! I'm hoping to get myself a '28 Chevy motor for a racer project in the next month. Have you got a build thread for this car?
    chryslerfan55, Deuces and loudbang like this.
  8. WC Durant
    WC Durant
    282doorUK, that's a cool Chevy. Any update on the Seagrave? Starting to go through withdrawals...
  9. Drmalacarne
    Drmalacarne
    Hi to all.
    I’m in vacations and next week I’ll come back to Brazil and send updates.
    Gui.
    Enviado do meu iPhone usando H.A.M.B.
    Thor1, chryslerfan55, Deuces and 7 others like this.
  10. Drmalacarne
    Drmalacarne
    Great job! I love the skinny shape!
    The solid driveshaft was welded in a big lathe, with constant alignment conference.
    Thanks!
    Gui
  11. trikejunkie
    trikejunkie
    from Scotland
  12. pumpman
    pumpman
    I've been following your impressive build from the start. Not sure if this has been asked. Are you building this monster for your evil intentions or is there a small king (customer) that needs an ego boost?
  13. Drmalacarne
    Drmalacarne
    Hi!
    First ideia.
    Gui
    Stogy, chryslerfan55, Deuces and 2 others like this.
  14. 282doorUK
    282doorUK
    Thanks Bb, sorry no build thread, you have a PM.
  15. Drmalacarne
    Drmalacarne
    ffb4a4fa-9f95-458f-94ab-995666ce5336.jpg b42b9911-8f11-4a2a-8697-938b6e331422.jpg
    Radiator hoses done.
    Almost time to start the engine again and make some noise on the streets.
    dwollam, Thor1, Stogy and 18 others like this.
  16. ClayMart
    ClayMart
    ...Add trikejunkie to the D.I.Y. Friction Shock Club. ;)
  17. Rickybop
    Rickybop
  18. roseville carl
    roseville carl
    nice bends.............
    Deuces, loudbang and Drmalacarne like this.
  19. Deuces and loudbang like this.
  20. Drmalacarne
    Drmalacarne
    37119a5b-72ea-4a4a-876c-2141095ff536.jpg 7d3369c2-6354-4b82-b5db-6546c9029e52.jpg
    Last works on the body before painting.
    brEad, 41 GMC K-18, Squablow and 19 others like this.
  21. v8flat44
    v8flat44
    Still love'n it
    loudbang, Drmalacarne and Deuces like this.
  22. abonecollector
    abonecollector
    Man, i love a good restoration as much as a good hot rod/custom build. Pretty cool build going on over there. But, honestly, i don't know how you can possibly get anything done, with all those Brazilian women just outside your door
  23. Drmalacarne
    Drmalacarne
    That’s true! We have beautiful women here in Brazil! Thanks! Gui
  24. Rickybop
    Rickybop
    brEad, loudbang and raven like this.
  25. Drmalacarne
    Drmalacarne
    Dashboard layout done.
    Now we’ll cut a 6mm stainless steel plaque to make the base to the clocks.
  26. Drmalacarne
    Drmalacarne
    IMG_3449.JPG IMG_3450.JPG IMG_3451.JPG IMG_3452.JPG IMG_3453.JPG IMG_3454.JPG IMG_3455.JPG IMG_3458.JPG IMG_3459.JPG
    Pictures of today.
    Next Saturday we are planning to start the engine again and take a ride around the block.
  27. tubman
    tubman
    Make sure you make a video including sound! I want to hear the exhaust note (I still love them exhaust tips!).:)
    6-bangertim, Thor1, Okie Pete and 3 others like this.
  28. Drmalacarne
    Drmalacarne
    Ok!
  29. JUNK ROD
    JUNK ROD
    killer tail pipes!!!!!
  30. e1956v
    e1956v
    Alliance Vendor
    What is that speedometer out of?
    www.speedoservice.com
    Should I rush your rush job or the rush job I was rushing when you rushed in?
