Hot Rods # 10 Track Roadster Build- Marty Strode
Discussion in 'The Hokey Ass Message Board' started by Marty Strode, Jan 24, 2020.
  1. Marty Strode
    Marty Strode
    As the ***le states, this will be the 10th Track Roadster I have built, on this platform. It all started for me, building #7, back in the mid 90's, hoping to find a market and getting a few cars together for some dirt track action. Of the 9 that I built, along with a Tub of the same design, only one was not a complete construction, on my part. The blue # 8 was a combined effort by my racing partner Ernie Martin, and myself here in my shop. 6 of the 9 cars saw track time over 8 years, as well as many miles of street use, the black one with Red Ram power, has over 25,000 miles on the clock. The latest one will be for my good friend Bill Towers from Delaware, a long time racer and true Hot Rodder ! That's it for the intro, construction photos to follow. 2014-10-14 124717.jpg Fast Lane track-t's 008.jpg 012_12.JPG T-2.jpg
    LCGarage, HarryT, Outback and 33 others like this.
  2. jim32
    jim32
    Looking forward to the photos and story. This will be good! thanks in advance.
    loudbang and Stogy like this.
  3. Marty Strode
    Marty Strode
    It all starts with my last pair of laser cut frame rails. When I weld the tapers, I clamp them down to a 6"X 6" square tube, putting a back bow in the front section. The reason is, welding that 3' front section will cause quite an arch to the rail, I only want a slight arch when fully welded. The 7th picture shows all of the templates I used to replicate all of the previous cars. As we progress, it will show all of the fixtures I developed for setup and welding of the rest of the build. More pics to follow shortly. IMG_3792.JPG IMG_3794.JPG IMG_3800.JPG IMG_3818.JPG IMG_3819.JPG IMG_3822.JPG IMG_3836.JPG IMG_3838.JPG IMG_3842.JPG IMG_3851.JPG IMG_3846.JPG
  4. Blues4U
    Blues4U
    from So Cal
    Hot damn! I'm in for the ride. Thanks for sharing Marty!
    Outback, loudbang and Stogy like this.
  5. Marty Strode
    Marty Strode
    Moving along, this covers the ***embly of the perimeter frame using a stock Model A rear crossmember and the installation of the front radius rod mounts. The last shot is the fixture for the front engine mounts, which will be next. IMG_3853.JPG IMG_3854.JPG IMG_3849.JPG IMG_3855.JPG IMG_3856.JPG IMG_3866.JPG IMG_3867.JPG IMG_3871.JPG
    Deuces, Lil'Alb, Outback and 20 others like this.
  6. 41rodderz
    41rodderz
    from Oregon
    Nice. Where are you playing ? Sunset ?
  7. pitman
    pitman
    Great work! The pics help any builder Marty.
  8. Marty Strode
    Marty Strode
    Engine mounts for 8 BA Flathead are fabricated from 10 ga P&O steel. I machined up a pair of aluminum biscuits for setup purposes, as they hold engines solid, and it will utilize Bob Drake mount cushions. That's it for today, as I need to dig out a bell housing and trans to install tomorrow. IMG_3873.JPG IMG_3874.JPG IMG_3877.JPG IMG_3875.JPG IMG_3878.JPG IMG_3879.JPG IMG_3880.JPG IMG_3881.JPG IMG_3882.JPG
    Deuces, Lil'Alb, Outback and 22 others like this.
  9. Marty Strode
    Marty Strode
    Nah, they discontinued Vintage Racing nearly 15 years ago, don't race anymore !
  10. Nice work Marty. I miss my TRP #43 every day but I don't miss the lack of leg room. Other wise they are lovely hot rods.
    chryslerfan55, loudbang and Stogy like this.
  11. gnichols
    gnichols
    from Tampa, FL
    I'm in. LOVE these cars. Gary
  12. Gofannon
    Gofannon
    Subbed. But I get the feeling I'm going to want to s**** the ch***is on my own build and start again after seeing this.
  13. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Marty,
    I'm trying to understand the laser cut frame rail bit. Is the starting point a piece of a rectangular tube? The laser part is the vee cut? Held apart by the wood blocks because?
    The drawing looks like the rails might taper on both ends, more at the front and just a bit at the rear. Or, is that just an optical illusion?
    If a guy was just going to build a one off, would it be more cost effective just to cut the wedge out with a jig saw?
