Drag racing tips?!
Discussion in 'The Hokey Ass Message Board' started by 53 hemi, Jan 3, 2020.
  1. swade41
    swade41
    from Buffalo,NY
    If you have old filters with the metal mesh around the paper element you can cut the paper away and just run the metal mesh, it'll keep the stones and pterodactyls out.
    loudbang and 53 hemi like this.
  2. They look like a bias ply , vintage slick to me.
    BTW, real radial slicks don't require front radials. Front runner drag only tires are not radial construction.
  3. fordflambe
    fordflambe
    "Basic advice?" - Real drag racers never tell you how they do it!
    Turnipseed likes this.
  4. thehazguy
    thehazguy
    Hit a reaction time like the one on the right (G152)
  5. Anybody can do that once..
    Nobody does it 6 rounds in a row;)
    thehazguy likes this.
  6. saltflats
    saltflats
    from Missouri
  7. raven
    raven
    What was your tire patch like when you tested your slicks with 35lbs in them? I bet they were narrower than your slick.
    If so, you’re going to have to drop the tire pressure.
    r
  8. DDDenny
    Some do!
    https://frankhawley.com
  9. roseville carl
    roseville carl
    now thas funny right there.....no advice just go out and have fun and the next thing you will do is build a FED.....
    chryslerfan55, loudbang and saltflats like this.
  10. JUNK ROD
    JUNK ROD
    Looks rad man!!!:cool:
  11. Tickety Boo
    Tickety Boo
    from Wisconsin
  12. Tickety Boo
    Tickety Boo
    from Wisconsin
    Salty, you must have edited out the back end of my Chevelle in the video :p:p:p
    chryslerfan55, saltflats and loudbang like this.
  13. saltflats
    saltflats
    from Missouri
    Believe I have a video of that in car run on my youtube , Norb.
    loudbang and Tickety Boo like this.
  14. GlassThamesDoug
    GlassThamesDoug
    Don't race without a loop, especially with good traction, however you obtain it...[emoji16]
    Sent from my SM-J320V using The H.A.M.B. mobile app
  15. I see that some people save their trip-zip time slips.
    I usually throw them away..Especially the ones with LOSE on the bottom:(
  16. 03GMCSonoma
    03GMCSonoma
    You don't want to spin your tires too much. "Spinning ain't winning."
  17. Tickety Boo
    Tickety Boo
    from Wisconsin
    There was a lot of history to this one Mark,
    My friend the Powershifter and I had been talking smack for about 3 years waiting for him to get his Ford up and running for the Meltdown Drags. :rolleyes:
    Scotts dyno sheet showed about 100 more hp than my Chevy by then, I knew my only chance was to cut a good light.
    He was still sorting out his suspension so should be running low 10s by now ;)
    So even though I Lost it was of my best races ever, and also received a $100.00 gift certificate from Compe***ion Products in Oshkosh for the perfect light. :cool:
  18. saltflats
    saltflats
    from Missouri
  19. RmK57
    RmK57
    I keep them all. Good for reference, write on the back any changes you made, tire pressure, air temp, etc........
    swade41 and loudbang like this.
  20. ..Or use a free Jegs log book ;)
    I write the weather specs right on the slip, before it changes.
    Eventually, they get logged in.
    INVISIBLEKID and chryslerfan55 like this.
  21. Cool!
    I had a set of M/T ET Streets from when I was on Team Mickey. I got them for my 62 Tempest 455.
    One night I stuck them under my o/t p.u. in street bracket. I told my buddy that they'd never spin and I was going to go trip-zip, or red, on the first hit. Sure enough , I came up .000 on the first TT. That made me no. 1 qualifier, in place for the first round bye. I got in the back for 1st round and come to find out , there was 32 cars..No byes any time.
    Lost the the eventual winner, right then and there :(
    chryslerfan55 and Tickety Boo like this.
