Projects Drilled axle dressed up.
Discussion in 'Traditional Hot Rods' started by 28 Ford PU, Jan 12, 2020.
  1. 28 Ford PU
    28 Ford PU
    from Upstate NY
    I’m always trying to do something a little different (like a Ford in a Ford) and I like detail. I drilled my front super bell axle and pressed pieces of 3/4 inch copper tubing into the holes just to dress it up. I still need to do a bit of polishing and paint touch up and cleared but I just wanted to show off my idea. IMG_0590.JPG IMG_0589.JPG
  2. Bird man
    Bird man
    from Milwaukee
    Not too shabby.
  3. 7916B44C-EE05-4141-81BD-4CA610904221.gif Dare to be different !
    I like it
    Daddy Deville and loudbang like this.
  4. 19Fordy
    19Fordy
    Very "spiffy".
  5. Rocky
    Rocky
    Classified Editor
    Original!
  6. sloppy jalopies
    sloppy jalopies
    wicked spiffy ...
  7. Boneyard51
    Boneyard51
    Kool!
    Bones
  8. ramblin dan
    ramblin dan
    That is great. That's the kind of detail that I like to look for and like to see when I check out a car.
  9. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Now suspend penny's (of correct year) in each hole.
    kidcampbell71 and loudbang like this.
  10. Great Idea.Im thinking chromed,but I like what you"ve got there.
  11. Looks awesome,,,,how about the patina that is on its way.
    Just like the Statue of Liberty.
    Fitty Toomuch and loudbang like this.
  12. Bandit Billy
    Bandit Billy
    Run on copper tubing tomorrow at Home Depot. :cool:
    great idea!
    loudbang and GordonC like this.
  13. GordonC
    GordonC
    Now you did it! Now you will have to add a whole bunch of other copper accent pieces! :D
  14. 302GMC
    302GMC
    from Idaho
    Cut the tube off fired 16ga shotshells & press the br*** in the holes. Each hole a different headstamp, of course ...
    28 Ford PU and loudbang like this.
  15. deathrowdave
    deathrowdave
    from NKy
    This is a great idea . Was it DWV copper or soft tubing ?
  16. hotrodjack33
    hotrodjack33
    How much effort is it to drill an axle ? And what type of bits did you use ?....I've never tried it.
  17. 41rodderz
    41rodderz
    from Oregon
    Dig it.
  18. akoutlaw
    akoutlaw
    Cool idea, I like it!:)
  19. loudbang
    Take some br***o and polish them up before the clearcoat.
    1947knuck, oldiron 440 and brady1929 like this.
  20. rd martin
    rd martin
    from indiana
    very kool!
  21. brady1929
    brady1929
  22. silent rick
    silent rick
    what about the galvanic reaction of the two dissimiliar metals touching each other. any thoughts on corrosion?
    deathrowdave likes this.
  23. solidaxle
    solidaxle
    from Upstate,NY
    There's been studies, that drilling the axle creates a whistle above 30 mph and will keep deer away. Sorry to bring up a sore subject. Just don't go in reverse it attracts them.
    I glad to see you you getting it back together.
  24. MMM1693
    MMM1693
    I drilled my Super Bell in my drill press. Started with 3/8 bit then went to 7/16 then used my Kar Prod reamer bit. the reamer bit starts at 3/8 and tapers to 5/8 and that's where I left it. Used lots of ATF
    hotrodjack33 and loudbang like this.
  25. seabeecmc
    seabeecmc
    One shot with Hougen bit. Ron
  26. 28 Ford PU
    28 Ford PU
    from Upstate NY
    I was also thinking stainless tubing would look great also but I already had a small length of copper. All it cost me was time.
    akoutlaw and loudbang like this.
  27. 28 Ford PU
    28 Ford PU
    from Upstate NY
    I’m 65 now. I think I’ll be in the boneyard before the axle.
    How many traditional rod builders back in the day thought about galvanic whatevers? The only dissimilar metals I ever thought about was the aluminum moon gas pedal being mashed into the steel floor boards.
  28. 28 Ford PU
    28 Ford PU
    from Upstate NY
    Your too funny!!! [emoji1].
    For those that don’t know my rod is apart right now because I had a deer commit suicide dead center of my grille shell.
    Sent from my iPad using The H.A.M.B. mobile app[​IMG][​IMG][​IMG]
  29. 28 Ford PU
    28 Ford PU
    from Upstate NY
    Hey, mmm1683 pretty much answered it for me. The only thing I can ad is lots of folks will tell you to use a ton of oil when drilling. But the truth is drill it dry. Cast has a high nickel content that acts as a lubricant. As you drill you will find that it chips now strings of material. Using oil only makes things worse because it holds the chip and dust in the cutting area. Keep the cutting area clean dry brush out the chips if they tend to build.
    hotrodjack33 likes this.
  30. A Super Bell axle should be fairly easy to drill it is a cast axle. Cast iron or cast steel is pretty easy to drill.
    a Forged axle like an original equipment axle on most old cars and trucks is a little harder (more work). But it can still be done with common drill bits. Drill pilot holes (I start with 1/8") and step your way up. When I was a kid we used a 1/2" Black and Decker Automotive drill, really funny if the bit hung with me on it I weighed all of about 135 and was usually riding the drill anyway. If it hung I am sure that I looked like a top spinning and weaving. :D :D :D
    @28 Ford PU the axle is purdy man. I like it dressed like you have done.
    dana barlow and hotrodjack33 like this.