    Damn, you weld good!
    Be ready for more questions from here. I want a track roadster REAL bad!!!!!:D And I got a torch and a hammer! :eek:
  14. A Boner
    A Boner
    Still wish someone would make a 23 style fibergl*** roadster body that is not only a few inches longer, but also a couple inches taller... to keep the body in proportion and allow more people to fit in them comfortably.
    Been waiting for this build thread, and love the Rodder’s Journal feature article on these HOT RODS, thanks!
  15. lumpy 63
    lumpy 63
    As usual beautiful work Marty! Whats the story with the mid engine Corvair?
    chryslerfan55, bchctybob and loudbang like this.
  16. Marty Strode
    Marty Strode
    Thanks for the rapid replies ! Bruce, if you want one, build it no matter what you have for equipment. As far as the laser cut rails, I had 6 sets done a the same time, and it really saved me a lot of time. If you have a saws all or jig saw, clamp a piece of 1/4" flat bar to the tube to act as a fence, and get after it ! The one thing about a Track Roadster that is appealing, is they are labor intensive, but materials are relatively cheap,and front and rear axles can be hand me down old Ford parts. No better thrill for the dollar.
  17. Been there, done that. Sawsall, tape, cardboard, steel tube for strength and lots of fibergl***. Center steering helps. Oh, and a overstuffed chair to kick back in while you're pondering the proportions for the right 'look'. Even made mine a bit wider too. Being 6'3"/ 325lbs sometimes has it's limitations.
  18. hotrodA
    hotrodA
    Beautiful cars! That shot of three side by side is cl***ic.
    BTW, what's the status of the 40 shop truck?
    catdad49, loudbang and Stogy like this.
  19. Marty Strode
    Marty Strode
    Hi lumpy, The car belongs to my old pal Lonnie Gilbertson (famous car builder) , I thought I would never say the words "wicked and Corvair " in the same sentence, but it certainly qualifies. It's here for a roll bar and an engine cover. It's OT and I won't post pics here, but you can check it out on his site.
    http://www.lonniesplace.com/projects
  20. BrerHair
    BrerHair
    Subscribed. A real pleasure to peek in on the pros, thanks for taking the time Marty!
  21. Lytles Garage
    Lytles Garage
    Marty, I built 10 Dump truck beds ?? We must be readin each other's mail ??!!!!!
  22. Marty Strode
    Marty Strode
    The 40 is out getting the final prep for paint, Washington Blue.
  23. Marty Strode
    Marty Strode
    Bruce, the reason for the wood blocks, is to hold it apart while grinding a weld prep on the joint, for proper penetration. The split bones up front, requires the frame to have torsional rigidity.
  24. bskustoms
    bskustoms
    from Aloha, Or.
    As always beautiful work Marty
    Sam
  25. Marty Strode
    Marty Strode
    Sam, we need to have lunch sometime and look over your Olds !
  26. 41rodderz
    41rodderz
    from Oregon
    Okay lol. Guess I am still behind the times :D
  27. Marty Strode
    Marty Strode
    I bought a very nice stamped steel, 49-51 p***enger car bellhousing from my pal Ernie. The key is to have all the correct clutch fork ***embly and starter plate for this unit, and he had it all. I had to borrow a transmission for set up, as the only 3 speeds that I have, are the RAT heavy duty ones, that will not work with the T-150 Jeep top shifter. I remove the outside/top ears from the trans as pictured in the last pic, because the trans is exposed. IMG_3883.JPG IMG_3885.JPG IMG_3886.JPG IMG_3887.JPG IMG_0672.JPG
  28. Marty Strode
    Marty Strode
    Trans mount crossmember bent, fit and tacked in place. Center gussets and diagonal tube "K" braces are next. Can't wait to remove the 1" square tube temporary brace. IMG_3888.JPG IMG_3891.JPG IMG_3893.JPG IMG_3894.JPG IMG_3895.JPG IMG_3896.JPG IMG_3897.JPG
  29. King ford
    King ford
    from 08302
  30. Marty Strode
    Marty Strode
    King, P&O stands for "Pickled and Oiled". It's "Hot Rolled" steel, that has gone through a chemical process to remove the blue mill scale from the surface, then oiled to preserve the clean exterior. It makes it nice to mark on, bend, and especially clean for Tig welding. Did you notice how clean the frame rails were ? I had them sandblasted to achieve the same result.
