Hot Rods Struggling with my 32 Ford roadster hood?
Discussion in 'The Hokey Ass Message Board' started by AF/X, Jan 17, 2020.
  1. AF/X
    AF/X
    I bought a 32 roadster fibergl*** car with no hood.
    I already had a (supposedly) 32 hood laying around, so i decided to put it on the roadster.
    It is wierd! Doesn't fit that great on p***enger side but pretty good on drivers side.
    It seams to me that the side panel of the hood back where it meets the cowl has a slight curve but the body where the hood side meets the car is straight?
    Are 32 hood side curved where they meet the body?
  2. Deuce Daddy Don
    Deuce Daddy Don
    Not really-----This is where "shimming" comes in for hood alignment. You just have to play around with rubber or neoprene shim tubing for desired fit.
    anthony myrick likes this.
  3. I have seen guys have to add metal on the edge to close gaps.
  4. wicarnut
    wicarnut
    My 32 had the Rootlieb hood set up, I changed the radiator from a Walker to a Afco Aluminum, what a nightmare, brackets slightly different, had to correct/modify, I spent off and on probably 12/16 hours realigning hood gaps, shimming, etc. I never got it as good as it was but then checked hood gaps on other 32's at shows and noticed very few fit real good, exceptions, real nice high dollar pro built cars.
  5. KevKo
    KevKo
    from Motown
    You will also find that each side of your body is different. Henry's were too. Getting both sides the same will be a LOT of work. Probably easier to get the body, frame and grille shell as square as you can, then fit each side. Can't see them both at the same time anyway.
    clem likes this.
  6. woodiewagon46
    woodiewagon46
    from New York
    As Deuce Daddy points out it's all about shimming the body. Every shim installed or removed affects another part of the car such as door gaps and trunk fitment. It took me a couple of days to get my '32 body and hood aligned to where I was happy. The picture of you p***enger side looks low to me, you may need to shim it up, that will close the gap some. It can try your patience, keep at it. Post some measurements of your hood and we can check if that's part of the problem.
  7. ct1932ford
    ct1932ford
    You can sometimes get it right by adjusting the radiator support rods. and the radiator bottom mounts. It works for me.
    wicarnut and pitman like this.
  8. Happydaze
    Happydaze
    Curved? In what sense? As far as i'm concerned the trailing (and leading) edges of the hood sides are straight, as should be the cowl where the hood sides sit. The hood sides when fitted should bulge out slightly / pull in toward the bottom) to match the shape of the cowl but the hood sides themselves return to being flat when not fastened down. The cowl banding or whatever you're using (silicon hose works in the cowl groove - not trad) gives the required bulge in the hood sides.
    Chris
    clem likes this.
  9. AF/X
    AF/X
    I put a straight edge on the trailing edge of the hood sides and they both have a curve in them they are not straight?
  10. HOTRODPRIMER
    HOTRODPRIMER
    I have spent a entire day adjusting the hood on a 32 Ford, sometimes they almost fall in place and other times they can be a down right nightmare. HRP
    wicarnut and nochop like this.
  11. Taboo56Chevy
    Taboo56Chevy
    you could possible have a 33 Ford Pickup hood side if no amount of adjusting helps the fit. The pickup side had a curve to it along the bottom to fit.
    32 hood -
    33 Pickup Hood -
    dudley32 likes this.
  12. 36couper
    36couper
    from ontario
    I'm dealing with sort of the same issue. The original hood seems to be too long. It's a fibergl*** body. I think I may have to move the rad/rad shell ahead about 1/2'+ to get it to fit. I have quadruple checked and the body is mounted on the frame correctly
    nochop likes this.
  13. Taboo56Chevy
    Taboo56Chevy
    your issue might be in the body itself. Depending on who made the body, it could be slightly longer than a original 32. I know alot of the gl*** bodies have lengthened the doors, but it wouldn't be surprising if its slightly off. Depends on the level of tolerance they had when they made the molds for producing the bodies.
  14. nochop
    nochop
    from norcal
    My Rootlieb hood been nice to m so far, but the build goes on.... B7A3BD6A-4819-4E54-9BEB-6CB9A7043F68.jpeg
    wicarnut likes this.
  15. 31Dodger
    31Dodger
    Are your radiator and shell level? It shouldn't be THAT far off.
  16. nochop
    nochop
    from norcal
    Chinese proverb...som ting wong. Is the length from bottom of the body belt line the same on right and left
  17. Happydaze
    Happydaze
    Sincere apologies - I've just checked mine and they're not quite straight. A straightedge placed on the surface and sighted on the top and bottom corners of the trailing edge reveals that the hoodside protrudes rearwards by 3/16" . Hope that helps some. BTW mine are either originals or older repops and fit nicely to a Brookville 3w with an original firewall.
    Chris
  18. clem
    clem
    FWIW : Even if the shape of the hood top is out, it may affect the alignment of the side panels..........
  19. woodiewagon46
    woodiewagon46
    from New York
    Don't know if this will help you, but I just went out to the garage and measured the Rootlieb hood on my '32. The very top of the hood side is 33 and 3/16". The very bottom measures 32 and 5/8".
  20. Andy
    Andy
    Do you have an original frame? I have seen aftermarket frames with too much rise in the front. A friend had to bend the front of his down to get the hood to fit. I would try to fit the top and mark where the belt line is on the shell. Try to fit the sides alone to the cowl. The repo hood sides are flat and they should have a gentle curve to match the cowl and shell.
    The bare hood sides will tell you if the frame is off.
  21. woodiewagon46
    woodiewagon46
    from New York
    Andy brings up a good point. At one time they were selling Deuce frames with an exaggerated rise in the front end. Do you know anything about your frame?
  22. DDDenny
    What kind of mounting legs does this body use at the firewall location, any photos?
    This (may) have an affect on hood fitment.
    Also, as was stated, if the radiator/crossmember is off, from that point on it will be difficult to align grill shell to cowl correctly.
    You also need to be able to stand back some distance to make sure the junction of the hood to cowl does not appear like it has a "broken back", meaning the hood looks like it is going either uphill or downhill.
    I recall reading a statement from one of the big name shop guys about it taking a couple days to get this right.
  23. Curt R
    Curt R
    1932 Ford hood measurements from Rootlieb
    Rootlieb will make hoods to buyers specifications. One persons 32 hood dimensions may not be identical to another persons 32 hood or Fords. Not all original Ford body panels were dimensionally identical to each other, they were m*** produced and way too many things could have affected a manufacturing change in dimensions 88 years ago.The pictured dimensions are believed to be the factory dimensions. As shown by the Screenshot_2020-01-18 2013 Catalog pmd - 252ba087ee8afab316e24fb728b44f46.png picture and measurements the hood sides are not square top to bottom or end to end so trying to fit the irregular shaped hood side into a dimensionally square opening (straight body cowl edge to straight radiator shell edge) will be difficult. As stated by others getting everything to fit will be time consuming. Getting perfect gaps is way more than Ford did in 32.
    clem likes this.
  24. V8-m
    V8-m
    from Alaska
    Wondering where the 22" starts ( center of the strip or the edge off it) and where ending ( is the side body line included or not)..the same 13 1/8"
    How it's measured
  25. krylon32
    krylon32
    from Nebraska
    On the last several steel bodied cars I've built we had to ad and subtract from the sides and on 2 we pie cut the hood tops, all this to get the perfect fit. Then did my chopped 5 window and the Rootlieb 25 louver gennie hood fit perfect as made. They're all different.
    V8-m and clem like this.
