Technical Drivetrain Adaptation Tribal Knowledge Thread
Discussion in 'The Hokey Ass Message Board' started by treb11, Jan 15, 2020.
  1. treb11
    treb11
    "Well the transmission was a '53 and the engine was a '73 and when we tried to put in the bolts all the holes were gone. .... So we drilled it out so that it would fit And with a little bit of help with an
    A-dapter kit we had that engine runnin' just like a song." - Johnny Cash
    I think we need a thread that brings together all the little tips and details of adapting transmissions to engines they never were mated to from the factory. I often see brief descriptions of WHAT was put together, but not HOW. All the gory details like what pilot bushing, was the input shaft trimmed, what clutch disk part number was used, which adapter housing was used and/or modified. In short, this will hopefully become a repository of reference information for trans swaps. Copies of old magazine articles are legit, as long as the detail is there. Links to other HAMB postings are legit too.
    Now, this IS NOT to be ANOTHER T5 thread, there is already a great lengthy thread here,plus others. So don't bother with that.
    What I would like to see for example is LaSalle to flathead or T-10 to Studebaker or Buick straight 8 to ZF transaxle.
    Go.
    Kreepea_1, Ned Ludd, SS327 and 5 others like this.
  2. Budget36
    Budget36
    I just listened to that song. Funny thing as a kid I thought he did the "49, 50....ect" thing more times in the song, seems he only did it at the end.
    Oh well, back to your favorite programming. George Jones is coming on;)
  3. Rocky
    Rocky
    Classified Editor
    At one time I planned to use a 500 Caddy in my coupe with a muncie 4 speed. I found a chevy bolt pattern Lakewood ****ter shield had the alignment dowels in the same place as the caddy and all but 2 bolt holes lined up. I welded 2 ears on the ****tershield so I could use the top 2 holes on the block. Cool! Now, all 6 bolt holes lined up. It was about that time I found the caddy block was cracked all the way down one cylinder. Never did address the flywheel problem but I know one is available aftermarket.
    panhead_pete, alanp561, Baumi and 3 others like this.
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I have 76 Malibu Cl***ic harness in my 56. When I pulled the light switch it all worked with a little rewiring.
  5. gimpyshotrods
    gimpyshotrods
    I am in the process of putting a 6-71 blown Chrysler 354 Hemi, on an Cadillac Eldorado TH425 front wheel drive transmission, with two chains, all turned around backwards, and running a reverse-rotation quick change rear axle, and set mid-ship in a Model A pickup.
    Toms Dogs, winduptoy, SS327 and 19 others like this.
  6. DDDenny
    I don't expect the ZF transaxle to fair well here!
  7. Budget36
    Budget36
    Ya know if you weld the chains up....
  8. gimpyshotrods
    gimpyshotrods
    winduptoy, 2Blue2, alanp561 and 12 others like this.
  9. treb11
    treb11
    Here's a Speed Gems adapter catalog page to help identify that strange part you have.
  10. treb11
    treb11
    Bump to try to archive some actual information, otherwise I'm gonna let this one die. That would be too bad, there is a lot of knowledge out in HAMB land that needs to be saved.
    Automotive Stud and Texas Webb like this.
  11. belair
    belair
    Great idea. Common knowledge is a lot like common sense. It isn’t all that common.
    427 sleeper likes this.
  12. treb11
    treb11
    Buick straight 8 with a T5
  13. dan c
    dan c
    it's done with B-O-P parts.
    Hnstray likes this.
  14. dan c
    dan c
    i have an old engine-swap book (#2) from peterson pub. that has a great chapter on this. everything from bolting on a piece of angle iron to making a bellhousing. published in the late '60s...
  15. Rocky
    Rocky
    Classified Editor
    Yes but I really wanted to use the ****tershield's motor mounts like a 55-57 chevy. The ****ter shield was perfect for that...until I found the gigantic crack in the cylinder!
    dan c, Hnstray and loudbang like this.
  16. bchctybob
    bchctybob
    I agree, I just read through a thread about Cadillac engine and LaSalle transmission and the bellhousing differences, etc. Good Info. Maybe you can swipe that one and put it here. Maybe someone has an old Trans-Dapt, Wilcap or Offy catalog and they can post some pages.
  17. bchctybob
    bchctybob
  18. treb11
    treb11
  19. bobss396
    bobss396
    And look at how some of these swaps were performed, no precision equipment, eyeball engineering, transfer drilling. You made do with what you had around.... and made it work.
    alanp561, Texas Webb and loudbang like this.
  20. treb11
    treb11
  21. treb11
    treb11
  22. MO54Frank
    MO54Frank
    I am a subscriber to Jonathan W’s YouTube channel and this is one of his many backyard engineering successes.
    firstinsteele and loudbang like this.
  23. treb11
    treb11
  24. treb11
    treb11
  25. treb11
    treb11
  26. treb11
    treb11
  27. treb11
    treb11
  28. treb11
    treb11
  29. treb11
    treb11
  30. I am in the beginning stages of putting a GM ****** behind an off topic Datsun inliner out of a Z car.
    Hnstray, Vic Walter and rusty valley like this.
