Technical Low but functional
Discussion in 'Traditional Customs' started by p1yotaboy, Jan 9, 2020.
  1. flamedabone
    flamedabone
    I drove my old Merc everywhere.
    -Abone.
    BigO, 40two, Hollywood-East and 8 others like this.
  2. downlojoe33
    downlojoe33
    Couldn't have said it any better myself. The stance on that Merc is PERFECT!
    61Cruiser, ebfabman and jimmy six like this.
  3. Torchie
    Torchie
    Here is a picture of THAT truck before I sold it and people started to strip parts off of it every time they flipped it. I used 3 inch shackles in the front (SoCal Speed shop as I recall) and home made longer ones in the rear. Talk about traditional.LOL I also added tube shocks front and rear along with a rear panhard bar to keep things legit as it was a 47-48 Ford rear end which is a bit wider then the stock 41 was. The truck was also channeled 6 inches.My avitar give a good profile of how it sat. I've got a pic somewhere that show the height from the ground to the bottom of the rocker to about the height of a pop can.
    Dropping and axle should not affect track width. Many of the customs back in the day had some sort of rubbing issue with the front tires. You just never went lock to lock. And as has been stated, castor are noting new. The Hirohata Merc had casters on the bottom of the rear bumper as I recall.
    Junior Conways shoe box was low as was Larry Watsons G****vine and both static drops.
    Customs were all about the look. Not always about how practical they were.LOL
    Torchie
      56.4 KB
  4. p1yotaboy
    p1yotaboy
    Glad to see you chime in sir. And again thanks for the advice you have given me so far as how you built yours. I’m trying to finish up my honey do New Years list before I start heavy on the f1. Hopefully only a few more weekends and I’ll be done enough to get started
    Torchie likes this.
  5. 4" in front, 6" in back and then learn to drive it pretty careful on driveways, speed bumps, and dips in the road
  6. Trucks with car front sheetmetal rules
  7. 57JoeFoMoPar
    57JoeFoMoPar
    It's funny that this thread should come up today.
    My 57 Ford is damn low, with a static drop. Chopped coils in the front, 3" blocks in the rear with a reversed shackle. The lake pipes are the lowest point, and they've been torn off the car more times that I can count. I too have driven the hell out of this car, easily over 100K miles in the 18+ years I've owned it, so it's not as if how low the car sits has stopped me from getting it out and enjoying it. That being said, as I've gotten older, my tolerance for the ******** ***ociated with driving a car this low has lessened. As mentioned, the lake pipes have been ripped off the car more times that I can count. Despite comfortably seating 5, this car is absolutely a 2-seater since the weight of an adult in the backseat makes turning without s****ing an impossibility. The skirts have been dragged for miles. The driveshaft chewed a hole through the floor under the back seat. While people will alway complain about speed bumps with lowered cars, I can tell you that by far the most problematic issue I've run into are just dips in the road, such as a drainage grade in the left or right lane, which you basically never see until it's way too late and you hit it at full speed. Even a cooler with ice and beer will drastically affect ground clearance. Now that I have a 16-month old, I just won't drive her around in this disaster. So I literally haven't driven this car in about a year. But I have to say, the car looks great with that stance, and raising it to improve ride quality and driving enjoyment would come at the expense of show aesthetics. Not a good trade off.
    My 61 Olds drives and rides like a million bucks, but I think it sits like a 4x4. The car would have a lot more at***ude if it were much lower. But I like how nice the car is to drive and enjoy piling the family in the car to go to shows. It's still a compromise.
    The reality is that air suspension gives you the best of both worlds. I know it's not "traditional" as it is for this board, and people dump on it as mini truck ****, but the ability to adjust ride height for both show and driving really allows you to not only look good but to log serious miles without beating you or the car to death in the process. This winter I'll be installing an Air Lift 3p system with two compressors. For the price of what air ride parts have come down to, whether it be Air Lift, Accuair, etc., or even if you put together your own system with manual controls, it's worth the expense for the overall enjoyment of the car. I've also talked to a few people who daily drive bagged O/T cars, and they have no issues with reliability with the systems. The reliability of the systems greatly depend on the quality of the install.
    For stuff that nobody is going to see on a custom car, I have no qualms about going to air suspension. I know some may disagree, and thats fine. I just draw my line in the traditional sand elsewhere.
    BigO, 40two, Special Ed and 5 others like this.
  8. ekimneirbo
    ekimneirbo
    Since the suspension will not be visable I'd bag it...........but stay away from the stupid "layin frame" ****. Nothing looks more idiotic than sitting on the ground. I say this having never owned a car that is "bagged". I have owned several trailers that manage to drag when I exit my driveway onto the street. It happens because of two inclines intersecting at 90 degrees. Last trailer I built I incorporated caster wheels on the back. Don't think that will look good on a lead sled. In the fifties there were far fewer speed bumps too. Noting will make you regret your choice more than hearing that grinding noise as you proceed forward even if you don't tear something up. Put bags in it and make the lowest setting be where you want it when the car is cruising or at a show. Then when you get out on the road, raise it an inch.........or two if needed. You will be glad to have the ability to gain some height for a few seconds when you need it! ;) I see some of the *****s out there actually attach blocks to their cars that they allow to s****e the road. What fun that must be.
