Hot Rods 34 ford 3w made entirely from junk!
Discussion in 'The Hokey Ass Message Board' started by JimSibley, Dec 30, 2019.
  1. Bandit Billy
    Bandit Billy
    Apparently I need to spend more time in the 'kane. Nice progress Jim. Go Zags!
    Stogy and loudbang like this.
  2. JimSibley
    JimSibley
    FA28DF4A-E6F2-4141-B7D9-8897610DD303.jpeg 8641FB98-9BB2-4C7B-99CC-35840CB16116.jpeg Just a little progress. Rear suspension
  3. Tom Sherry
    Tom Sherry
    Very cool.
  4. j hansen
    j hansen
    Really nice.
  5. slayer
    slayer
    I bet you can turn goat piss into gasoline! Every build you post here is beyond impressive, turning parts most builders would s**** into awesome cars.
    loudbang, Thor1 and 427 sleeper like this.
  6. nrgwizard
    nrgwizard
    from Minn. uSA
    I don't know... I think that perfectly metal-finished & cleared on the outside, w/all the welds showing the seams & patching on the inside, would cause a whole lot of folks to either be speechless or walk away mumbling to themselves for a very long time... :D . Esp when everything else was finished properly in paint/chrome.
    Jim, you really do good work.
    Marcus...
    brEad, loudbang and JimSibley like this.
  7. JimSibley
    JimSibley
    Thanks Marcus, I love a clear coated raw car. The whole time I have been thinking about this car I have pictured it in a navy blue with all of the ch***is a light grey. We will see what it turns into. I kinda like the car to “ build itself “ and evolve as it grows.
    loner2, kiwijeff, Phillips and 6 others like this.
  8. Rocky
    Rocky
    Classified Editor
    Oh, my!
  9. Deuce Bob
    Deuce Bob
  10. ken1939
    ken1939
  11. patmanta
    patmanta
    from Woburn, MA
    SUBSCRIBED! I dig what you're doing here.
  12. Lloyd's paint & glass
    So why the tube frame? Why not a traditional set of rails? Are you building it to p*** a sanctioned inspection or just for the salt flat look?
    Tman, loner2, chop job and 1 other person like this.
  13. 8flat
    8flat
    Sibley you glorious SOB that is going to be rad
    loudbang and kidcampbell71 like this.
  14. JimSibley
    JimSibley
    I’m building it entirely out of junk that I have. The tubing is left overs from a tube ch***is Willy’s aero that I helped on. For a front end I will be using a dodge wavy axle that I found on my property. Rear end is out of a 1969 ford truck that a friend rolled. Motor is a 327 that I bought for another project and never used, trans is a power glide that I never got around to taking to a swap meet. My goal is a wild ride that runs hard and cost less than 50000$ to build. All of this with a finished look and a quality build.
  15. 2deuces64
    2deuces64
    I like this kind of build, and why I haven't seen this thread till today is beyond me. I'm going to have to pay more attention! I'm in for the ride.
  16. racer756
    racer756
    Jim Sibley is a hero!
    kiwijeff and loudbang like this.
  17. texkbc
    texkbc
    more please!
  18. 2deuces64
    2deuces64
    Stogy, loudbang and 32SEDAN like this.
  19. -Brent-
    -Brent-
    YES! Love this!
    This car is going to be killer!
  20. ***Area-51***
    ***Area-51***
    from Ohio
    the Chevy is a cool car....I'm sure this one will be a hit out of the park.
  21. catdad49
    catdad49
    The Amazing Mr. Sibley, what else is to said?!
  22. JimSibley
    JimSibley
    Side window height is 6 1/4 inches, as is the windshield. Back gl*** is 4 1/2.
  23. JimSibley
    JimSibley
    D5043712-0498-4841-9492-058BBF850643.jpeg 9DF84DC6-D0DE-4848-954B-844BF02A9C74.jpeg 0D341031-5EA3-4495-946D-EB594D19057A.jpeg 4FB6DCC4-3775-4FFB-8561-6DD63457076C.jpeg 6C21F1B5-E828-4CED-B680-F108A3AED01A.jpeg Front end work. Took a bent up 40 ford front axle and cut the spring perch mounts from it, machined them to fit the wavy axle. Tacked them on for now, I’ll heat the axle and weld them hard when I get it all as it should be. A lot of work, but I think the wavy axle has a look that I want and it was all junk, so it fits my build.
  24. James D
    James D
    Excellent! Always enjoy your builds Jim.
    kidcampbell71, -Brent- and loudbang like this.
  25. 2deuces64
    2deuces64
    Thanks for the info
  26. Corn Fed
    Corn Fed
    Your axle idea is brilliant. I have never seen one done that way. It surely is the best way to get the spring behind the axle that I have seen yet. I have always been nervous of guys simply drilling horizonal holes in the bones and about mounting perches in shear but this totally eliminates that. And its a new way to tackle mating that Mopar axle to a Ford spring. Cool!
  27. JimSibley
    JimSibley
    Thanks. This is the second one I did like this. The other axle was a tube from an old sprint car that I put under my model a coupe. It worked real well , so I did it the same way on this one. Just need to make sure that your weld is hot, that’s a lot of steel there to melt together., but the original axle is a really nice forging and the tube axle is so thick, I’m real happy with how they come together.
    Outback, loner2, Just Gary and 6 others like this.
  28. I think I’m gonna use that idea because it’s s damn good one!
    Just Gotta find a trashed axle to cut donor parts from.
    Outback and loudbang like this.
  29. studebakerjoe
    studebakerjoe
    Jim, that really is a great idea. I have a model A axle that a guy cut up with a torch, but the perch holes are fine I couldn't toss it. Now I think I know what to do with it since I have a couple wavy axles. You do realize you've probably raised the prices on 4 door 57 Buicks now don't you.
    loudbang, JimSibley and Stogy like this.
  30. JimSibley
    JimSibley
    The roof really fit perfectly. I think the curve is even there to repair above the rear window area on a 34 that’s been smashed, I mean it fit that good.
    Outback, loner2, Just Gary and 4 others like this.
