Did Edelbrock make an intake for
Discussion in 'The Hokey Ass Message Board' started by Flathead Youngin', Jun 30, 2006.
  1. Flathead Youngin'
    Flathead Youngin'
    putting the generator in the stock location on a flatty? I know offy did....
    like this but in Edelbrock.....
    edit: i've looked at jegs, summit, etc. and only saw the one regular style...
  2. Bruce Lancaster
    Bruce Lancaster
    And one other...the "slingshot" two piece very early Edelbrock, now scarce and expensive. Go with a super dual...
  3. Flathead Youngin'
    Flathead Youngin'
    I have a brand new super dual with the offset genny bracket (probably going to sell for trade off). I can't run my generator in the center and clear the radiator (unless I shove it so far forward that it looks silly) and if I put the offset bracket on, it'll look goofy and the fan won't be centered in the radiator...
    And NO, Petejoe, I won't run a wussy electric fan......:D
    EDIT: I double check the fan in the center but it needs around an extra 3-4"......you know how much value real estate has under the hood of an AV8
  4. Bruce Lancaster
    Bruce Lancaster
    Would any of the '32-39 generator mounted fans fit in the center? If so, you could make an extra gen into a shortened fan supporter in the center.
  5. Bruce Lancaster
    Bruce Lancaster
    This is indeed an aesthetic problem--the flathead is very Gothic in its archtecture, and does demand symmetry...
  6. dmarv
    dmarv
    Alliance Vendor
    from Exeter, CA
    Offenhauser did make different gererator offsets. I'm not sure which one you have, they have one to mount the generator to the p***enger side or driver's side. Maybe a different offset would work better. Download a copy of the Offenhauser catalog from the link below. Page 33 shows the generator offset brackets.
    Dan Marvin, Owner
    Exeter Auto Supply
  7. speedo
    speedo
    from Dayton,OH
    Does the PM7 allow for a center generator? Anyone know about the Eddie Meyers high rise?
  8. dmarv
    dmarv
    Alliance Vendor
    from Exeter, CA
    I also forgot to mention that Offenhauser makes a fan carrier bracket that places the fan in the stock location, while you move the generator to the side. Part number is 3499. Which I can get from Offenhauser for you.
  9. Bruce Lancaster
    Bruce Lancaster
    The right and left generator brackets are very different. They mount to the same places, but one mounts the gen perpendicular to the head, the other mounts it perpendicular to the world, resulting in different placement. The perpendicular to head one was originally to clear the low radiator hoses on '39-41 Fords, and gives very poor belt wrap on the pump drive pulley.
  10. Bruce Lancaster
    Bruce Lancaster
    That 3499 bracket directly mounts the shaft and hub for a '42-48 fan to the generator mount pad.
  11. dmarv
    dmarv
    Alliance Vendor
    from Exeter, CA
    What engine, heads, and intake manifold are you using?
  12. dmarv
    dmarv
    Alliance Vendor
    from Exeter, CA
    Bruce, you are correct once again!
  13. Flathead Youngin'
    Flathead Youngin'
    i'd love to have a slingshot or a pm7 but my pockets aren't that deep at the moment....:rolleyes:
    my bracket will put the generator on the p***enger side and i also have the little aluminum backet to run the fan in the center........i can't run the fan in the center because my 59ab was installed in a 33 sedan and the front pulley was machined off of the crank pulley.......because it was machined off, i pushed the engine farther forward so the breather would clear the fire-wall but that still wasn't enough.....
    here's what i have....
  14. As a side note, there must surely be a tradeoff in performance using a slingshot instead of a super dual?
  15. speedo
    speedo
    from Dayton,OH
    I never head that, why was that? I have a set of edmond heads, and I was looking for an intake, maybe I'll think twice now....
    I think Wildcap makes a sharp intake like the one your looking for, it doesn't show it on the wesite, but I thought that they had or were making one.
    Plus I agree with Bruce, I am running an offset bracket, and well if it weren't under a hood, I would change it, make me shudder when I see it...
    "it does demand symmetry..."
  16. Flathead Youngin'
    Flathead Youngin'
    because of the distance the fuel has to travel? wouldn't that hold true with a slingshot and pm7 type intake........it's hard to burn valves out of flatheads that are using the tungsten valves.....
    did you burn valves or just hear about it......not disputing YOU but maybe someone had the front carb leaned out real badly.....just curious....the offy and the edmunds seem to be a quick fix for what i'm doing......
    i'd like to see a pic of your fan setup that you converted.....
  17. tommy
    tommy
    sure did! mine is an early block letter manifold. The later ones had script lettering. I don't know if it still is available.
  18. tommy
    tommy
    For the front cylinders to lean out you would have to add air to the mixture from a vacuum leak. The mixture ratio wont change just because it travels further. IMHO. My plugs all burn the same.
  19. SinisterCustom
    SinisterCustom
    Thats what I'm thinking too.
    Jeez... I hope the end cylinders on my SBC don't run lean with my tri-power running progressive????:eek: haha
  20. 47bob
    47bob
    I have a super dual with an offset alternator and had to use two different radiator hoses. Looks like ****. If i had it to do over i'd run a 4 barrel.......................As for lean cylinders; i wouldn't think they would run any leaner than with a stock 2 barrel
  21. klazurfer
    klazurfer
    Tommy : " The mixture ratio wont change just because it travels further .. "
    true , but you forgot something : HEAT & THERODYNAMICS ;)
    Klaz
  22. dmarv
    dmarv
    Alliance Vendor
    from Exeter, CA
    What engine and heads are you running? Offenhauser makes a 45 degree elbow to clear the generator for 1949-1953 engines and heads.
    Dan Marvin, Owner
    Exeter Auto Supply
  23. tommy
    tommy
    Then you better stay away from all those dual quad 283-270, 409-425 Chevys and the Buicks of the same years (I not sure of the CI or HP on them.):D
    I don't seem to remember any epidemic of burnt valves in those engines. They had heat and thermodynamics too...didn't they?:D:D
  24. 47bob
    47bob
    '47 Ford 59AB
  25. klazurfer
    klazurfer
    Tommy : " Then you better stay away from .... " I sure will ! :) Anything made by anyone that had no clue when it came to THERODYNAMICS is out of my book ...:) ...Just kidding ;) .... I think ..:confused:
    Klaz:)
  26. speedo
    speedo
    from Dayton,OH
    dmarv, I don't think I've ever seen that 45 degree bend outlet your talking about. Do you have any pictures? I have the same problem with the 2 different hoses and it looks like ****, too. I had to run one of the krinkle hoses for now because every other hose I tried to use kept having to sharp of a bend and I was afraid of it colapsing
    skidmarks, I'd like to see your setup too, sounds kinda nice.
  27. speedo
    speedo
    from Dayton,OH
    dmarv...your inbox is full...I got your PM and bump back up for pictures of skidmarks setup...
  28. Flathead Youngin'
    Flathead Youngin'
    tommy, do you know what # that intake is?
    edit: wait, that's an 8ba style.....weren't the gennerators a bit shorter on them?
    do you know the 59ab #
  29. zgears
    zgears
    a couple shots of my Edelbrock regular