  22. oldiron 440
    oldiron 440
    At least racers that win!:)
    I think the biggest thing is getting your car through tech and getting yourself familiar with your car. As you have pointed out fuel line, driveshaft loop should be worked out ahead of time. As far.as being familiar with your car, burnouts without smoking the clutch or rolling past the starting line are important, getting used to the car pulling hard in first gear with the slicks on ( the first time I took my 65 Willys pickup with a 440, TF with a J converter 4.10 gears and slicks out on the blacktop I could feel the weight of my eye balls on the hit ) theres just more going on faster. So find a quite place to practice getting the car in second gear with the slicks on.:)
    Good luck
  23. I thought I'd better point out that a back road test will tell you almost nothing about the slicks.
    You're going to be on a prepped and glued track, unless it's some rinky dink place.
    You don't want to slip the clutch. You want to go to the track and find out how high you can come out , without spinning or bogging., and letting out the clutch as fast and hard as you can, if you want to get a hole shot jump on the other fellow. Tire pressure should be ,at a minimum, half what they are at now.;)
  24. oldolds
    oldolds
    He should find a private place with 60 foot of concrete pad and enough room to stop after that. I am sure there are places that you could get permission to do a couple burn outs for practice in an industrial complex. Then buy some glue and try to break things!:eek:
  25. slayer
    slayer
    Don't be so sure on dropping the tire pressure with Towel City slicks. Most reports from guys I race with is those slicks work better with more pressure unlike a conventional slick. I think it has to do with being a recapped a radial. You will just have to experiment to find your ideal tire pressure.
    chryslerfan55, 53 hemi and loudbang like this.
  26. I did not see where he said they were radials.They come both ways, don't they?
    Yes, you are right about radials. Whole different deal. In fact, real radial slicks won't even work on a stick shift car. You'll bounce all over the place. These, with a standard stiff sidewall..who knows?
  27. 53 hemi
    53 hemi
    Alright, guys - I'm still here!
    Minor carnage lol
    So last night I took the coupe out to the local street racing area - check out "da pad New Orleans" on YouTube; it's a crazy place.
    It was early, around 7:30 pm and only many people were actually there. There's an area where people hang out about 1/4 mile from where the actual racing takes place. I cruised through there and was spotted by a modern Mustang. He followed me out and wanted to run en route; I was pretty oblivious and he came up on me; I was in 3rd gear and when he got along side, I dropped it down into 2nd and pretty much surprised us both Haha! But anyways, I stopped at the drag area and he kept on going, so whatever.
    Where they race there's a pretty big "burnout pit". I pulled into that -
    Ok, these slicks are new radial casings and then freshly recapped. I had the tire pressure at 40 psi (for whatever it's worth, the sidewall says 44) thinking that much air pressure would be better for just cruising around and doing burnouts and what not; I didn't think they'd hook too well...
    So, I held the engine at 2000rpms and popped the clutch. Instant, intense wheel hop and bang - u-joint failure, or so I thought.
    I pushed it off the road, tossed the driveshaft inside and called AAA. It was dark and i just had my phone for a light. IMG_20200124_211740_038.jpeg
    Sent from my SM-G950U using The H.A.M.B. mobile app
  28. 53 hemi
    53 hemi
    Got it in my garage and basically, what happened was with the wheel hop the u-joint didn't fail (this u-joint is a 1330 / 1310 conversion unit, with the 1310 on the pinion yoke) , but rather the straps that held the u-joint to the yoke did. These were straps, with bolts, not u-joint u-bolts.
    I also posted a pic of a tire after I got home; they're sticky! 20200125_073539.jpeg 20200125_073549.jpeg
  29. 53 hemi
    53 hemi
    After more inspection it looks like everything is ok, nothing really broken. I've ordered a new u-joint and actual u-joint u-bolts, both from ****er. I'll put it all back together Monday, with my street tires!
    Now, at this point I got troubleshooting with my older brother. He's a muscle car guy and doesn't have a presence on here, but is aware of the forum.
    I asked if I could share his notes with you guys - imagejpeg_0.jpeg imagejpeg_0(1).jpeg IMG_7575.jpeg
  30. elba
    elba
    Back in the 60s at Quaker City , I saw a car go thru the traps at about 100 MPH backwards because the driveshaft fell out and went under a wheel .
