Projects Timm builds a model A
Discussion in 'The Hokey Ass Message Board' started by Tim, Mar 8, 2016.
  1. Six Ball
    Six Ball
    from Nevada
    When you make the paper gauges be sure the tank is full, the engine is cool, the oil pressure is good, the speedo is at 120mph and the tach is a 6,000 rpm. Because you'll never see it again. :eek:
    Stogy, brEad, Mike Moreau and 4 others like this.
  2. Tim
    Tim
    from KCMO
    Lil'Alb, kidcampbell71, Stogy and 5 others like this.
  3. Inked Monkey
    Inked Monkey
    3 sets of eyes
    Stogy, loudbang and Tim like this.
  4. Tim
    Tim
    from KCMO
    Spider dash spider dash... haha.
    last work morning before baby aka no loud garage time for a couple months.
    let’s see what happens!
    drdave, Stogy and loudbang like this.
  5. Tim
    Tim
    from KCMO
    One hour coffee break update.
    heat, a hammer, and a very large clamp and the lump in the center of the firewall is hammered close enough for mocking up the firewall bracing.
    going to get after the dent from the fuel pump now.
    best case scenario I get the two center gauges drilled and mounted because I more or less know where they need to be.
    kidcampbell71, Stogy, OFT and 2 others like this.
  6. Inked Monkey
    Inked Monkey
    I used to buy hole saws to cut for gauges but then I found out a jigsaw works just as good. A lot cheaper too
    kidcampbell71, loudbang and Tim like this.
  7. Tim
    Tim
    from KCMO
    Good thought. This big ****er cut the first hole in 16g just fine but the second one was an ordeal. I just wanted to get a second hole before the drill or the hole saw gave out.
    the 4 other holes are smaller so I don’t think I’ll have a much issue but worse case they’ll make a good scribe line for the saw.
  8. Tim
    Tim
    from KCMO
    Really only took three photos. Short on time today so even this will be shorter than my normal ramble.
    Used mostly hammer and dolly and a some heat shrinking to get the center of the firewall close enough for mock ups.... I think. The fuel pump divot I used a cut off wheel and cut the sides and bottom and hammered it forward. I’ll deal with welding it and making it pretty later.
    tapped and marked center lines and mocked up gauge and medal placement.
    drilled two pilot holes and the. Two giant hole saw holes. First Pilot hole landed about 1/16- 1/8 off mark so I just made them both the same amount off from the mark.
    any how shoved it back into the car and tossed the dash bar on with a magnet before calling it quits.
    mill sit in the car and tape the 4 smaller ones on late tonight when everyone’s in bed. Might file the holes and slide the tach and speedo in while I’m there... 764D8FFC-83B0-4471-83FA-641526DE0C05.jpeg F6AEEEFC-A706-4403-970E-4E5290EDF9D1.jpeg 150BD62B-9B6A-4526-9C6F-5B060998F4A9.jpeg
    drdave, Stogy, loudbang and 5 others like this.
  9. Tim
    Tim
    from KCMO
    Progress! 25408BB1-7E1B-42C6-89F2-6BA37FAD2F79.jpeg B9CAD0BB-9CC4-4725-B1F8-4D3F61F42336.jpeg All together, he used a small bit of cut off to fill the little gap at the end of the p***enger side of the cross rail.
    Stogy, brEad, loudbang and 1 other person like this.
  10. Tim
    Tim
    from KCMO
    You got me curious. Other than it being shaped like a brick that seems doable...
    ~used th350 because 3rd is one to one just like this three speed 6195523D-6F62-4411-B288-CE6492A948CD.jpeg
    Stogy, Six Ball and loudbang like this.
  11. Tim
    Tim
    from KCMO
    Wrapped the body in tape and slid the tach and speedo into the dash 30563E9B-7A3F-4155-94B2-004A019E63D3.jpeg 5ACB794E-6D46-44DA-BED8-1A460D60FE27.jpeg buddy was giving me a hard time that I wouldn’t be able to read the tach but this is pretty much exactly how I see it from driving position 48989362-45EC-4E49-BF63-E64AB9C51009.jpeg 9D4E0189-D9F4-4264-BB43-610A5272BCFF.jpeg that thinking in mind I stuck the side gauges where I could see them in each quarter of the wheel. Split by the spoke I could see them just fine but hated how they look. 06003526-9A1D-4F91-BF9A-73124D8CCE30.jpeg 63434AF9-FEDA-4795-A72B-6BB2AD6A1495.jpeg E283B8C8-34E9-4BFD-A5A9-7900D35BEF5D.jpeg switched them to both being visible threw the wheel and I think it’ll probably make the p***enger side gauges easier to read as well.
