Projects Not good news in the Flathead
Discussion in 'The Hokey Ass Message Board' started by David68, Jan 13, 2020.
  1. David68
    David68
    So got the engine onto a stand today to perform some investigating. Removed the intake and was super stoked to find nothing broken. When I took off the head I found the rust pop marks shown in the pics. Stoke bore and I’m hoping (fingers crossed) that the machine shop can cut .030 and make it good. Just wanted to update the group. IMG_0727.JPG IMG_0728.JPG
  2. FritzJr
    FritzJr
    If the bore is not badly worn, I would consider just a quick hone job and new rings.
    Blues4U likes this.
  3. David68
    David68
    Looking bad in the right bank too. Looks like some jack nut used JB weld to fill in a crack and then hone the cylinder. SMH. IMG_0729.JPG
  4. nochop
    nochop
    from norcal
    Post in “ what I dislike about the hobby” thread....just kidding, sorry this happened
    VANDENPLAS and Spooky like this.
  5. What is the bore now,,,it should be able to handle the overbore,,surely.
    Tommy
    Desmodromic and David68 like this.
  6. Ziggster
    Ziggster
    Welcome to the HAMB. I'm fairly new and just had a flathead done. That looks pretty good except for the area you think may have been epoxied. I doubt JB Woeld would have withstood combustion temps and pressures for very long. I just needed 0.020" to clean up mine after a rebuild overbore of 0.040". So I"m at 0.060" now.
    David68 and Desoto291Hemi like this.
  7. flatford39
    flatford39
    My guess is that one is going to need a sleeve which is no big deal. You need to have it checked for cracks before you go to far on it.
    Truckdoctor Andy and David68 like this.
  8. David68
    David68
    Stock bore. 3.18
  9. Should clean up just fine,,,as long as that gouge is not too deep under the epoxy.
    Either way,,they can be bored a lot.
    Good luck man.
    Tommy
  10. RB35
    RB35
    Plenty of room for a cleanup bore.
  11. Beanscoot
    Beanscoot
    Looks like a fair bit of pitting that won't be easily honed out:
    ffr1222k, Desoto291Hemi and David68 like this.
  12. oldiron 440
    oldiron 440
    I bet it was stuck at one time.
    Lloyd's paint & glass likes this.
  13. tubman
    tubman
    If you have to buy pistons anyway, I'd bore it to 3 5/16" for the extra displacement and compression. The pistons and rings cost the same and you'll still have enough meat in the cylinders for a couple of more rebores and a hone or three. Everybody wants the vaunted Merc crank which will give you 255 cubic inches with a bunch of money and effort, while boring 1/8" with a stock stroke will give you 258 cubic inches for about the same cost and effort as a stocker (239").
  14. Fortunateson
    Fortunateson
    Good info here...!
  15. squirrel
    that's gonna take a lot of overbore to clean up completely...I like tubman's suggestion
  16. David68
    David68
    Thanks Tubman.
  17. I would not worry about it.
    It may have been silver solder. I have seen them done that way before. seems like it must have worked well enough.
    I don't know much about your flatty, but I do know that most of them will go .125 and still have plenty of meat left. They were a heavy casting. If your machinist doesn't know what it will take to clean it up have him rough bore it 'til its clean then buy pistons to match and tail it in.
    Beanscoot likes this.
  18. Wavetrain75
    Wavetrain75
    My 49 Flathead is .090 over and has one sleeve to repair a cracked cylinder from way back when. I replaced the rings and it runs like a top with very little oil use, at least by Flathead standards.
    On a completely unrelated subject, I have a set of new .060 rings I’d let go very reasonably.
  19. Flathead Dave
    Flathead Dave
    from So. Cal.
    I think it can be bored to what you want. Sleeving could be an option.
  20. Flathead Dave
    Flathead Dave
    from So. Cal.
    Looks like SPEEDY from McDonald's.
  21. Onemansjunk
    Onemansjunk
    from Modesto,CA
    That Epoxy Fix might not be EPOXY!!!!! It might be a COLD REPAIR done with LOCK-N-S***CH—-I repeat—-LOCK-N-S***CH—Google it and don’t FFF with it!!!!
