Technical 700r4 Pump Installation?
Discussion in 'The Hokey Ass Message Board' started by greasemonkey54, Jan 19, 2020.
  1. I am replacing the front pump seal on a 700r4. The gasket set came with washers and o rings for the pump bolts but no instructions on which order the go. I ***ume I slide the washer on first followed by the boring? The original bolts had rubber coated washers it appears. Just trying to get it right to avoid leaks.
  2. squirrel
    If there is a groove for an O ring, use the O ring. If there isn't, use the gasket. I think the O ring was only used in the 1960s on the early TH400. but I don't know much about the 700, only been in a few of them.
  3. 173
    173
    I recently put together a 700r4 and the bolts for the pump all had o-rings in a recess in the bolt head. That was an 87 unit, perhaps yours is earlier and uses a different type of washer? I would think that an o ring on top of or under a washer that is flat would just squish out...
  4. It's a 1986 unit. This is a picture of what I have. Bottom is the original washer, it seems to have rubber or ATV on it. Middle is the new washer and top is the oring. On the right is the bolt. 20200119_200710.jpg
  6. Marty Vanin
    Marty Vanin
    82 -86 used washers,87 and up used o rings.like 173 said if there is a recess under the head of the bolt use the o rings if not use the washers. Some one may have changed them at some point
  7. Marty Vanin
    Marty Vanin
    Use the washers
  8. Thanks guys. There are no instructions in the kit and I really dont want to pull this thing again.
  9. squirrel
    interesting that they went back to the O ring design, after abandoning it for 20 years.