  12. Tim
    Tim
    from KCMO
    Also, with the dash bar mocked up I have less room under there than I thought for hiding things. I want to put a little dash light over the st Christopher medal in the center of the dash hid behind the dash bar but it seems a normal built will be to tight.
    Anyone have a lead on a small dash light that’s maybe an LED but a warm tone?
    Stogy, Thor1 and loudbang like this.
  13. Six Ball
    Six Ball
    from Nevada
    That looks good and any way you can always move the steering wheel a little to see the gauges, maybe not at 4774 rpm, but in general. :rolleyes:
    Stogy, loudbang, brEad and 1 other person like this.
  14. redzula
    redzula
    Had that happen a few times... So much that I've gotten in the habit of select all and copy before actually posting a long update just in case.... Actually saved me a few times.
    Progress looks good been following on socials just reading it all here though. Keep it up. Baby will be here before you know it.
    Sent from my rotary phone using The H.A.M.B. mobile app
  15. Tim
    Tim
    from KCMO
    Baby has arrived safe and sound!
    and my brain feels much better :)
    kidcampbell71, drdave, Stogy and 9 others like this.
  16. waxhead
    waxhead
    from West Oz
    Congratulations to you and your family.
  17. OFT
    OFT
    Congratulations!!!--how is mom and baby doing???
  18. Tim
    Tim
    from KCMO
    thank you!
    Mama, baby and everyone are doing well. My wife is super human :)
    kidcampbell71, drdave, Stogy and 4 others like this.
  19. redzula
    redzula
  20. Tim
    Tim
    from KCMO
    They are setting off loads of fireworks in Kansas City. Word must have got out
    Stogy, brEad, Six Ball and 1 other person like this.
  21. Six Ball
    Six Ball
    from Nevada
    A healthy baby is a wonderful thing. Is this the first? Congratulations, Where's my cigar?
    Stogy, Tim, waxhead and 1 other person like this.
  22. Tim
    Tim
    from KCMO
    Second :D
    Stogy likes this.
  23. Six Ball
    Six Ball
    from Nevada
    So you are an old hand at this stuff. One word of caution more kids is not an addition problem it is a multiplication problem. Take it from a retired school teacher. It's not just one more it's how that one deals withe all the rest and how the rest deal with it. But two in a family is all good. As a dad I love to see how my two grown sons deal with each other. Good men! Their mom did a great job.
    drdave, Stogy, loudbang and 1 other person like this.
  24. brEad
    brEad
    Congrats Tim! Glad everyone is doing well.
    loudbang, Stogy and Tim like this.
  25. Stogy
    Stogy
    Congrats HambDaddy O @Tim...;)
  26. Tim
    Tim
    from KCMO
    Thanks guys. It’s a ripple for sure but we’re doing well so far :)
    Stogy likes this.
  27. Six Ball
    Six Ball
    from Nevada
    It was funny this morning I was telling you about raising kids at the same time you were telling me how to build hot rods. Our posts must have p***ed in cyber space close enough to wave. :D
  28. Tim
    Tim
    from KCMO
    Haha I had noticed.
    Stogy likes this.
  29. Rocky
    Rocky
    Classified Editor
    You da man.........Dad
    Tim, loudbang and Stogy like this.
  30. Tim
    Tim
    from KCMO
    We’ll come visit uncle Rocky this spring ;)
    thinking these little license plate bolts/ lights might do the trick for lighting up the medal on the dash and maybe a bank of switches. Tuck them up under the dash rail and maybe tie it to the headlight switch?
    95BDFDCB-9B8D-4829-8E0E-A1031675FC52.jpeg 09F23B3C-9DD7-410A-8DC9-5686D7951E76.jpeg
    OFT, kidcampbell71, brEad and 3 others like this.
