354 392 HEMI Itakes
Discussion in 'The Hokey Ass Message Board' started by The37Kid, Sep 28, 2008.
  1. christineman
    christineman
    from minnesota
    Would u have or know of any of the above intakes for sale?? Also, do u have any idea of which if these r the lowest in height??
    Mel@moparmel.com
  2. christineman
    christineman
    from minnesota
    do you have any of the above for sale or know of one that I can pick up? also, do you have any idea of which one is the lowest in height?? ;thanks
    mel
  3. 73RR
    73RR
    Mel, keep in mind that not all of the listed intakes interchange. If you find an Edmonds 2x2 it will be for the 51-53 331, and the 2x4 will be for a 54-331, both will have t-stat cast in. Yes, they could be used on later engines but they will not be a simple bolt-on. The Edmonds intakes are also a bit taller than later dual-carb intakes (like Weiand or oem)
    As to height, the 3x2, 4x2 and 2x4 inline will be the lowest due to the single plane design.
  4. Kerry
    Kerry
    What kind of differences do you see in the early to late intakes Gary? Inquiring minds want to know.
  5. 73RR
    73RR
    Kerry, I may have been a bit vague, sorry if there is confusion.
    Obviously, the 51-53 has a 'port size' issue, and the 54 has the t-stat issue. If using a 51-54 intake on a 55-58 engine then 'something' has to be done with the t-stat(s), hence the 'not a simple bolt-on' statement.
    Nothing dramatic, just additional work to contend with.
  6. George
    George
    Either block off the Thermostat opening, or block off the front of the heads & use a 392 or chevy waterpump.
  7. George
    George
    linky
  8. Verminator
    Verminator
    It's an old thread. but I just unwrapped this, hiding in the rafters. Was saving it for my 57 392 going into something project. Ready to go with rebuilt carbs, linkage and 2 new air filters 1634285 10/58 date
  9. Dago 88
    Dago 88
    Maybe a silly question, if someone can help me with, are 354 & 392 intakes interchangeable? Thanks in advance:)
  10. slayer
    slayer
    Yes the intake s will interchange as long as there both p***enger car engines. Some 354 truck heads are slightly different in the heat riser area.
    Just Gary likes this.
  11. Dago 88
    Dago 88