    Some of low ridings inglorius moments.....I do have to admit the car skipping rope at the 3:40 mark was impressive. Then watch the lowered dually truck that comes up next and how he drags leaving the parking lot.
  9. nochop
    nochop
    from norcal
    **** pucker factor
  10. Boden
    Boden
    Ai shocks all the way. It’s traditional. And smart. And they r cheap. No special mounts. Bolt in. All u need it a compressor and some wiring. And a tank. But this cite isn’t nessecarily a bolt in cute.
  11. BigO
    BigO
    Here's my '47 and it will be dropped in the rear and still drivable, may add air shocks for safety reasons...
  12. pgj
    pgj
    from aurora co.
    ekimneirbo likes this.
  13. pgj
    pgj
    from aurora co.
    I'm in the middle of putting a accuair system in my 64 olds. my normal ride height was aprox. 3-4 inchs. then one night with my wife and grown son in the car a piece of asphalt grabbed my crossmember and broke the lower bell housing bent the trans adapter and broke the case on my new 700r4. $3000.00 dollars damage. it's getting air ride and i don't care what anyone has to say about it.
  14. 2bubbas
    2bubbas
    '66 PU is low- lowest point is front crossmember- 3 inches- dropped I-Beams and flipped axle- c-notched- totally drivable- 100_3565.JPG
    p1yotaboy and guthriesmith like this.
  15. rusty1
    rusty1
    ...lower it til somethin s****es or drags, then it's just rite...
  16. fordcoupeguy
    fordcoupeguy
    It seems the more cool you want to look ,the more impracticle it is. Its just not fair! I am doing a tail dragger shoebox and am working on an adjustable hydrolic -coilover system for the rear. With aging infrastructure ( roads) you need to be able to set ride hight on the fly. Would not be good to rip a hole in the gas tank and have a fire. Not sure if insurance would cover that. And that's a whole different topic!
    p1yotaboy likes this.
  17. ebfabman
    ebfabman
    I agree. In this case, nothing more "practical" than air ride.
  18. Jalopy Joker
    Jalopy Joker
    I would use a small floor jack along side of frame behind front tire to raise car enough to get regular floor jack under front
    did that once, hit a Armadillo while in Texas - no fire
  19. fordcoupeguy
    fordcoupeguy
    Overhang has a lot to do with ride hight too. I only have a 1in block in my Cady and it still drags the bumper on some ramps. Imagine a continental kit.? Would look cool but may not get out of the driveway! IMG_0209.JPG
    40two, p1yotaboy and Special Ed like this.
  20. LOST ANGEL
    LOST ANGEL
    Side pipes help visually lower the car.
    40two, stanlow69 and p1yotaboy like this.
  21. LOUIELOUIE
    LOUIELOUIE
    My 41 sits 3 1/4” off the deck from the rear of the running board. 4” drop axel upfront, flattened rear crossmember drives mint with no dramas at all.
  22. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    The tighter you tuck things into the frame (oil pan, trans, brackets) etc, the lower you can go.
  23. Blue One
    Blue One
    from Alberta
    Lots of posts that I refuse to take the time to read here.
    Because they are way too long and no one seems to understand the concept of punctuation or paragraphs.
    It’s really irritating to try reading 600 words or more that look like one never ending sentence.
    There is such a thing as too low when it comes to practicality or usability.
    Riding in a car or truck that s****es or bangs over every little pimple on the road gets old quickly.
    Someone mentioned scrub line which is a valid safety concern.
    And don’t even start on Airbags :D
    Bags are for groceries not suspensions. :p
  24. My Roadster is pretty low. I sectioned the oil pan and oil pickup. 20160827_154355.jpg 66778283_340353620226891_3236306777213501440_n.jpg 81447853_473001626738224_8374564088302272512_n.jpg
    anthony myrick and p1yotaboy like this.
  25. gnichols
    gnichols
    from Tampa, FL
    For a driver: 6" fully laden - full gas tank, two pax, perhaps some luggage? Also be careful for long overhangs front and rear (approach angles). Nothing lower than the frame rails (engine, bell housing, exhaust pipes).
  26. swervyjoe
    swervyjoe
    Any more pictures? Is the drop axle all you did to the front?
  27. Colonial Coupe
    Colonial Coupe
    20180610_094251.jpg we drive it, but there are some places that I know not to go.
  28. ekimneirbo
    ekimneirbo
    Speedbumps.............Something that wasn't prevalent in the fifties. Its a reality that you have to plan for today.
    05snopro440 and p1yotaboy like this.
  29. BigO
    BigO
    Some examples of a car looking two different heights but actually the same height, pictures can fool you.
