Technical Powder coating question on Aluminum
Discussion in 'The Hokey Ass Message Board' started by Budget36, Jan 24, 2020.
  1. Budget36
    Budget36
    I have an Al intake I cleaned up in my blasting cabinet. I'm going to order a powder coating kit and put an old oven I have to use.
    The question I have is will the porosity of the Al show with the coating, or do I need to polish the intake first?
    Thanks
  2. MoparTobi
    MoparTobi
    from Macon, Ga
    Lay it on nice and thick and it will "flow out". Practice on some s**** first. Make sure you bake the intake first to let it outgas!
    Just Gary and Budget36 like this.
  3. belair
    belair
    Kind of like paint. It will show what's underneath.
    Budget36 likes this.
  4. Bandit Billy
    Bandit Billy
    Knock em down with 80 grit if you like 'em silky, smooth the sharp edges and remove the logos , no need to polish.
    This is 80 grit finish
    I was going to powder coat but I rattle bombed mine instead with Eastwood 2K Ceramic gloss black engine paint to match the block and trans.
  5. Really good job Billy,
    Looks a lot better than the factory new surface .
    That’s your low deck engine isn’t it,,,,,,291,,,, looks just like a piece of art !
    Or is that your 330 ?
    Tommy
    Bandit Billy likes this.
  6. fullhouse296
    fullhouse296
    from Australia
    pre heating before layin on the powder will stop the bubbling and give better adhesion long run .
    Budget36 and WB69 like this.
  7. oldolds
    oldolds
    Used intake?
    Heat it up in the oven and see if any old oil residue comes to the surface before you coat it.
    Budget36 and lothiandon1940 like this.
  8. WB69
    WB69
    from Kansas
    Had it done by a friend, came out very nice. He did preheat as said above. Probably doesn't hurt that he does it for a living too.
  9. Budget36
    Budget36
    Thanks all for the advice.
    Yes it's a used intake.
    How long should the preheat be for?
  10. Bandit Billy
    Bandit Billy
    330 tall deck. And thanks. That is high praise from a Desoto fan.
    @Budget36 make sure you post up some pics of the before and after powder. Maybe I missed it but what color are you doing?
  11. Budget36
    Budget36
    @Bandit Billy I'm not sure on the color yet, possibly a deep blue.
