Folks Of Interest Screws in reverse smoothie wheels?why?
Discussion in 'The Hokey Ass Message Board' started by iwanaflattie, Jan 11, 2020.
  1. Colin HD
    Colin HD
    I like someone got over zealous trying to hold a set of Moon discs on LOL
  2. iwanaflattie
    iwanaflattie
    I was really hoping they fit my van but econolines have the 5 on 4.5 pattern
  3. Dean Lowe
    Dean Lowe
    Running 5-6 psi we had to run screws in the rims to keep valve stems in the tubes. Went to these chromies 'cause no way in hell was I drilling my Halibrands!
  4. chevy57dude
    chevy57dude
    Don't know how much you paid but those slicks are the better part of the deal IMHO.
  5. Hemiman 426
    Hemiman 426
    from Tulsa, Ok.
    Yep, screws used for keeping the slicks from spinning on the wheel. Very common in the late 60's/ 70's. I did that on a cheap set of rims for my 68 Hemi car.
    Charlie K and loudbang like this.
  6. sunbeam
    sunbeam
    It was done with slicks and low air pressure to get a bigger foot print
    Truckdoctor Andy and loudbang like this.
  7. BLAKE
    BLAKE
    Thank you, thank you!! That's a real pet peeve... folks seem to forget what a 'reversed' wheel really is.
  8. big duece
    big duece
    from kansas
    Probably 4.5" pattern... don't believe Ford has a 4 1/4" pattern.
    Hnstray, Moriarity and loudbang like this.
  9. DOCTOR SATAN
    DOCTOR SATAN
    from okc
    I had some five spokes on my splitwindow vette with tapped holes for screws to hold slicks......
  10. iwanaflattie
    iwanaflattie
    Or they are too young to know the difference.
    I edited my ***le.
    I learned a lot last night.
    Thanks
    My bad,edited...will recheck the pattern today
  11. big duece
    big duece
    from kansas
  12. chevy57dude
    chevy57dude
    Yeah, the slicks are worth more than you paid.
  13. lothiandon1940
    lothiandon1940
    wraymen, Turnipseed and loudbang like this.
  14. iwanaflattie
    iwanaflattie
    Why is that?
    Arent they too old to be used?
  15. chevy57dude
    chevy57dude
    Out of production, rare, and yes, too old. If you were anywhere close I'd give $100 for 'em.
    loudbang and big duece like this.
  16. sunbeam
    sunbeam
    Ford 61-67 econoline used 4.5 bolt pattern.
  17. iwanaflattie
    iwanaflattie
    Yes i edited my mistake.....
    I just recked the pattern.
    4.75
  18. Its to keep the tire from spinning on the rim when you launch.
    What happens a lot is that slicks are run at very low pressure to enhance traction on launch. Running them low makes it easy for them to spin on the rim.
  19. sunbeam
    sunbeam
    Ford never used a 4.75 pattern. Unless some one swapped in Chevy stuff.
  20. Hnstray
    Hnstray
    from Quincy, IL
    I seem to recall Ford did use 4.25 x 5 bolt pattern on the OT ‘89 thru ‘95 T-Bird......probably on the Mark VIII Lincoln derivative.
    Ray
    loudbang and LM14 like this.
  21. iwanaflattie
    iwanaflattie
    The bolt pattern on the wheels is 4.75..
    The pattern on the econoline IS most likely 4.5.sorry for not specify.
  22. big duece
    big duece
    from kansas
    I think those 4.250 were 4 lug
  23. sunbeam
    sunbeam
  24. Relic Stew
    Relic Stew
    from Wisconsin
    The rear tire has sidewall damage in a spiral pattern, the one in the foreground has visible black lines in the same pattern. Someone was putting enough power through them to wrinkle the sidewalls. The screws were probably necessary, not just for looks.
    Dean Lowe, loudbang and egads like this.
  25. Hnstray
    Hnstray
    from Quincy, IL
    I believe you are correct, the 4 lug wheels were also 4.25”.......but the t-bird is 5 lug 4.25”
    Ray
  26. derbydad276
    derbydad276
    tap the holes use ****on head stainless screws start a new trend
    iwanaflattie likes this.
  27. iwanaflattie
    iwanaflattie
    I want to believe that this set up was used in a bad *** hotrod back in the day
    19Eddy30 and willys36 like this.
  28. seb fontana
    seb fontana
    from ct
    All four wheels are by Appliance I think, dimples for hub caps [little "moons"] are on the inside of the lug nut cavity PIC_0944.JPG PIC_0943.JPG ..The wheels with the slicks are standard and probably 5/6" wide. The wheels with out tires are reversed.. Check the distance between the valve stem and where the tire bead starts; the reversed is wider than the standard.. Look at the back side of the wheels with slicks and the wide spot is there..I am inept at photo shop today so can't label pics.:mad: Enclosed is pic of the chrome reverse I bought new from Gratiot Auto Supply around 1972 on my ShoeB. Holding up well for 48 years old..
  29. willys36
    willys36
    Speaking of buying obsolete slicks, I am eternally grateful to have found these early 60s vintage Pos-A-Traction Inglewood recap slicks. Brand new never used 10x15s which are perfect matches to those used by Ed Roth on the original Mysterion. They are one of the most important contributions to the original look.
  30. blowby
    blowby
    from Nicasio Ca
    If I was going to use those rims I would mount the tires then just swipe some silver silicone or JB weld over the holes and be done with it. Then again I've never won a car show...
    a boner likes this.
