Technical ***January 2020 Banger Thread. Happy New Year!***
Discussion in 'Traditional Hot Rods' started by Jiminy, Dec 31, 2019.
  1. winduptoy
    winduptoy
    Are you sure it is a fuel problem?
  2. railcarmover
    railcarmover
    Nothing special,Stromberg 97 carburetor,Ansen (or Burns or Tattersfield) intake manifold,Red's 4 into 2 header.
  3. railcarmover
    railcarmover
    A man much wiser than me once told me "Boy, if you think the problem is fuel then its ignition,if you think its ignition then your problem is fuel"
  4. Binger
    Binger
    from wyoming
    One down one to go. We got the sedan ****oned up and now to put the new motor into the roadster. I will update as we make progress.
    Old Dawg, Bigcheese327, burl and 4 others like this.
  5. jadz928
    jadz928
    from Michigan
    Waking up a Model B w/orig Miller-Schofield OHV 0110201718a.jpg
    Old Dawg, Lil'Alb, burl and 9 others like this.
  6. Binger
    Binger
    from wyoming
    Got the newly rebuilt engine in and took off fenders. Won’t take much to finish up.
  7. ghalperin
    ghalperin
    I finally got it running. After dis***embling and ***embling about a dozen times, I was having problems getting the jets to bottom out in the chambers, so I cleaned up the threads for the jets with a 1/2–27 tap. I also resurfaced all the flanges. It may have been ****ing air between the throttle and the bowl. It may have been a tiny piece of dirt stuck somewhere, I really don’t know what was wrong.
    Old Dawg, poshdbs and railcarmover like this.
  8. railcarmover
    railcarmover
    So you grind through the sandblasting,body work and paint,the steam cleaning of the ch***is,the days where you work all day and cant see what you did..working like a fool to get to this point,clean work finish ***embly.Only to find out you do each process three or four times till your satisfied..
    Old Dawg, burl and barrnone50 like this.
  9. klawockvet
    klawockvet
    First time ever to be ahead of schedule on a car project. Picked up the new engine from Joe at Turlock machine on Jan 4th. Drove all day on the 5th. Got the engine in and 90% done on the 6th. Finished up and running early the next morning. New engine is a B block with late counterweighted "C" crank, TM aluminum rods, 283 Chev pistons, inserted crank and rod bearings with full pressure, Dan Price Cragar with dual Stromberg 97's, FSI ignition, Red's header split into two pipes and mufflers running all the way to the back. Hooked into an F150 27% OD trans, 3.78 rear. Its a sweet combination and its good to have all of my old cars up and running. IMG_3867.jpg IMG_3872.jpg IMG_3875.jpg
  10. BeaverMatt
    BeaverMatt
    Are broken valve springs common in Model A/B engines? I'm digging into a Model B engine and this is my first look inside a Model A/B (years of experience with more modern overhead V-8's). No. 1 intake had the top approx 1 coil broken. No. 4 intake both had the bottom 1 1/2 coils broken. Engine is out of a truck. Had sat for some time (undercover and out of the weather). Got it running quite easy and it ran well (on a test stand).
  11. Binger
    Binger
    from wyoming
    Getting a few things out on this roadster! Starting to gone together.
    mdimages, Shutter Speed, burl and 7 others like this.
  12. wheeltramp brian
    wheeltramp brian
    Sure looks nice binger!
  13. barrnone50
    barrnone50
    from texas
    Looking Good on your progress turning out those Motors. On the roadster what Head is that? Thanks George
  14. Binger
    Binger
    from wyoming
    It’s a Thomas head. 7:1. I can’t wait to see how it runs. My buddy Larry has wanting to beat my coupe. He had called me out for a race at the dirt drags. I think he should be able to do it with this motor set up.
    barrnone50 and Old Dawg like this.
  15. Not if you out tune him....................
    Old Dawg, Jet96, barrnone50 and 2 others like this.
  16. V4F
    V4F
    from middle ca.
    seems like a slow month . people must be in garage getting ready for good weather
  17. jim1932
    jim1932
    Been so warm in Maryland I'm still driving mine.
  18. Been cold outside, relatively so been in the shop
    here's a taste
    Cams out for plating then grind, new tank in coupe and girdles
    BCCHOPIT, Old Dawg, burl and 5 others like this.
  19. winduptoy
    winduptoy
    got the oil pan off the engine that I did the crack repair on going to clean things up.. That was a bigger project than it sounds like. I had to get the engine stand off of the container. Well that takes the forklift. It blew a tilt cylinder so I had to rebuild it before I could lift the engine to put it on the stand ...had snow last night and it is blowing 40 to 45 with gusts of 65 to 70 mph....I can park outside with the window rolled down and my arm hanging out and think I'm doing pretty good time
    Jet96 likes this.
  20. winduptoy
    winduptoy
    Old Dawg likes this.
  21. 4bangerbob
    4bangerbob
    from AB, Canada
    Very nice machining on the cams and the gui
  22. Michael_e
    Michael_e
    John, How thick is that crankshaft girdle?
    Thanks,
    Mike
  23. Mike,
    it is 3 1/2" thick give or take
    John
  24. Johnny Nitro
    Johnny Nitro
    from Chicago
    Wow. That is a shockingly beautiful ride. I love all the details. Raw br*** tank, and overflow, engine turned firewall, and the entire motor. Just awesome.
    rwrj likes this.
  25. Binger
    Binger
    from wyoming
    [​IMG][​IMG]
    We got Larry’s roadster started yesterday. The Gear Drive header sounds awesome. A few things to ****on up and then it’s time to put some miles on her. Too bad it’s the middle of winter right now and warmish days are not too common.
    Old Dawg, jadz928, winduptoy and 4 others like this.
  26. 62pan
    62pan
    Nice job binger. I did my motor transplant in Dec. because I didn't want to have much downtime. Now here I set after an ice/snow storm with salt over all over the roads and future highs only in the 20's waiting for better weather.
    Binger likes this.
  27. The37Kid
    The37Kid
    DSCF0720.JPG Are these Model A motor mounts early '28 AR items or AA truck? Thanks. Bob
    winduptoy likes this.
  28. Crazydaddyo
    Crazydaddyo
    BCCHOPIT likes this.
  29. burl
    burl
    from Minnesota
    What kind of plating on the cams ? I have seen some cams that were salt bath nitride
  30. The37Kid
    The37Kid
    I've seen copper plating on unmachined sections of cams, think it has something to do with heat treating. Bob
